Question about Bosch Classixx WFL 2066 Front Load Washer
Washing machine does not drain so there is a dirty water stuck in the machine .it is a bosch washing machine
    Genius:
  • 1,044 Answers
Please check the outlet pipe connection. See that the pipe is not bent or twisted. Also remove the outlet pipe and check the outlet opening. See that it is not blocked because of dirt or may be a piece of cloth is stuck in the outlet opening. Clean it.
Posted on May 03, 2010
How do i drain the water from my bosch nexxt front loading washing machine to remove the pump filter
I believe if you can get to it, put the hose end lower than your tub and it should drain. My front loader quit pumping and it was two quarters stuck in the pump.
Jan 02, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch classix water won't drain
check for blockages in the outlet pipes, filter and pump.
Dec 30, 2012 | Bosch Classixx WFL 2066 Front Load Washer
Bosch WFLI2440GB/5 Washing Machine drain pump running continuously
Bosch WFLI2440GB/5 Washing Machine This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Nov 08, 2011 | Washing Machines
I have a bosch washer machine which has got a bras wire stuck in the drum i think.When i run the washer now water is coming out from under the machine.
possibility of such a bra wire stuck in the drain valve or drain hose, you can check, ranging from filter sewage water to the drain valve (with drain motor). you should open the drain valve / motor assembly. wire bra might clog there. so that the rubber water valve does not close properly
Aug 05, 2010 | Bosch Washing Machines
The door on my Bosch washing machine 1605 is stuck on shut
Hiya,
the door not opening is normally a sign that there is still water inside if you can try a spin cycle or if you have a drain option try using that & if it was the water then the switch will trip & you should be able to open the door again.
Hope this helps
Apr 21, 2010 | Washing Machines
My bosch classixx 1400 express washing machine has become very noisy when draining water, it never used to be. Any ideas?
If it is only noisy when draining the water, then could be something stuck in pump.
There should be a filter located at the bottom front right of washer behind a cover.
Unscrew anti-clockwise to remove and clean, and look inside the pump opening as well to see if anything is stuck there.
Apr 13, 2010 | Bosch Classixx WFL 2462 Front Load Washer
Washine Machine not draining
Check the following to combat this issue.
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 10, 2009 | Bosch Washing Machines
Bosch 2460 washime machine. washed, will not drain r spin
i think thew buzz you hear maybe something stuck in the pump impellor. remove filter and check
Jul 23, 2008 | Bosch Logixx WFT 2806 Front Load...
Bosch WET2820 integrated washing machine. Cycle gets stuck on "anti-crease 1". Have followed instructions in manual for unblocking drain pipe, hose and suds pump although problem (doesn't drain...
was a hair clip stuck in the drain pump..
fixed like this:
Use the small draining pipe that is fitted to the filter housing to drain the water down.
Take the filter out from front bottom.
Inspect and remove any debris blocking the drain pump.
et voila! working!
Jul 10, 2008 | Bosch Washing Machines
Bosch Classixx WFL 2066 Front Load Washer Logo
143 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
