Question about Garden
My lawnflite 703 blade drive belt keeps jumping its pulley. It looks like 2 pulleys don't line up properly. There appears to be 2 pulleys, one of which has a tension spring on it and the belt goes rould the pulley that drives teh blade and then onto teh tension pulley. It is these 2 pulleys that seem to not line up causing the belt to ride off and jam.
  • alanincroft May 03, 2010
    The 2 pulleys that I refer to are both on the deck. One is attached to 1 of the blades and the tension pulley is right beside it. logically they should be level with each other but the tension pulley looks too high. The engine pulley is right at the front and the link between this and the tension pulley appears to be fine.
    both pulleys are on the deck, not as suggested in the answer I received. 1 pulley is attached directly to one of the blades and the other appears to be a tensioner. They are about 10 mm out of alighnment. The link form the tension pulley to teh engine seems fine
    Genius:
  • 1,400 Answers
Hello
Is the belt new or used? Replace it if its old.How are the blades?if one is out of balance it will cause the deck to shake and the belt to jump off.
The deck also needs to be level,this is done with rods and jam nuts located under the mower above the deck.There should also be a pin near the engine pulley that keeps the belt in the groove of the pulley,make sure its there and not bent.
Posted on May 03, 2010
  • 360 Answers
The pulleys will not line up since one is connected to the engine and the other is connected to the "deck" which goes up and down.
Around the pulley connected to the deck there should be a piece of metal that helps keep the belt from slipping off, if it is bent too far from the pulley, bend it back in. Also I would replace the spring with a fresh new one to keep a good tension on the belt.
I have a 30"/ 16.5 craftsman snowblower and the traction belt keeps jumping off almost as soon as I engage the drive. I have replaced the belts and it happened again.
1) Look for obvious pulleys out of alignment. Most pulleys on a drive system are 'keyed' and have a set screw or bolt holding them into position.
2) Most traction belts turn with the engine, so it turns all the time. Look for an idler pulley with spring attached that may be out of alignment.
3) Inspect the 'V' groove of the driven pulley for any foreign debris.
4) Inspect the driven pulley for damaged caused by another pulley or object striking the edge of the 'V'.
Feb 15, 2017 | Garden
I have a 52" Husqvarna LGT 2654 riding lawn mower and when I engage the blades, the belt does not turn the pulley system. What could be causing this, the pulley idlers, or the belt?
depending on the age of the machine, there could be several possibilities
1-- belts are not tight enough--- belt tension system is not correct, wrong length belts
2--bearings for the shafts for the blades are rusted up and seized - preventing the blades from moving--- switch the machine off , disengage the belt drive and see if you can turn the blades by hand
3--- if you have an electric pto system to drive the belts to the blades then that system is not getting full power to engage the PTO or the clutch is not working--worn facings
take it to a service dealer and have a proper diagnosis done
May 09, 2016 | Husqvarna Garden
How to replace cutter belt Lawnflite ride on mower 903 auto drive , it came off and don't have operator manual for configuration
There are idler and tensioner pulley's, you sould maybe go to a dealer they could maybe help with the proper routing.
Apr 18, 2015 | Garden
Craftsman LT2000 lawn tractor keeps throwing deck drive belt
Keep in mind that the mower deck gets to be raised and lowered into the desired mowing height, with no change to drive pulley (at motor) height. This requires a belt long enough to allow the furthest reach (usually with deck dropped to lowest setting) and a spring loaded tensioner pulley, to take up the slack (and keep the belt tight) as the deck is raised. There may also be a belt guide or two incorporated to help keep the belt from jumping ship in the process. Sometimes these are just a heavy gauge steel wire loop that attaches near the pulley to keep the belt from jumping if it gets slack. Possibly you didn't thread the belt through or under it properly, or have missed the tensioner pulley.
