Question about Acer AL2671W 26 in. LCD Television
Blue screen in RGB2 & VGA input modes...
When I change input modes to RGB2 to watch a DVD I now get a blue screen ( I can still see the picture but all colour has gone except Blue). I've also noticed the same If I hook up my PC and use VGA.
The other modes are fine, this just happened without me changing any menu options etc.
  • 3,037 Answers
Sounds like a defective tv.
First try a different set of cables, if the problem persists, then contact Acer
Acer Contact Information Main support number 408.432.6200 or 1.800.733.2237
This same thing has happened to other LCD tvs if it is not the cables which it sounds like it isn't, though I have not seen this model do it before
Hope this helps, let me know if you need anything else
Have a good day
Posted on Mar 25, 2008
    Sergeant:
  • 317 Answers
Check your cable connection..
SOURCE:
When tv is turned on, screen shows white w/ blue logo, then shows "VGA" and "no signal" on a blue screen. After a minute it turns off. We cannot get a picture. We have a Time Warner...
Right now the TV is set to accept the video signal from PC through the VGA port so when it does not see the video signal from the VGA port, the TV will go into shutdown or standby mode. You need to change the input to be where the cable box is connected to using INPUT or SOURCE button on the remote.
What kind of connection are you using to make the connection between the TV and the cable box?
Please clarify. Make and model of the TV?
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Aug 19, 2011 | Televison & Video
I dont have cable.i was using this tv just to play dvds and i accidentally hit channel search. now i get a blue screen that says" plerase connect cable system or an antenna to the terminal on the back...
Hi:
Using remote locate a button called tv/video or Input, turn on the DVD player and hit this button until you see your DVD player Logo. Most dvd players use either video 1 or 2, or componet or HDMI outputs. Seems you have changed the TV's input back to TV mode and you need to change it to a video mode input.
May 17, 2011 | Televison & Video
How to connect Blu ray disc player with my Bose 321 system. I have 1080 p samsung LCD TV. How to get the best.
hi,
do the following.
1. connect ur blue rays hdmi out to ur tvs hdmi input.
2. connct blue rays out to any one of the coaxial(aux) input of bose.
3. connect ur tvs optical audio output to optical audio input of bose
4. connect monitor out of ur bose to any one of ur av in of ur tv. connect component video to better quality .
4 . in the blue rays audio setup select audio output priority as optical/coaxial
5 . in bose set aux as digital input.
to see blue ray select hdmi of ur tv, sellect in bose in which the blue rays coaxial is connected(aux) insert disk in blue ray an watch
to see dvd in bose select tvs corresponding input, select bose to dvd . insert dvd and watch
to whach tv program set tv to corresponding mode. set bose to optical audio input mode.
ok
Dec 15, 2010 | Televison & Video
My projector does not show any picture,only show blue screen, does the lamp need replacement an if it does how it will cost
If you are seeing the blue screen at startup, then the issue is more than likely not the lamp. What is your input source and what inputs are you connecting to?
If you are using a laptop PC, note that the VGA output by default is not active. You have to go into display settings and change it to dual monitor for VGA output to work.
Oct 05, 2010 | Hitachi CPS210LAMP Projector Lamp
No video on our tv
I found in the manual on page 13 bottom, that if you PRESS STOP buttom for 5 seconds of your remote controller then you can see the picture on the interlaced mode again on your TV.
Otherwise you have to connect you DVD to a unit that has progresiv scan, such as an HDTV, some computers if they have an input or to a projector .
I connected my DVD to a projector thru the VIDEO output and put eveything back to normal, and it is working fine now.
System Reset
Open CD disk tray. Press stop key and hold for 15 seconds, screen will appear.
Apr 01, 2009 | Akai DVPS760 DVD Player
Tv screen has turned blue and I can't watch tv
i think by accident you have changed the input when you went to change the volume. look for a button labeled " input" or "video" select on the remote and scroll through the various choices. you should get your picture back.
Jan 21, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
When connecting my Blue Ray DVD Player (Panasonic DMP-BD35) to my JVC TV (LT-37DS6BJ) I get large black bars at the top & bottom of the screen despite changing the aspect ratio on the DVD. The TV...
It all depends on the dvd that you are watching you cant change it to anything bigger than what is was recorded.
You will have to just watch it like it is. I have the same thing with my dvd player its really thin picture its annoying
Dec 04, 2008 | JVC Televison & Video
Blue screen?!
im not sure what that button is for i think pan and scan but anyway try holding the power button down for several seconds to rebut the player hopfully this works let me know if not and well try something else
Sep 21, 2008 | Insignia Televison & Video
Blue tint to picture
cheak projecter mode your in under hdmi mode blue cool settings on hi ? eash input setup is differt use warm colers not cool 1 2 3 so on u know what i mean sum sterio have hard time with hdmi out to dvi might wann use coumpuont out from reciver to 15 pin vga sum projecter in 720 p mode have gard time 1080i so on u relly need dvi out from setrio to dvi more less for monister cable best use compunt cable projecter only 16 millon colers anyays ok not 529 billon like samsung plmasa would be were u would wann use hdmi to get all those colers but coumpunt is more then worthy wiyth projecters output ok
Jan 23, 2008 | Onkyo TX-SR674S 7.1 Channel Up-Converting...
Acer AL2671W 26 in. LCD Television Logo
111 people viewed this question
Top Acer Televison & Video Experts
Eric Rotmil
Eric Rotmil
Siul Oyaratgam
Jaime Hernandez
Are you an Acer Televison and Video Expert? Answer questions, earn points and help others
