Question about Sun - XVR-100 Graphic Card
New SUN fire v210 server with XVR-100 graphics card. when power on No display on monitors. However sever is booted properly. No error indication. HELP
What does Media boot failure on a sun server v210 mean
Either the hard dive with the OS is defective and should be replaced or the boot ROM is no good and needs to be replaced.
Feb 11, 2014 | Sun Microsystems SUN V210 Server 2x1.34GHz...
Cannot Display From Monitor
How long have you waited for it to boot? I know some servers take forever before they send a signal to the monitor. However, if you're get the monitor test screen or "no signal" screen, this usually is a sign that the monitor is not getting any signal from the server, indicating a bad cable or loose connection or the like (though not always if it's still booting). Have you looked in the server cabinet to make sure nothing is broke on the on-board connection or something? Is the DVI port you mentioned on the external PCI card? What does it plug into? I'm guessing you've checked for any installed video cards. Is there another port on the front or anything under a panel?
Nov 27, 2013 | Sun Fire V40z Server
Boot device
I think you have erased the required system.. what is the message that displayed ??
Aug 17, 2013 | Sun Fire V210 Server
How to check pci sun xvr-500 graphics card work properly in sun blade 1500 at solaris 5.8 and what is the name of its packges and patch
Want to make sure your drivers are in place and no errors have occurred? Simply click start right click on my computer select properties then select device manager scroll to Display Adapters and click on the small "+" you should see the model of your PCI Express graphic card there. If there is a problem with it, a yellow exclamation mark should appear besides it. If you don't see it everything is OK and your card is working properly.
If your computer came with a motherboard disc the drivers could be on it
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question exclamation mark ? mark ! or a red x right click select reinstall drivers if you don't have a disk with the drivers you have to download them
http://download.cnet.com/matrox-millennium-ii-agp/3000-2108_4-10028803.html
http://download.cnet.com/jetway-motherboard-driver/3000-2098_4-163033.html
Aug 31, 2011 | Sun XVR-500 PCI Graphic Card
I need the driver of Sun XVR 500 Graphics Accelerator Card.
http://download.cnet.com/intel-graphics-media-accelerator/3000-2108_4-10300119.html
if this driver is not right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
(be precise)also the download software finder under that there will be a list place a tick in the box of any one you want/need
all software windows software mac software mobile and web apps
http://majorgeeks.com/downloads35.html
also this link will provide you with many freeware and share drivers
hope this helps you
Aug 23, 2011 | Sun XVR-500 Graphics Accelerator (p/n...
Sun fire v120 Server Scc Not Detected System is not Booting
may be it was relax
just touch it servel times,you will see the info
SCC inserted
SCC been moved
or something like that
and then just let it be the state of "scc inserted
Mar 17, 2009 | Sun Fire V120 Server
Analog output works fine, but no signal for digital output
is ther option on screen it self dvi mode and anlog mode .
Jan 24, 2008 | Sun - XVR-100 Graphic Card
SunFire V240 using XVR-100 graphics card
may be the graphics card has fitted correctly on the slot inside try reinserting once....
or
may be this is due magnetic field appliances like speakers are very near 2 monitor so keep some distance from monitor and then on monitor press menu button and give degauss....
if still problem problem persists then may be there is some conflict with the driver so try uninstalling it and then installing it again...
or else may be there monitor problem ... just have check with connecting another monitor
Oct 25, 2007 | Sun XVR 100 (32 MB) Graphic Card
Problem with Xsun hang in Sun Blade 100 servers
hi navinsoni,
just reinstall os when u have insert ur graphic card in the slot just try it will work it would not kill user session
regards
shailesh
Oct 10, 2007 | Creative Labs Riva TNT2 M64 Graphic Card
Computers & Internet Logo
136 people viewed this question
Top Sun Computers & Internet Experts
Cosma Papouis
Cosma Papouis
Robin Hill
Robin Hill
Are you a Sun Computer and Internet Expert? Answer questions, earn points and help others
