Question about Sony Cyber-shot DSC-W170 Digital Camera
I have a Sony DSC-W170 and when I turn it on it powers fine and the lense opens, then shuts and opens a few times then stays open and tells me to 'turn the power off and on again'. I have done this and it doesn't solve the problem the same thing just happens again and again. I would'nt mind but it was fine then just stopped working, please help.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Feb 11, 2011
Canon cybershot
It's not the memory card. Try the procedures in this tip.
Aug 13, 2012 | Sony Cyber-shot DSC-W170 Digital Camera
Sony cybershot DSC-W170 lens malfunction
sounds like you have dust, sand of some type stuck in the retracting lense. Ive found someone to tell me to take out my batterys and SD card, then tap the bottom of the camera on a table top. Replace the batteries and power up. Doing this, I was told it loosens up the debri for the lense to retract to close and to open again.
Aug 24, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Same Problem!!!!!
CCD FAILURE
Call Sony for FREE REPAIRS
they know abt it
pls rate me well
Aug 10, 2009 | Sony Cyber-shot DSC-W170 Digital Camera
Hello pleasehelp me.. i have sony cybershot
Hi!
It's probably stuck focus. Contact your local Sony service center, but if they ask too much, you can contact me at toms.safranovs@gmail.com and I will give you a good price.
I work in Sony service center.
Tom
Jul 16, 2009 | Sony Cyber-shot DSC-W170 Digital Camera
My Sony Cyber-Shot DSC-W55 camera does not turn on properly. When I press the gallery button, everything runs smoothly. When I press the on button, the lens opens and closes several times, making a little...
Hi. I had exactly the same problem with my Sony Cyber-Shot DSC-W7. The problem started after while lense was fully open, the battery became 100% empty. I did not have access to new batteries and did not have my charger with me so I put the camera on my car seat and went home. After charging the batteries, I turned the camera Off and the lense retracted 100%. Later on I tried to transfer some pictures to my PC. After connecting the camera to my PC with the dial in the P position and lense fully open I turned the dial to play in order to transfer photos. After transferring the pictures, I turned the camera off and disconnected from the computer.
I turn the camera on to take new pictures next day, The lense would go up, and and turn with lense fully open. It would never close. The screen was black with a message "Turn the camera on and off again". I tried 30 times or more and the same thing would happen again.
Here is what I did to fix my camera and it has been working normally since then.
1- I cleaned around the outside of the lense with lent free cloth
2- I used dust OFF to get raid of the remaining small dust particles from around the lense.
3- While turning the camera off, I pushed (down, up and turn) the lense in (NOT TOO Hard) by my hand. If you push the lense too hard, you may damage the mechanicall moving parts of the lense.
4- After a few tries, the lense retracted 90% +. I then pushed the lense a little harder all the way in, the way it normall retracts. The lense cover also closed 100%.
5- I turned the Camera on and off a few times. It was opening and closing exactly the way it used to. My Cybershot has been working okay since then.
I read a lot and here is what cause my lense to malfunction.
While lense was fully open and battery died, some small particles got on the lense and prevented lense from fully opening or closing.
In summery: two things could have caused your camera lense to malfunction.
1- if you had dropped your camera hard, some mechanical parts may have got damaged or dislocated. In this case you have to open the lense and replace the damaged part, clean and put it back on the camera. This is too risky for most ordinary people. You would most likely make it WORST.
2- If you did not drop it, most likly, some how some small dust particles got on the outside of the lense and they prevent the lense or the lense cover from fully opening and closing. If this is your case, please follow exactly what I did and your camera would be back to normal.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 25, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
I have a sony DSC-W170. It was dropped and now
I had exactly the same problem with my Sony Cyber_Shot. Here is what I did and the problem was fixed. I cleaned around the lense. While I turned the camera off, I pressed down the lense very softly (some up and down motion). After a couple of times, the lense retracted almost completely. Then I pressed a little harder until the lense retracted 100% as normal times. I turned it on everything was back to normal. If the lense does not have mechanical problem, you should be able to do what I did.
If there is no mechanical problem, most likly some dirt got on the sides of the lense while it was open. Try keep it very clean always.
Good luck;
Jun 15, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
I do have the same problem
You can tell Sony and maybe they can fix it.
Jun 07, 2009 | Sony Cyber-shot DSC-W170 Digital Camera
Sony cyber shot dsc-n2
There could be two things causing this problem.
1- some dirt somehow got on the outside of side of the lense. So the lense could not fully retract or open out. As a result you can take any picture. If the lense comes out even a little bit, try to pull it out NOT too hard a few times. If it does not retract, turn the camera off and push the lense in (up and down) NOT too hard foe a few times. If the camera opened up 100% or retracted 100%, your camera should be back to normal.
2- If you dropped the camera, some mechanical part of the lense is broken or dislocated or the cable may have come loose. In this case you need to take out the lense from the camera and inpect it for broken pieces or loose cable. clean the outside of the lense and push the lense in and out a few times. Put the lense back on and your camera would be back to normal.
Good luck!!!!!!
May 14, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
In camera or video mode it says turn the power off and on again
The problem is
1- some dirt somehow got on the outside of the lense. After it was retracted fully in, it prevents the camera from opening again. When you turn it on, if it opens a little bit, try to pull it out NOT too hard and let go a few times. If it opened, clear the outside of the lense. Your camera should be back to normal.
If the lense does not retract, but goes up and down when you turn it on or off, Clean the sides of the lense and while turning the camera off push the lense in NOT too hard for a few times. If it retrected 100% or most of the way inn, push the in a little harder untill it is 100% retracted in. Now your camera should be back to normal. 2- If you droped the camera, you probably damaged or dislocated a mechanical part of the lense. You may have to take out the lense by unscrewing it and inspect it for damaged parts or disconnected cable. Make sure clean the lense and test it by moving it in and out a few times, before puting it back on the camera.
Good luck!!!!!!!
Apr 14, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
Sony Cyber-shot DSC-W170 Digital Camera Logo
71 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
