Question about Muratec F160 Fax Machines
How could i reset the date of my fax machine f-160
    Genius:
  • 1,218 Answers
Visit Muratecs web site www.muratec.com you can download the manual for FREE.
Posted on May 28, 2010
Change date and time on Brother intelliFax 1860C
just solved this issue on mine at work:
Push MENU, then 0, then 1. Then, enter your new time and date.
Source: http://www.manualowl.com/m/Brother%20International/FAX1860C/Manual/239514?page=4
Scroll to page 13 of 16
Jul 05, 2012 | Brother IntelliFax 1860C Plain Paper...
I NEED TO SET THE TIME AND DATE ON MY LEXMARK X5470 ALL IN ONE.
Set the printer to factory defaults. Caution you will lose all stored custom settings. You will then be prompted to set the language, country, date, time and time format, your fax number, and name on your printer..
You can reset your printer to the original settings by first turning off the power. Then p
ress the Start Color (green button) + X and keeping the buttons pressed down. Press the Power On button once to power the All-In-One on. Continue to hold the Start Color (green button) + X buttons for the next ten seconds.
When the prompt appears , release the buttons and follow the prompts on the display to choose your language, country or region code, date, time, and fax number.
Use the forward and backward arrows to select your language. Use the checkmark to save the setting.
Use the keypad to enter the date, time, fax number, owner's name, and press the checkmark after each selction to save.
For future reference support information for your printer may be found here.
Jan 21, 2012 | Lexmark X5470 All-In-One InkJet Printer
How do I change the time on the Brother 2820 fax?
This was taken directly from the Brother 2820 Manual:
Setting the Time
When the machine is not in use it will display the date and time. If you set up the Station ID the date and time displayed by your machine will be printed on every fax you send. If there is a power failure, you may have to reset the date and time. No other settings will be affected.
1 Press Menu/Set, 0, 2.
[2. Date/Time]
2 Enter the last two digits of the year.
Press Menu/Set.
3 Enter two digits for the month.
Press Menu/Set.
(For example, enter 09 for September,
or 10 for October.)
4 Enter two digits for the day.
Press Menu/Set.
(For example, enter 06 for 6th.)
5 Enter the time in 24-Hour format.
Press Menu/Set.
(For example, enter 15:25 for 3:25 P.M.)
6 Press Stop/Exit.
The LCD now shows the date and time
whenever the machine is idle in Fax
mode.
When the machine is in Sleep mode, the
LCD shows Sleep. (See Sleep Time on
page 2-8.)
Turning on Automatic Daylight Savings Time
You can set the machine to change automatically for Daylight Savings Time. It will reset itself forward one hour in the Spring and backward one hour in the Fall. Make sure you have set the correct date and time in the Date/Time setting.
1 Press Menu/Set, 1, 5.
[5. Auto Daylight]
2 Press Up Arrow or Down Arrow to select On (or Off).
Press Menu/Set.
3 Press Stop/Exit.
May 03, 2011 | Brother IntelliFax-2820 Laser Fax
HOW DO I CHANGE THE PHONE NUMBER ON MY FAX MACHINE
go to menu setting there you can see factory default select and press .then machine will reset as factory default.off machine and on it again it will ask time ,date your fax address fax number everything give it.
Aug 01, 2010 | Sharp UX-B750 Inkjet Fax
Fax will not print the right report
You must to reset this one at first/ Then to try a litl to switch on/ If it one will not be no well? make it off/ Then//press the buttom Programm and to find the menu date and make some changes
Mar 14, 2010 | Brother IntelliFAX 560 Plain Paper Fax
Hi, Power surge knocked out power briefly, but now we are getting no printed confirmation sheets that fax was transmitted. How to reset??
Press
Function
74
set
12
set
set
stop
To reset date and time press'
function
71
set
enter date and military time
set
stop
Oct 22, 2009 | Panasonic Panafax UF-550 Plain Paper Laser...
How do I set the date and time
I found this that may help you:
"Set the date and time      You can set the date and time from the control panel. When a fax is transmitted, the
current date and time are printed along with the fax header. The date and time format
is based on the language and country/region setting.
Note If your HP all-in-one loses power, you will need to reset the date and time.
1 Press Setup.
2 Press 4, and then press 1.
This selects Basic Fax Setup and then selects Date and Time.
3 Enter the month, day, and year by pressing the appropriate numbers on the
keypad. Depending on your country/region setting, you might enter the date in a
different order.
The underline cursor is presented initially beneath the first digit; it automatically
advances to the next digit when you press a button. The time prompt
automatically appears after you enter the last digit of the date.
4 Enter the hours and minutes.
5 If your time is displayed in the 12-hour format, press 1 for AM, or 2 for PM.
The new date and time settings appear on the control panel display. "
Jun 27, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Date and time wrong on the journal
to reset the time and date on the machine you need to hit
Time/date
Function-7-1-start- then adjust the time and date and hit start then stop
Com journal after every fax
Function7-4-start-1-2-start-2"should says always" then start stop
receive time print." puts the time and date of your machine of the fax..example if your receiving a fax from new york and your in california it will put your time and date at the bottom.
Function7-4-start-9-start-2"should say valid" start then stop.
as for why your losing your time and date all the time is because the battery if dead on the machine.
hope this helps.
Jan 07, 2009 | Panasonic Panafax UF-585 Plain Paper Laser...
Panafax UF-755e
Sometimes when this machine loses power it goes to a default setting (flashing time and date) You will need to got to the user parameters and reset the time and date. If you refer to your user manual it will tell you how to do this.
Hope this helps...
Jun 16, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Muratec F160 Fax Machines Logo
81 people viewed this question
Top Muratec Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Ben
Ben
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
