Question about Eclipse XA5000 Car Audio Amplifier
Engine whine touched speaker wire to door and now have whine only when engine is running help
You're hearing whine from the alternator as it charges the battery. You could reduce it by turning the input level down on the amp, or by adjusting the filter on the high end. You can also buy a whine filter kit.
One last thing... you may have blown one of the diodes in the Alternator itself when you shorted the speaker wire. It would still work and charge the battery, but would not be able to filter the whine like it should.
Hope that helps...
Geno
Posted on Mar 26, 2008
In my wagon i have the factory fitted door speakers. Off one of the speakers there is a tail with two wires coming off it .can i just run off this to 2 extra speakers. If i can how do i do this
Your not going to hurt anything if you try it.just touch the wires of the speaker you want to add to the terminals.it will work or it wont.
Mar 12, 2017 | Cars & Trucks
There is a loud whining coming from the motor
Hi Tyler:
Try using a mechanics stethescope (or a dowel sound rod, thumb over end held against your ear) and with the engine running, touch various components. You will hear different sounds, and hopefully be able to isolate the whine.
CAUTION - Work Safe - moving bits can make the sound rod hurt you.
I'd be guessing at an alternator bearing as they whine worse than a puppy on the wrong side of a door.
Cheers
Jan 07, 2016 | 1995 Mercury Villager
I recently started to get really bad alternator whine noise from all my door speakers! it was working fine until i re-ran all the door speaker wires because my dumb cousin was using a very thin speak
hi, your problems could be many. this fault can be caused by a weak/old battery, poor quality/wrong gauge of battery B+ cable, very poor level of amp ground connection. this fault can be caused by a faulty rca output/preamp line out circuit from the head unit or crossover unit. this fault can also be caused by the antenna not being properly grounded to the vehicle chassis! best you check out you local installer if you battling with this fault.
May 22, 2012 | Pioneer Car Audio & Video
I am running rca cables to my amplifier. The little black wires that are wound with the rca cables which have looped terminals, Are they supposed to be connected to a ground?
Yes you can connect these wires to ground
this is used to prevent "Ground Loops" (un-even ground points in the system)
un-even ground points cause engine whine noise in the system and by connecting the stereo and amplifier grounds together usually resolves this issue..
So just connect one end to the same ground as the stereo and the other end to the amplifier ground location..
Hope this info helps
May 20, 2011 | Car Audio & Video
Just replaced a dead battery with a brand new one. Tried starting it and it makes a high pitch whining sound and wont start. Any suggestions of what the problem is? Does it need to sit to charge the...
The basics, your battery is used to provide power to the starter. Once the engine is running the alternator then provides current to recharge the battery and run all of your electrical components. so I would suspect the starter is not working to start the engine.
Feb 16, 2011 | Chevrolet Classic Cars & Trucks
Engine running really rough...whine sound when it isn't.
The run rough problem is due a cyl.mis firing,it becaused buy a bad plug,plug wire,coil,or even the ing.module. the servive eng.light flashing is warning you that you have a cyl.misfire that can cause damaget to your catltic converter if you continue to drive it.with may lead to why you think you have a exhaust problem,it may be colgged.
Dec 27, 2008 | 1999 Pontiac Grand Prix
Eclipse XA5000 Car Audio Amplifier Logo
101 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