It could also be the tensioner spring is broke or has fallen off or become too weak. Have someone move the deck up and down (with motor off, and belt installed) while you watch to see there is any obstruction in path. Also look for the belt becoming loose at a certain point. Some tensioners have the spring built in to the pulley and you can't really see them. They have to be pre-loaded, by rocking the pulley spindle assembly against the spring force while you slip the belt over it. Sometimes the belt looks fine and not loose in static (not moving) condition, but when the blades are spinning fast and the throttle is closed with no load (no thick grass being cut) the blades momentum will cause a belt sag that is supposed to be taken care of by the tensioner. It can get pretty grimy down there, also very dry, dusty and caked with cement like old clippings. Check the manual and find out where your tensioner is, then check it to make sure that it can move freely and it isn't locked tight by debris or rust. Also good to check if there has been an update to your mower. Sometimes these problems cause a manufacter to offer a better spring, or change pulley sizes to correct a common problem.
Aug 11, 2014 | Garden
Lawnflite 991 sp6e self propelled lawnmower
Buy LAWNFLITE Spares
This site may have the part you are looking for.
May 17, 2014 | Mtd Garden
Ariens Hydro ride on mower, Blade Drive Belt will not stay on Pulleys
Are you sure it is the right belt? Is the tightener working properly Are the pulleys miss aligned?
Nov 05, 2017 | Ariens Garden
I have put a new drive belt on my MTD B130n and it keeps slipping off the main drive pulley at the rear. Idling pulley seems to lione up with front and back ones. Can anyone help please as I've had it to...
My name is Dane and I am going to assist you in solving your problem.
On these drive belt pulleys, many times the pulleys will line up, but there can still be 2 common problems. First, Is there a chance tha the idler pulley bracket is bent? If it is bent it can still be in line with the other 2, but allow the bely to jump off because the pulley will still not be right.
The other problem can be that there is not enough tension on the belt. You may have to get a new idlerpulley spring and install it.
I hope this helps you. Thanks. Dane
Dec 11, 2010 | Garden
G-110 deck belt keeps jumping off pulleys
check for a broken belt tension er or maybe grass clippings under belt area, check for a broken or loose pulley bearing, even a bent shaft on the deck.
Aug 07, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
826LE Power Max Snowthrower_ Drive belt keeps coming off
part # 94-8812 is traction belt 106-4498 auger belt
There is a service bulltin on this I have not seen this yet, Ill paste it for you to look at .
this was issued dec 22-2003 you would think that it would have shown up as a problem by now.
UNITS AFFECTED: Model Number(s): Serial Number(s):
38620 240000001-240999999
38621 (Int'l.) 240000001-240999999
38632 240000001-240999999
38635 (Int'l.) 240000001-240999999
38642 240000001-240999999
38645 (Int'l.) 240000001-240999999
38652 240000001-240999999
SUBJECT: Traction belt jumps off the pulley.
SITUATION: Incorrect pulley alignment causes the traction belt to jump off, usually when the drive is disengaged or as a hill is crested.
CORRECTION:
1. Remove the belt cover, engine belt guide and the bolt securing the crankshaft pulley.
2. Remove the auger brake assembly.
3. Remove the crankshaft pulley and the auger belt.
4. On the left side of the machine, remove the hair pin cotter from the speed control link and slide the link out of the pulley pivot assembly. The traction belt can now be removed.
5. Shorten the pulley half nearest the engine (PN 106-7334) shown in Fig 1. Grind or machine 1/8” (.125”/3.2mm). from the hub end of the pulley. The new finished length of the pulley half should be 1.07” (2.7cm).
6. Chamfer the bore to ensure the pulley fully contacts the shoulder on the crankshaft. You can send the pulley to an outside machine shop if you do not feel that you can modify the pulley in house.
7. Reinstall the pulley with a new traction belt.
A. Chamfer edge after grinding/machining.
B. Remove 1/8”.
C. Masking tape used as a reference line.
8. With the engine off, engage both the traction and auger levers and inspect the alignment of both the auger and traction belt idler pulleys (Fig. 2). Since we have moved the crankshaft pulley it may be necessary to bend the idler arms slightly to center the belts. Adjust as needed.
9. Install the engine belt guide and test operate.
10. Install the belt covers.
PARTS: P/N 94-8812 Traction Belt
Feb 04, 2009 | Agri-Fab Agri - Fab Snow Blower - 42"
Garden Logo
315 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
