Question about Answer Carbon Expert BMX Handlebar
Thermodynamis system what is thermodynamis system
    Genius:
  • 1,416 Answers
Hello.
In , thermodynamic a thermodynamic system, originally called a working subtance a, is defined as that part of the universe that is under consideration.
And anything under consideration is called a system.
A hypothetical boundary separates the system from the rest of the universe, which is referred to as the environment, surroundings, or reservoir.
A useful classification of thermodynamic systems is based on the nature of the boundary and the quantities flowing through it, such as matter, energy, work, heat, and entropy.
while a system can be anything, for example a piston, a solution in a test tube, a living orgainsm, an electrical circuit, a planet, etc.
And it can also be explain as a
Branch of physics which deals with the energy and work of a system.
Thanks for using fixya.
Posted on May 03, 2010
System restore for systemx s51g23013ga3th0
System Restore or System Recovery?
System Restore does not delete your data.
System Recovery deletes everything and sets your system back to when you first purchased it.
To launch System Restore you can:
Windows XP - Click Start/Programs/Accesstories/System Tools/System Restore
Windows Vista - Click Start/Programs/Accessories/System Tools/System Restore
Windows 7 - Click Start then in the search box type "System Restore" (without the quotes) and the system will show you the link to click above in the search results.
For System Recovery - RTM - Read The Manual
Get onlineand got to www.google.com In the google search box type: "AcerSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Look for Manuals. Search the manuals for how to start the Recovery.
May 06, 2012 | Computers & Internet
Ibm 8215 beep codes
Here is a list of beep codes, this may help determine the problem wit your system.
1. Keyboard
2. System Board1-4-X Error detected in first 64 KB of RAM.1. Memory Module
2. System Board2-1-1, 2-1-21. Run Setup
2. System Board2-1-X First 64 KB of RAM failed.1. Memory Module
2. System Board2-2-21. Video Adapter (if installed)
2. System Board2-2-X First 64 KB of RAM failed.1. Memory Module
2. System Board2-3-X1. Memory Module
2. System Board2-4-X1. Run Setup
2. Memory Module
3. System Board3-1-X DMA register failed.1. System Board3-2-4 Keyboard controller failed.1. System Board
2. Keyboard3-3-4 Screen initialization failed.1. Video Adapter (if installed)
2. System Board
3. Display3-4-1 Screen retrace lest detected an error.1. Video Adapter (if installed)
2. System Board
3. Display3-4-2 POST is searching for video ROM.1. Video Adapter (if installed)
2. System Board41. Video Adapter (if installed)
2. System BoardAll other beep code sequences.1. System BoardOne long and one short beep during POST. Base 640 KB memory error or shadow RAM error.1. Memory Module
2. System BoardOne long beep and two or three short beeps during POST.(Video error)1. Video Adapter (if installed)
2. System BoardThree short beeps during POST.1. See "System board memory" on page 62.
2. System BoardContinuous beep.1. System BoardRepeating short beeps.1. Keyboard stuck key?
2. Keyboard Cable
3. System Board
Nov 29, 2011 | IBM ThinkCentre M52 8215 - P4 531 3 GHz...
Shut down
Possible corrupt operating system. The cause of corrupt operating system is Windows file corrupted or virus infected Windows.
Solution corrupt Windows files:
1. START - All Programs - Accessories - System Tools - System Recovery Options - System Restore (restore to the date when the OS is still normal)
2. START - All Programs - Accessories - System Tools - System Recovery Options - System Image Recovery (restore using a backup system that you created)
Solution files corrupted due to virus infected windows
Update anti-virus and virus scan (if the virus is detected, the primary action = repair, secondary action = quarantine). Then repair the operating system with System Restore or System Recovery Options.
Note:
If the operating system infected with virus (virus infected not long ago), the best solution is to use System Restore. Restore to a date when the windows are still normal.
Nov 13, 2011 | Toshiba Computers & Internet
What does po440 on a 2003 saturn vue mean with a service engine soon light on
That is a problem in the evaporative emission control system.
Could be anything causing it
Clogged filter in the charcoal canister
A leak in one of the vacuum lines
The purge valve not working,,,etc.
