Question about Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed
Motor stalls when blades are engauged - Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed
    Guru:
  • 351 Answers
You should check the blades for free rotation. with the machine off and in neutral, or disengaged, try and move the blades. You should be able to move them some. Get a mirror and use it to look under the deck to see if there is anything caught in the blades or in the way of the belt. An obstruction here in the deck would stall the engine.
Posted on May 03, 2010
I have installed a new blade in my circular saw R32021 and the blade stalls even before I begin to cut wood
by stalling do you mean that the blade stops spinning or the motor stops turning
if the blade stops spinning then the mounting bolt for the blade is not tight enough
if the motor stops spinning , junk it and get a new unit
Jan 20, 2017 | Blade Saws
We have a Haco press brake ATS650. The machine is operational but the blade will not move down ?
this sounds as if one of the safety switches are not being engauged correctly (, main motor runs, but arbor wont engauge piviot arm to move down , solinoids not being told to stick it's arm out to catch fly wheel ,due to safety switch not allowing it too
Feb 23, 2015 | Garden
Craftsman Self Propelled lawnmower will not allow me to pull starter cord out. Why? Very new mower 917.370433. Has oil and gas in it.
is your self porpelled engauged is your blade break dis engauged take the plug out can you turn blade by hand did you hit something check to see if blade is bent let me no what happens
Aug 31, 2014 | Garden
HAVE LTX1000 GOLD IN COLAR blades will not engauge cable to engauge is broke .WHERE CAN I GET CABLE MODEL NUMBER IS WORE OFF?
You can try this model # 917.272440 and go the Sears Parts Direct http://www.searspartsdirect.com
If you are from the US you can get it directly from sears. Here is the part # for the cable 175067
Jun 25, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Cannot have blades engauged when in reverse mower stalls
You are right, the mower has a disconnect for the pto when you try to mow in reverse. You need to turn the key to the mow in reverse position, and now you can mow going backwards.
Hope this helps, Matt
Dec 11, 2010 | Toro LX466 22HP Lawn Tractor 13RT61RH244
Craftsman 18hp riding mower runs & stalls when engage the blades
motor off= deck engaed turn blade should turn motor and belt fairly easy, NO remove the belt from the motor pulley with deck engaged blades should turn freely.
most decks have breaks on the pullies so if the deck is not engaged the break will be on
May 27, 2017 | Craftsman Garden
Blade won't stay engauged
It is very hard to say without knowing model, but if it is a Honda Harmony than I would look towards the the cable that controls the blade engagement. If your model is equipped with a blade engagement lever most likely yours is controlled by a cable also and it only needs to be adjusted correctly. Good luck!
Oct 18, 2009 | Garden
Engins starts and runs when mowing will backfire and stall.
I am not sure what time of lawn mower this is, but if the blade is directly tied to the motor, usually the belt will just slip if not, but if this is directly connected to motor, it might have jumped timing. If this is not the case, inspect under the mower deck, and determine if there is something jamming the blades against the deck or if their is something bound around the blade, this can cause more strain on the motor, which could result in the symptoms your experiencing.
Aug 05, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mower wants to stall when blades are engaged on a Huskee 13hp 38'' cut Tecumseh engine 6 speed on the go shift
Usually when the motor stalls when blades are engaged on any mower it is the carb that needs cleaned and rebuilt. The motor isn't getting enough gas to handle the load.
Jun 23, 2009 | Garden
Blade does not turn
Disconnect the electric from the saw. Remove the throat blade cover. Bring the blade all the way up. Look for wood  caught between the blade and anything else. Finding none,remove blade. Try motor w/o blade. If it runs now,w/o the blade then the motor is likely ok . Reinstall blade. Now if it stil stalls, Replace motor.
Feb 11, 2009 | Craftsman 10" Table Saw
Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed Logo
130 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
