Question about EZQuest Cobra Plus (B12660) 120 GB Hard Drive
My mac is not recognizing my disk from my hard drive
This is what my mac is saying when I turn my hard drive on. Its says it doesn't recognize the disk. I went to verify in utilities and this is what it says. I don't want to loose my data!!!
Verifying volume “disk1s10”
Checking HFS Plus volume.
Checking Extents Overflow file.
Checking Catalog file.
Invalid node structure
The volume EZQ 120GB needs to be repaired.
Error: The underlying task reported failure on exit
1 HFS volume checked
Volume needs repair
    Problem Solver:
  • 16 Answers
Open Disk Utility (as I'm sure you already have) and select the main partition of the problematic disk on the left side, which should be titled disk1s10. In the First Aid tab, click the "Repair Disk" button on the bottom right hand corner of the window. *Note: If this is the current boot disk, you will have to boot off of the Mac OSX Install Disk by inserting it and holding the "C" key while it is turning on. Select your language and choose Utilities --> Disk Utility from the menu on the top of the screen, then following the above instructions.
Posted on May 03, 2010
My mac does not recognize my seagate goflex drive anymore
Try the drive on another computer. If it is recognized there, you might be looking at a larger issue on your Mac. If it doesn't, the GoFlex's drive or boards may have failed.
Jul 07, 2011 | Seagate 500GB FreeAgent GoFlex Hard Drive
My PowerBook G4 does not recognize internal hard drive. when i boot without cd it will not boot and i will see a question mark on the screen and a small icon that represent mac os. i have Mac OS X 10.3...
If you plugged this into a PC and formatted it you probably formatted it with NTFS or another Microsoft file format. This will not be recognized by a Mac. You will need to pop the hard drive back into your Mac and boot to the installation CD. From here you will need to go into disk utility and reformat the drive with a GUID Mac Extended format partition. If you open disk utility and the drive doesn't show up you probably have an issue with the drive controller on the logic board.
I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
Jun 28, 2011 | Computers & Internet
I have a 1 TB SimpleDrive external USB drive. The drive is now making a repeating, beeping noise, slow and methodical, and it is not recognized by either my MAC or my pc. WHat does the beep-beep-beep mean...
The hard disk inside it doesn't responds to the controller - hardware failure, the disk has failed.
Nothing can fix that, your unit is truly dead and you need a new one.
Apr 30, 2011 | SimpleTech SimpleDrive Portable USB 2.0...
Hi i need to copy files from my macbook to my seagate hard disk which is in ntfs format.. it says it is write protected... help me...
the ntfs format is windows operating system format...
MAC will not recognize this format...
You need to format your hard disk according to the MAC OsX from your MAC computer...
Dec 13, 2010 | Seagate FreeAgent Pro Desktop - 320GB -...
WD HD TV Media Player won't recognize Hard Drive
I had a similar issue eventually reformatted on the mac and included the dos readable check option on snow leopard,
Jun 05, 2010 | Western Digital TV HD Media Player USB...
MacBookpPro osx10.4.11 doesn't recognize new WD passport
the problem is that your western digital operates using the NTFS (New Technology File System) which is the standard file system of Windows. Apple macs is not interopable with native NTFS therefore you need to install a read-write NTFS file-system driver on your mac.
an excellent free mac NTFS driver can be found here-
http://mac.softpedia.com/get/System-Utilities/NTFS-3G.shtml
//javaftper
Apr 02, 2010 | Western Digital Passport WDXML800UE...
My Mac OS X doesn't recognize my Maxtor One Touch
Try unplugging both the power and data cables from both the computer and the hard drive. Let the hard drive spin down. Plug the cables back in. It should become visible with no loss of files.
Nov 07, 2009 | Maxtor OneTouch A01B080 80 GB Hard Drive
Mac book will not turn on.
A flashing folder at startup means that the Mac doesn't recognize your system. This can be either a hardware or software problem. The hardware problem would be the hard drive, and the software the OS.
So these are the steps you should proceed: 1) Check your hard disk by using your install DVD (press the c key at startup), choose your language, go to the utilities menu and hit Disk utility. go to SOS tab and select your hard drive on the left. Click "repair volume" and check what happens.
2) reboot, if it does not recognize the system again, reinstall it using the "archive-install" option
May 29, 2009 | Apple 13.3 MacBook Intel Core 2 Duo 2.2GHz...
Having Problem with both LaCie hard drives being recognized on both macs
Try to connect to another computer, and see if it recognizes the drive. If Not, you can dismantle LaCie and take the disk out.
Connecto your disk to another external box (USB or Firewire) so you can have access to you data.
Jul 04, 2008 | LaCie (300740) 160 GB Hard Drive
Usb not recognized when I put scan disk in port
do 1 thing plug it on a other PC or on a mac and see what happens !!
then format the volume..
hope this helped...!!
Feb 28, 2008 | SanDisk 1GB Cruzer Titanium USB Flash...
EZQuest Cobra Plus (B12660) 120 GB Hard Drive Logo
275 people viewed this question
Top EZQuest Computers & Internet Experts
David Payne
David Payne
Are you an EZQuest Computer and Internet Expert? Answer questions, earn points and help others
