Question about Dell Latitude C640 Notebook
Battery won't recharge for latitude d620 - Dell Latitude C640 Notebook
  • joshs71 May 03, 2010
    Batteries won't charge. There are two batteries are working fine. Stopped charging before, but begin charging again when I purchased a new power chord. But now going back to same problem.
  • joshs71 May 04, 2010
    This troubleshooting still doesn't work. If there is a problem with the charging system, is there anything I can do or do I have to take it to a repair shop?
    Genius:
  • 1,354 Answers
If your computer runs normally on the AC adapter, but the battery won't charge, please try the following troubleshooting steps:
  1. Check the Battery and Connections:
    1. Remove the battery from the system.
    2. Look at the connectors in the bay and on the battery for signs of physical damage.
    3. Check the battery charge by pressing the status button or image on the battery near the LED's.
Note:
The lights indicate the current amount of charge on the battery. If all the LED's come on when you press the button, the battery is fully charged. If fewer lights are lit, then the battery is partially charged. If any lights flash, or blink, there could be a problem with the battery.
D. Consult the Tell Me How guide for more information on battery LED's:
E. Where to find the Dell Tell Me How and User's Guides
    1. Reinsert the battery; push until it locks into place and the latch snaps back to the locked position.
  1. Swap Bays or Try A Second Computer:
    • Some systems can run with the battery in either bay. Try swapping bays if you have one of these systems.
    • If you have access to a second computer like your own, try to charge your battery in that system.
  1. Flash the BIOS:
  2. Flashing the BIOS can correct many hardware issues.
  3. Run the Recalibration Utility if Your System has One:
This utility runs the battery all the way down and then recharges it completely. The process takes several hours so it is best to run it overnight. Use only the recalibration program specified for your system. Using any other program could void your warranty! Latitude LM, Inspiron 3000 and Inspiron 3200 systems use this recalibration program:
BATRECAL.EXE Inspiron 5000, Inspiron 7000, and Inspiron 7500 systems use this program:
I75BRCA0.EXE Latitude LS, Latitude L400, Latitude X200, and Inspiron 2100 enable a recalibration option on the Power page of the BIOS Setup Program:
How to Enable Battery Recalibration Try to charge a second battery like your own if possible.
    • If the second battery won't charge, the problem may be caused by the charging system in your computer.
  1. If the battery still won't charge after you have done this troubleshooting, please [Reply] to this message and be sure to include the following information:
Posted on May 03, 2010
  • frist of all just chack folowing steps
    1 tak out you bettary then try to on drect from the charger if it's woking mence you charger is working fine
    2 chack whern did u purchased your laptop if it's under warranty then contact dell service cente
    3 if your warrenty is over then tak it to the service center
  • 242 Answers
First check and see how old is the laptop and battery.
If the battery is old enough to be replaced then without delaying you must replace the batteries.
If the Laptop is not older than a year then you must open the batteries and check if there is any physical damage or not. Especially leaking problem.
At the bottom of it you will find 2-4 screws to remove where the battery is fit.
Those are the only check points for batteries.
Thanks
Jimmy
  • Jignesh Khare
    Jignesh Khare May 03, 2010
    The only problem that i see here is DEAD BATTERY. The battery that you are trying to charge must have died.
  • Jignesh Khare
    Jignesh Khare May 04, 2010
    Bingo, that is what i meant to say. Except for repair shop (purchase Battery) it will not go ahead.
    Thanks
    Jimmy
Pc booting light blinking battery
As a rule this indicates a low battery or a failing battery. If you charge it and it drains quickly, it needs replacement. When getting a new battery (power cells), fully charge it overnight and use it until it drains completely. Once it is recharged for 24 hours, the batter will obtain a memory and last longer.
Jan 03, 2014 | Dell Latitude D620 Laptop (Latitude-C620)...
Tip
Dell latitude d620 Battery
We are a professional manufacturer and distributor of all types of replacement batteries and battery chargers. Full one year warranty for every replacement battery and battery charger; Our Dell latitude d620 laptop batteries last longer per charge and will last longer overall because whenever possible we only carry name brand battery cells. Our goal is to meet or exceed the performance of your original batteries and it means that you can use our lithium ion battery to replace yours. We assure that we use only high quality parts that equal to or better than the original so you can feel good about having a positive impact on our environment when you use our Dell latitude d620 batteries. In our store you will find a right products at very competitive prices so you will save lots of money.