The best thing is to take it and have it checked out, they might have to do a smoke test to find the problem.
All they do is inject smoke into the system, if there is a leak the smoke will come out of it. All it takes is a pin hole in these emission systems to screw it all up.
Aug 13, 2010 | 2003 Saturn VUE
I checked the codes and one comes up its po446. i dont under stand what it mean so i cant fix it to get the light to go out.
P0446 Evaporative Emission System Vent Control Circuit.
The following are descriptions of all Evaporative possible codes:
P0441 Evaporative Emission System Incorrect Purge Flow
P0442 Evaporative Emission System Leak Detected (small leak)
P0443 Evaporative Emission System Purge Control Valve Circuit
P0444 Evaporative Emission System Purge Control Valve Circuit Open
P0445 Evaporative Emission System Purge Control Valve Circuit Shorted
P0447 Evaporative Emission System Vent Control Circuit Open
P0448 Evaporative Emission System Vent Control Circuit Shorted
P0449 Evaporative Emission System Vent Valve/Solenoid Circuit
P0450 Evaporative Emission System Pressure Sensor/Switch
P0451 Evaporative Emission System Pressure Sensor/Switch Range/Performance
P0452 Evaporative Emission System Pressure Sensor/Switch Low
P0453 Evaporative Emission System Pressure Sensor/Switch High
P0454 Evaporative Emission System Pressure Sensor/Switch Intermittent
P0455 Evaporative Emission System Leak Detected (large leak)
P0456 Evaporative Emission System Leak Detected (very small leak)
P0457 Evaporative Emission System Leak Detected (fuel cap loose/off)
P0458 Evaporative Emission System Purge Control Valve Circuit Low
P0459 Evaporative Emission System Purge Control Valve Circuit High
At least the cap isn't loose for the gas tank.
I would clear the code with an OBD-II Scanner 'erase code' button, and see how long it takes for it to come back.
Aug 06, 2010 | 1996 GMC Jimmy
I'm trying to install a c4380 wireless printer with windows 7 but it won't take, says it's not supported by software
  1. First find out if you are using 32 or 64 bit
  2. Click Start
Collapse this imageExpand this image vistastartbutton.jpg , type system in the Start Search box, and then click system in the Programs list.
  1. The operating system is displayed as follows:
    • For a 64-bit version operating system: 64-bit Operating System appears for the System type under System.
    • For a 32-bit version operating system: 32-bit Operating System appears for the System type under System.
Method 2: View System Information window loadTOCNode(4, 'moreinformation');
  1. Click Start Collapse this imageExpand this image vistastartbutton.jpg, type system in the Start Search box, and then click System Information in the Programs list.
  2. When System Summary is selected in the navigation pane, the operating system is displayed as follows:
    • For a 64-bit version operating system: x64-based PC appears for the System type under Item.
    • For a 32-bit version operating system: x86-based PC appears for the System type under Item.
  3. Then go to hp website and download driver for windows 7 for correct bit version.
  4. Unistall old driver install new.
Nov 28, 2009 | Xerox DocuColor 12 Printer
Be.tmp.exe application error. the instruction at "0x0040c173" referenced memory at "0x0040c173". the memory could not be read
This should all be done in safe mode and with system restore turned off for now.
This is a virus and You need to run your antivirus scan and remove what it finds,Run a cleaner program such as Ccleaner
Hit Ctrl+Alt+Delete and open the task manager,Under the process tab find and end task on tmp.exe and/or BE.tmp.exe.
It is a process belonging to an advertising program by 123bar. This process monitors your browsing habits and distributes the data back to the author's servers for analysis. This also prompts advertising popups. This process is a security risk and should be removed from your system.
