Question about Poulan Pro 22" Self Propelled High Wheel Mower
Where is the air filter located on a lawn mower
  • 360 Answers
If the engine has a plastic cover, remove it.
On top of the carburetor will be the air filter, usually it is enclosed in a metal container with a single long screw going into the middle of it. remove the screw and the filter will come right off for cleaning/replacement.
Posted on May 03, 2010
  • 126 Answers
SOURCE: gas pouring out of air filter
carb is gummed up from the old fuel turning to varnish and clogging the jets. while trying to start, its trying to inject fuel, but its clogged and taking the path of least resistance (coming out the air filter).
you'll need to drain the gas tank and remove the carb to clean it out. if unfamiliar or uncomfortable doing this, then take it to someone to do a carb cleaning.
Posted on Jan 31, 2009
  • 143 Answers
SOURCE: 4.5hp B&S engine on a bolens mower..won't idle steadily
This is called hunting, your fuel-air ratio is not right. Your carb. jets need cleaned
Posted on Sep 05, 2009
Testimonial: "Thanks...always get great advice on here...."
SOURCE: Our Toro Personal pacer Model 20031 lawn mower will not start;
i turn the key and it grinds
Posted on Dec 06, 2009
hunter19_46m
  • 7482 Answers
SOURCE: my lawn mowers carburator overflow and leak gas
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Oct 12, 2010
SOURCE: Lawn mower chugging
better late than never, I have the same mower
there is no throttle control on these mowers, if you look under the air filter the throttle is balanced by a spring pulling in one direction and a lever controlled by engine speed. if the spring breaks or falls off the lever will wiggle back and forth, more gas if the engine slows, less if it speeds up. you end up going fast/slow/fast/slow etc.
The tension spring slows the switching down and smooths out the engine speed.
Posted on Jul 08, 2011
Where is the fuel filter located?
What kind of mower ??? Most 21" walk behind mowers ONLY have screens in the tank
Most riders have an inline filter
ALL commercial mowers have an inline filter
inline means it's in the fuel line going to the carb
Apr 12, 2015 | Garden
Craftsman riding lawn mower won t cut grass
Does it die when you attempt to engage the cutting deck? If so the you might have a clogged fuel filter, bad gas, dirty air filter, bad spark plug.
Or the mower engage switch may be faulty. They are located in different places on different mowers. But should be attached somewhere along the main pivot of the engage lever. Let me know if you need more assistance. Good Luck!!
Jun 05, 2012 | Craftsman Garden
I bought a new mower this summer. was stalling out and now won't start at all. where is the air filter located
The air filter is located on the right side, opposite side of the muffler. It is behind the flat vertical cover on the right side toward the forward end of the engine. The cover has a curve on the left and right side of the cover.
Aug 02, 2011 | Poulan Pro 22inch 625 Series Briggs ...
I do have murray22`` 6 hp i like to know if their is an air filter & where is it locted on my machine. i wonder if you can sand me the manual of this machine please
There is definitely an air filter. I don't have the manual, but the air filter will be located in a plastic box either on top or on the side of the engine. There will be a screw that holds the cover of the box closed, if you remove the screw then the cover will come off and reveal the air filter. The filter will either be foam or pleated paper.
Jun 07, 2011 | Briggs & Stratton Lawn-Boy Insight Series...
Where is the carburetor on the Craftsman 675 Series 190cc 22" cut self-propelled lawn mower?
The carburetor would be located BEHIND the air filter housing and air inlet tube. The air filter housing should have a removable (by screw or clip) cover.
Apr 13, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
Does my lawn mower poulan pro model#PR625Y22RKP have a air filter? where is it?
Just about all internal combustion engines have some type of air filter. Clean air to any engine is extremely important. Most engines always have the air filter located ahead of the carburetor or the fuel injection system. Yours is probably located on the side of the engine under a cover with a screw in it. The cover may look like part of the main engine cover, but it will be smaller. Check on both sides of your machine, just behind the front of the engine.
Jan 23, 2011 | Poulan Pro 22" Self Propelled High Wheel...
Lawn mower wont start. changed air filter, spark
Does it turn over? If it does, what happens? Does it sound normal when its cranking? I need more information to help. Is it a push mower or riding mower? Does it start by key or pull start?
May 01, 2010 | Poulan Garden
Where are the air and oil filters located
I don't think you have an oil filter on your push mower. You can go to www.buymtdonline.com and look under illustrated parts look up then enter your model number of your LAWN MOWER not your motor and it will give you a parts listing for mower and look under the sub categories for the engine and it will show you where the air filter is located and oil filter (IF ONE). Look at the little number by the air filter then scroll down to that number below the diagram and you will get the part number for the filter.
Hope this helps
roundo4
Aug 03, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Where is the air filter located on the poulman pro 6.75 ready sta
it is either on the handle up near the top which they call a snorkle filter or on the side of the carbi in a square plastic cover
Jun 27, 2009 | Poulan "Poulan" Push Mower
Can locate air filter on Craftsman 5.0 lawn mower Model#971 377 2
It is behind the cover hooked to the carburetor.
Mar 25, 2009 | Garden
Poulan Pro 22" Self Propelled High Wheel Mower Logo
279 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