  • Chemistry :Li-ion
  • Voltage : 11.1V
  • Capacity :4400mAh
  • Color : Metallic Grey
  • Condition : Brand New
  • Availability : In Stock
  • List Price : £ 55.88
  • Now Price : £ 40.88
  • Dell latitude d620 Battery Description
    We focus on bringing you the best replacement Dell latitude d620 battery to our customers and hope that our customers can buy their satisfying Dell batteries, the Li-ion laptop battery on sales will be the perfect replacement to your original Notebooks. We guarantee the Dell latitude d620 battery with a full one-year warranty from the date of purchase, 30-days money back, if the battery(s) have any quality problem! If you have any question or suggestion about this Dell latitude d620 Battery,Please contact us
    on Mar 26, 2010 | Computers & Internet
    The screen of my Dell Latitude D620 laptop won't
    there should be a strip of plastic above the keyboard that has power button and it you should be able to take it off to get to the hinges.
    Aug 02, 2012 | Computers & Internet
    Hi have got a dell latitude d630 laptop and a emos battery buy cant seem to be able to pinpoint what type i need many thanks
    Under back of the laptop, you will find the service tags.
    Go to dell official site to check your laptop details:http://support.dell.com/support/topics/global.aspx/support/my_systems_info/details
    Also, if you need a replacement battery,those sites may helpful:9-cell dell LATITUDE D620 Battery http://www.battery-center.net/dell-latitude-d620-battery.html
    6-cell dell d620 battery http://www.brand-new-battery.com/dell-latitude-d620.htm
    Oct 30, 2011 | Dell Latitude D630 Notebook
    Battery light flashs orange continusly on a dell latitude d620 if i disconnect the power cord the computer shuts down
    Two possible causes for flashing Amber battery light.
    1) Your battery won't charge and needs to be replaced.
    2) Your charging circuit for the battery is defective and then your motherboard of laptop will need to be replaced.
    Oct 20, 2011 | Dell Latitude D620 Notebook
    Mine is dell latitude d620 laptop.battery is new.problem is it was running both on ac and battery.suddenly battrey is not taking the charge but my laptop runs on ac power. can i remove the battery and run...
    the batteries eventually wear out and quit taking a charge. You can run the system without a battery with no ill effects. replacements are about $100 for a new battery
    Sep 27, 2010 | Dell Latitude D600 Notebook
    My dell d620 laptop need a battery, I want buy one online, so everybody, how about this http://laptopsbattery.us/dell-latitude-d620-battery.htm ?
    The one you have listed is for a good price but this one may be a tad bit better:
    http://www.amazon.com/7200mAh-battery-Latitude-Precision-serie/dp/B001RNACES
    Price is a bit better but its just knowing what the shipping is going to be.
    May 28, 2010 | Dell Latitude D620 Notebook
    Please help me bios password, which is admin system dell latitude D620
    remove the laptop and, bios battery wait 10 minutes then reconnect the bios battery and repower with the power supply
    May 28, 2009 | Dell Latitude D620 Notebook
    Dell latitude d620 power on password can't remove
    No need to short out any pins, shorting out pins allow you to reset the BIOS quickly. When you leave the BIOS/CMOS battery out overnight, this will reset the BIOS (you only need to leave the battery out for 1/2 + hour to do the same thing).
    Mar 29, 2009 | Dell Latitude D620 Laptop (Latitude-C620)...
    Is any cheap battery for laptop d620
    Hi - i've ran a D620 now running a D630 and yes the battery life is extremely poor even when the battery is new.
    The option above will give you extra - you can also buy a moduler battery that will fit into the CDROM port which will give you even more!
    http://www.google.co.uk/products?hl=en&q=d620%20modular%20battery&cr=countryUK%7CcountryGB&um=1&ie=UTF-8&sa=N&tab=wf
    or ebay is your best bet...
    Dec 31, 2008 | Dell Latitude D620 Notebook
    Dell Latitude C640 Notebook Logo
    111 people viewed this question
    Alun Cox
