Question about Asko W6761 Front Load Washer
Aeg 72630 update will not rinse during rinse cycle
The washing machine stops following the wash cycle. The water has been pumped out and now its in rinse mode . The machine stops .No water enters the machine. No FAULT CODE DISPLAYED.I have cleaned the drain pipe of the washing machine which was completely blocked and so the the external drain pipe too.The mode of failure is intermittent.I found that if I leave the machine for hour and restart the rinse cycle it works. On another occasion I emptied the resdual water from the emergency drain outlet and the machine worked too . Any suggestion I called Asko's 800 # and they were kind but not useful. They didn't have the "fault" error in their database. Weird. Mine is still not working correctly and I know all the lines are clear.
  • tejas57 Mar 25, 2008
    Yeah.
    When you spend the twenty bucks and no one shows up to talk...it kinda doesn't fixya...if ya know what I mean.
    Great idea...lousy execution.
  • Ian Greenland May 11, 2010
    is it an asko or an aeg
    Sergeant:
  • 351 Answers
If is an asko remove the top panel and check the triple valve for a faulty solenoid,also remove paddle from inside the drum with a screwdriver in the middle hole and pull toward you,and look inside the black sump hose to see if theres a plastic ball in the hose if so you need to remove it take of front panel/s to get access to the hose.also check for coins in the hoses acting like a valve.let me know and i will think of somthing else
Posted on Mar 26, 2008
How do I fix washing machine to finish emptying during rinse and spin cycle?
Long shot, but does it fill the same as when new? I would check the atmospheric switch which is a hollow tube that runs down the inside of the drum(not in the wash cage) when the water fills, It pushes air up to stop the fill. It may have gotten clogged. Or partially clogged.
Mar 28, 2016 | Fisher and Paykel Washing Machines
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
Aeg 72630 update
Press first left up button and first left down button simultaneously
( during the execution of the washing programme ) for at least 2 seconds: the LED switch off and then display the sequence of flashes indicating the alarm.
The alarm sequence is displayed for the time in which the buttons are hold down.
When you read the alarm code,we will be able assume what may be faulty.
Dado
Aug 31, 2014 | AEG Washing Machines
I have been getting the Sd code and then F21 code during regular wash. I followed directions cleaning out white filter on bottom of machine and it did not help. So I followed directions for resetting the...
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
need to replace the part but dont try it if you dont have idea how to do.
call the technician for your safety and not to waste money.
Oct 30, 2013 | Whirlpool Duet GHW9150P Front Load Washer
My 12 year old AEG OKO LAVAMAT is making a grinding sound when it fills. It's fine at all other times. I've tried cleaning out the filter, and running it empty.
This is usually caused by the recycling pump running empty whilst the washing is still soaking up the initial fill water. as the water begins to soak the clothes it then starts to pass through the drum into the pump and the whole thing quietens down. running empty will not work. to test this theory try opening the drawer very slightly and filling it manually with a hose before starting the machine, (ONLY TO THE NORMAL LEVEL) and see if the noise is still as bad.
Feb 09, 2013 | AEG Washing Machines
Hi, I have an AEG 72630 Update machine, its been very noisy for a while on spin cycle but now is making a rattling noise & is leaving black spots on clothes, could it be bearings??
Yes this is the bearings, they have completely collapsed and the oil is leaking out onto your clothes. You will need a new tub rear and that is around £120 plus labour. Sorry its not better news.
Mar 07, 2011 | AEG Washing Machines
AEG Lavamat 76400 during spin cycle blows a fuse
its not the heat element its the water pump i would say it has gone to ground try disconnecting the water pump if the fuse does not trip then replace the water pump
Jul 03, 2010 | Washing Machines
Have Aeg 72630 stopping problem
When it sticks, is the tub empty of water? If so then you may need to change the cold water solonoid just inside machine where fill vaulves are fitted. good luck hope this works
Feb 12, 2010 | AEG Lavamat 72640 Front Load Washer
If the drain lines were plugged, there may have been enough pressure on the pump to fault out. Make sure the sewer line is completely open, as well as the lines at the pump.
Jan 14, 2008 | Washing Machines
Asko W6761 Front Load Washer Logo
264 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
