Question about Sun System 600 Hps Cool Grow Light System 600w Hps Garden Grow Light Systems
One of my two hps bulbs is brighter than the other one the bulbs and one of the ballast are new the other ballast is a year old
    Guru:
  • 351 Answers
Hi .. it could be the ballast .. an easy thing to do to troubleshoot this would be to swap the lamps. If the problem follows the lamp. then that is the problem. If the pronblem stays with the fixture, then I would replace the ballast in that fixture.
Posted on May 03, 2010
Can I get a brighter lamp for my 55: toshiba tv
Brighter lamp means more heat and that is not a good idea. Check the hours on the bulb that you have to see if it is old, might need to have the unit cleaned. Also the ballast might be failing etc.
Mar 04, 2017 | Toshiba Televison & Video
I have a building full of 427G lights with 12-15 that won't work, but appear to have good bulbs. What is the issue?
Florecent or the yellow HPS bulbs? If HPS you have a bad bulb, or bad ballast. May be similar issues if florecent.
Mar 05, 2015 | Lithonia Lighting Home
My ballast making a humming noise but will not light up my 600w hps bulb?? small bit of purple light in the bulb when turned on but not lighting up?? tried a 400w bulb in hood with the 6oow ballast and...
NANOLUX BALLAST 400W-1000W
NANOLUX HPS and MH electronic ballasts can be light up
E-MAIL :cly@sznumber.com
Skype:sznumberballast
May 18, 2013 | Sunlight Supply 400 Watt Hps Sunsystem I...
Just bought 4 new 1000W Super high output HPS bulbs. Only one of them is really bright. The others are about 80% by eye. The brightest one is nearest to the transformer stack but the others don't...
A ballast for a 1000 240 volt fixture will lose a small amount of output over time , but should nt be too noticeable . I suggest you take one of the dimmer bulbs and install it into the fixture that has the brightest bulb in it now . If the new bulb is now the brightest of all , then you know your other ballasts have lost some intensity . I have also seen on some bulbs depending on the gas inside the glass( ex. HPS or Metal Halide) which gives off the different color , will take a while on initial start up , to burn at full intensity . It is also possible that you were given used bulbs which would explain the 20 percent loss in intensity . Good luck
May 30, 2011 | Sunmaster 1000w Hps Grow Light Bulb 1000...
Picture flickers on Sony HDTV
Hi,It seems your ballast(board that powers light bulb) is going weak.The ballast was used to provide a lower voltage because lamp didn't use as much as brand new one. A newer one takes more voltage and when ballast doesn't provide as much power it will flicker or produce a dimmer image.I found the one for your tv here: http://www.discount-merchant.com/1091041-KDS-60A3000-p/1091041.htm?Click=48173 Good luck and God bless you!
Jan 06, 2010 | Sony KDS-60A3000 60" HDTV
400 watt grow light
ballast is weak ,or the bulb. i would never by the combo lights /use a hi pressure sodium for both vegative state and flowering.you dont necessarily need a MH..
Jan 03, 2010 | Garden
I have a 400w floralux hps not lighting up
take the balast to a shop and try a new light in it
Mar 21, 2009 | Garden
Hello...need help.. replaced 600mh bulb then
Have you tried the switch yet? The plastic switches inside some ballast boxes don't do well with the heat produced by the ballast. You can try to simply bypass the switch and hard wire the ballast to the plug to test whether or not that might be your issue. If you need a new switch, just call Sunlight Supply directly http://www.sunlightsupply.com/hort/contact.aspx they should be able to send you a replacement switch.
Feb 18, 2009 | Sunlight Supply 400 Watt Hps Sunsystem I...
400 watt HPS
The ballast may not be the problem. The problem may be the ignitor (starter). If the fixture humms, then the ballast is most likely working. Ballasts (transformers) do not go bad very often.
Oct 12, 2008 | Sunlight Supply 400 Watt Hps Sunsystem I...
Sun System 600 Hps Cool Grow Light System 600w Hps Garden Grow Light Systems Logo
257 people viewed this question
Top Sun Garden Experts
Dennis Key
Dennis Key
john h
Are you a Sun Garden Expert? Answer questions, earn points and help others
