Question about Asrock P4I45GV R5 Motherboard
Cpu beeps but no display on my monitor so i am not able to do anything, can anyone help me in the matter
    Guru:
  • 214 Answers
This is an Extended CMOS RAM problem, check your motherboard battery, and motherboard.
Posted on May 18, 2010
    Problem Solver:
  • 5 Answers
Beeping normally means either memory or video card issues. There are different beep codes dependent on your motherboard and BIOS. I would start with either or both to help resolve your situation. You can go to this site to help decypher the beep codes. http://pcsupport.about.com/od/nonworkingcomponent/ht/beepcodestb.htm
Posted on May 03, 2010
I am currently on my laptop because when I turn on my desktop, the monitor (ViewSonic VX2235wm) powers on with a message that says No Signal Digital and then turns off. Any suggestions?
hi; your monitor has no problem, its your cpu. Try to hook your monitor to your laptop,and change the display setting to your LCD monitor. If LCD has displaying no signal mean signal coming form the Video card of your CPU try to visualize if you hearing some beeps into from CPU, some motherboard has beep codes if there's an error or failure to your CPU, 1 beep means its good system test. if you don't hear any beeps, try to check first your Video Card marmeto12_21.jpg if you have Spare try to replace it, try to reset all the connectors even Memory card to its slot. reset means pull the connectors and place it back again, also check the power supply of cpu if still functioning good.but you can test it by multi volt meter. if nothing happens check your motherboard most common failure is bloating capacitor, and overheating chipset. thanks....................hope this helps...................
Sep 07, 2011 | ViewSonic VX2235wm LCD Monitor
The monitor is not displaying anything and the
Make sure the vga cable is connected to CPU and the CPU is on if it is giving the beeps then remove the ram clean it and fix it again.try with removing the cmos battery also.
Have a nice day and do not forget to rate please...!
Feb 15, 2010 | Computers & Internet
My monitor is not responding to anything. what can i do aside from rebooting?
do you see the light blinking in the monitor? I mean the POWER led light up? If so, then the monitor is ok and is working good. It is your CPU which has a problem and not sending digital signal for the monitor to display.
Try to turn off your computer. After 3 minutes turn it back on. then notice if you will hear a short beep from the CPU. That signals a successful video initialization. If you went through that process, then your computer will get back to life.
However, if you dont hear a short beep from the CPU, then definitely your CPU is frozen therefore there is nothing to display to the monitor.
You need to open the CPU case, pull out memory modules then plug them back in. Then try booting.
If not successful, try to open case and pull out the processor. Put it back in after 30 seconds. Try booting again.
Do ALL THESE while your PC is UNPLUGGED.
Good luck.
Oct 09, 2009 | Computers & Internet
Hi I just bought 7 NEC Multisync LCD1550v monitors and they all have the same problem. when plugged in all i get is a blinking power light. 1 of them showed signs of life for just a second but that was it....
You buy a new LCD Monitors, now still not working., if that new LCD Monitor is OK, then check your VGA Card, its inside the CPU maybe its broke or not connect properly inside. This are the cause of not displaying in your LCD Monitors.
If you here some beeps of your CPU then find out how many beeps and tell us here immediately.
Aug 03, 2009 | NEC-Mitsubishi MultiSync LCD2170NX (Black)...
My pc is giving continuous beep voice.
Probably some hardware defect. You could try removing unnecessary components. Of course, as a minimum, you need the CPU and memory. If you have more memory modules, you could try them one-by-one, if this is possible with the particular type you use. Please note, some motherboards / memory types require to use particular slots for particular configuration, to use modules in pairs, etc (please consult manual).
Mar 20, 2009 | eMachines D3123 Desktop Computer With AMD...
DO ANYBODY KNOWS WAT TO DO IF DISPLAY NOT APPEARS
The 280W may not be supportive enough for the computer requirements and is not diverting its power correctly to power the VGA part of the motherboard.
Jan 31, 2009 | Compaq Refurbished 280WATT POWER SUPPLY...
No beep,No Display on my monitor,only CPU heatsink fan is moving
have you thought about changing the battery on the motherboard, also checking that the fan on the cpu is seated properly with enough heatsink paste as both these issues will stop the pc from booting
Oct 29, 2008 | Asrock K7S41GX Motherboard
Going to Sleep Displayed
I turned on my computer and the monitor displayed this message on the screen "going to sleep no input received". I checked the power cord and unplugged it, nothing. No lights are flashing or beeping sounds. The CPU is working just fine, anyone have any idea what to do
Aug 02, 2008 | HP vs19 (Silver) 19" LCD Monitor
No Beep No Display
motherboard problem motherboard can't display when switch on, the cpu fan faster no beeping . I had change power supply, but same.Check the keyboard LED,Not flash.I had remove the ram but can't hear beep. PC speaker ok conferm. Monitor display tested monitor its ok . But no comming display. Can you help me? How i can solve this problem?
Jul 03, 2008 | Intel Motherboard
No Display
Be sure that your power supply is working!
If the PS is working ,Try to examine your memory . if your computer getting long beeping. means that CPU is working if not beeping something wrong with your CPU. if beeping Unplug the memory clean it and connect it back. then test the computer. if doesn't solve the problem try replace the memory.
Dec 10, 2007 | Computers & Internet
Asrock P4I45GV R5 Motherboard Logo
137 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