%FontsDir%\nwlnkfwd.exe %FontsDir%\nwlnkipx.exe %FontsDir%\nwlnknb.exe %FontsDir%\nwlnkspx.exe %FontsDir%\nwrdr.exe %FontsDir%\oprghdlr.exe %FontsDir%\p3.exe %ProgramFiles%\internet explorer\keymaker.exe %ProgramFiles%\outlook express\keymaker.exe %System%\1025\zipfldr.exe %System%\1028\zipfldr.exe %System%\1028myztx.exe %System%\1031\zipfldr.exe %System%\1033\zipfldr.exe %System%\1037\zipfldr.exe %System%\1041\zipfldr.exe %System%\1042\zipfldr.exe %System%\1054\zipfldr.exe %System%\2052\zipfldr.exe %System%\3076\zipfldr.exe %System%\3com_dmi\edb.exe %System%\3com_dmi\edb0000a.exe %System%\3com_dmi\edb0000b.exe %System%\3com_dmi\edb0000c.exe %System%\3com_dmi\edb0000d.exe %System%\3com_dmi\edb0000e.exe %System%\3com_dmi\zipfldr.exe %System%\catroot\zipfldr.exe %System%\catroot2\{127d0a1d-4ef2-11d1-8608-00c04fc295ee}\tmp.exe %System%\catroot2\{f750e6c3-38ee-11d1-85e5-00c04fc295ee}\tmp.exe %System%\catroot2\tmp.exe %System%\catroot2\zipfldr.exe %System%\com\zipfldr.exe %System%\dhcp\zipfldr.exe %System%\directx\zipfldr.exe %System%\dllcache\zipfldr.exe %System%\drivers\disdn\ws2ifsl.exe %System%\drivers\etc\atmlane.com %System%\drivers\etc\atmuni.com %System%\drivers\etc\audstub.com %System%\drivers\etc\battc.com %System%\drivers\etc\beep.com %System%\drivers\etc\bridge.com %System%\drivers\etc\cbidf2k.com %System%\drivers\etc\ws2ifsl.exe %System%\drivers\ws2ifsl.exe %System%\drivers\zipfldr.exe %System%\export\zipfldr.exe %System%\grouppolicy\adm\gpt.exe %System%\grouppolicy\gpt.exe %System%\grouppolicy\machine\gpt.exe %System%\grouppolicy\user\gpt.exe %System%\grouppolicy\zipfldr.exe %System%\ias\zipfldr.exe %System%\icsxml\zipfldr.exe %System%\ime\zipfldr.exe %System%\inetsrv\zipfldr.exe %System%\keymaker.exe %System%\macromed\comadmin.exe %System%\macromed\comempty.exe %System%\macromed\comexp.exe %System%\macromed\edb00017.exe %System%\macromed\res1.exe %System%\macromed\res2.exe %System%\macromed\tmp.exe %System%\macromed\zipfldr.exe %System%\microsoft\zipfldr.exe %System%\msdtc\msdtc.exe %System%\msdtc\trace\msdtc.exe %System%\msdtc\zipfldr.exe %System%\mui\0418\ftdisk.exe %System%\mui\0418\gm.exe %System%\mui\0418\gmreadme.exe %System%\mui\0418\hgfs.exe %System%\mui\0418\http.exe %System%\mui\0418\i8042prt.exe %System%\mui\0418\imapi.exe %System%\schost.exe %System%\services32.exe %System%\spool\drivers\w32x86\3\mouclass.sys %System%\spool\drivers\w32x86\3\mountmgr.sys %System%\spool\drivers\w32x86\3\mqac.sys %System%\spool\drivers\w32x86\3\mrxdav.sys %System%\spool\drivers\w32x86\3\mrxsmb.sys %System%\spool\drivers\w32x86\3\msfs.sys %System%\spool\drivers\w32x86\3\msgpc.sys %System%\syskey_dll\sysupdate.exe %System%\system\system.exe %System%\tmp.exe %Temp%\5.exe %Temp%\70554keygen1.exe %Temp%\guqf296\keymaker.exe %Temp%\ixp000.tmp\efubtgis.exe %Temp%\ixp000.tmp\key_gen.exe %Temp%\ixp000.tmp\keygen.exe %Temp%\ixp000.tmp\keymaker.exe %Temp%\ixp000.tmp\tmp.exe %Temp%\ixp000.tmp\tvonuaek.exe %Temp%\ixp000.tmp\zwwltphz.exe %Temp%\ixp001.tmp\keymaker.exe
You should also download and run Spybot search and destroy and delete what it finds.
If
May 21, 2009 | HP Compaq Presario V3000T Notebook
Design a Menu-driven interactive programme to find out all the Capital cities of India using switch statement
import java.io.*;
public class capital
public static void main(String args[]) throws Exception
System.out.println("Enter 1 for Andra Pradesh");
System.out.println("Enter 2 for Arunachal Pradesh.");
System.out.println("Enter 3 for Assam.");
System.out.println("Enter 4 for Bihar.");
System.out.println("Enter 5 for Chhattisgarh.");
System.out.println("Enter 6 for Goa.");
System.out.println("Enter 7 for Karnataka.");
System.out.println("Enter 8 for Gujrat.");
System.out.println("Enter 9 for Haryana.");
System.out.println("Enter 10 for Himachal Pradesh.");
System.out.println("Enter 11 for Mizoram.");
System.out.println("Enter 12 for Jammu & Kashmir.");
System.out.println("Enter 13 for Jharkhand.");
System.out.println("Enter 14 for Kerala.");
System.out.println("Enter 15 for Madhya Pradesh.");
System.out.println("Enter 16 for Maharashtra.");
System.out.println("Enter 17 for Manipur.");
System.out.println("Enter 18 for Meghalaya.");
System.out.println("Enter 19 for Nagaland.");
System.out.println("Enter 20 for Orissa.");
System.out.println("Enter 21 for Punjab.");
System.out.println("Enter 22 for Rajasthan.");
System.out.println("Enter 23 for Sikkim.");
System.out.println("Enter 24 for Tamil Nadu.");
System.out.println("Enter 25 for Tripura.");
System.out.println("Enter 26 for Uttar Pradesh.");
System.out.println("Enter 27 for Uttaranchal.");
BufferedReader br = new BufferedReader(new InputStreamReader(System.in));
String read = br.readLine();
int ch = Integer.parseInt(read);
switch(ch)
case 1: System.out.println("Hyderabad");
break;
case 2: System.out.println("Itanager");
break;
case 3: System.out.println("Dispur");
break;
case 4: System.out.println("Patna");
break;
case 5: System.out.println("Raipur");
break;
case 6: System.out.println("Panaji");
break;
case 7: System.out.println("Bangalore");
break;
case 8: System.out.println("Gandhinagar");
break;
case 9: System.out.println("Chandigarh");
break;
case 10: System.out.println("Shimla");
break;
case 11: System.out.println("Aizawl");
break;
case 12: System.out.println("Srinagar(Summer) & Jammu(Winter)");
break;
case 13: System.out.println("Ranchi");
break;
case 14: System.out.println("Trivandrum");
break;
case 15: System.out.println("Bhopal");
break;
case 16: System.out.println("Bombay");
break;
case 17: System.out.println("Imphal");
break;
case 18: System.out.println("Shillong");
break;
case 19: System.out.println("Kohima");
break;
case 20: System.out.println("Bhubaneswar");
break;
case 21: System.out.println("chandigarh");
break;
case 22: System.out.println("Jaipur");
break;
case 23: System.out.println("Gangtok");
break;
case 24: System.out.println("Chennai");
break;
case 25: System.out.println("Agartala");
break;
case 26: System.out.println("Lucknow");
break;
case 27: System.out.println("Dehra Dun");
break;
default: System.out.println("Invalid entry!");
break;
(IGNOU - BCA - CS-74 - Q.4 - 2009)
Visit : Www.hamidraza.page.tl
Apr 13, 2009 | Computers & Internet
I would like to restore my system. i do not know how to start it
click on start, all programs, accessories, system tools, system restore,
once u open system restore, click on next, select a date to which u want to restore the system and click on finish, system restore will happen and system will restart, if successful it would show the msg system restore successful
Nov 14, 2008 | Gateway Computers & Internet
Answer Carbon Expert BMX Handlebar Logo
144 people viewed this question
Top Answer Cycling Experts
Indermani Tiwari
Bill Boyd
Donald Ayers-Marsh
Are you an Answer Cycling Expert? Answer questions, earn points and help others
