Question about Hitachi 42PD6600 42 in. HD-Ready Plasma Television
Hi, I have a Hitachi 42PD6600 which does not start. I get green light for a second but than it turns red. I get all the output voltage from the power except from VS and VA. Is this a common problem? Thanks Steinar
    Problem Solver:
  • 15 Answers
It turns into protection mode.Check PSU and Loads.
Posted on May 03, 2010
I can't figure out what is wrong with my Hitachi CP-X605 projector.
The ballast (which provides power for the lamp) might have gone bad. Check the voltage its outputting with a digital multimeter.
Aug 23, 2015 | Hitachi Office Equipment & Supplies
Hitachi model# 50ux23ka no power???
The green ones are each tied to a voltage source in the power supply of this set, try to see if one goes off or dim before the others, the red one should always be on.
If one can be seen to go out first or dim first that voltage line is being held down or has a problem.
Its meant to be a way to know which voltages are up and also to narrow down where a problem might be.
Dec 12, 2012 | Televison & Video
All of a sudden my Hitachi P50H401 has not been turning on. I simply plug it into an outlet and it turns on for 2 seconds then immediately shuts down (not even the red standby light stays on) . Any...
Hi.Your television have problem in power. maybe the power suply of your tv have loose connection or have open circuit and may contact sometimes when its move it.So you better check the power supply if is good or have output voltage.
Jul 05, 2011 | Hitachi P50H401 50 in. Plasma HDTV
I have a hitachi 55pma550 plasma tv.when I turn on the main switch red light comes on standby. But when I turn on tv the red red light on stand by turns green only for 10 seconds and goes red no picture...
It's most likely the smps. You'll first need to check voltages at CN63, pin #1-(+5v), 3-(+3.3v) and pin 8-(+6v) Also check CNPPS, pin 1-(+30v), 4-(+5v), 8-(+12v), 12-(+10v) absent these values and the power supply is clearly the problem.
Jun 30, 2011 | Hitachi 55PMA550 55 in. HD-Ready Plasma...
Generac generator on auto runs weekly. light green previuosly green. now red. what causes this??
Hi and welcome to FixYa I am Kelly. Your red LED is telling you that it was 1. overloaded. 2. has low voltage 3. overheated or 4. short in the powered circuit.
OVERLOAD LED (red): Lights up if the generator experiences
a load greater than the rated output, low voltage, overheats or
the powered circuit experiences a short. The output is stopped
even though the engine keeps running.
I do not know which of the 4 conditions caused your red light. If you have the read light with no load I would suspect low voltage from the generator / inverter. If it overheated you will also get the Red LED with no load.
Thanks for choosing FixYa.
Kelly
Aug 30, 2010 | Kitchen Ranges
I cant get any sound from my Hitachi 42PD6600
HITACHI
42PD6600 NO SOUND
Sound value’s have been lost in memory,
to reinstate
please do the following.
ENTER SERVICE MODE. MENU- 4-7-2-5.
Go to Audio menu.
Select Sound 2.
Re-instate the following
FM PRESCALE 15
NICAM PRESCALE AVL ON 35
SCART PRESCALE AVL ON 14
SCART VOLUME AVL ON 122
THESE WILL HAVE ALL DEFAULTED TO ZERO
GO TO STANDBY TO MEMORIZE
Sep 03, 2009 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
My t v will turn on, the light will be Red, then Green ,then
your tv in protection mode some thing wrong inside tv.mostly power card defective.
Jun 28, 2009 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Hitachi 51f510 Color problem
for testing, place the green crt board on the red crt and see if the red crt lights up and the green does not. If the green does not light up then check for 200+ volts on the collector or the output transistor. if you have that kind of voltage thee then check for an open resistor. If not then make sure the transistor is not shorted
Dec 28, 2008 | Hitachi 51F510 51" Rear Projection...
Hitachi 32LD8700 - TV won't turn on although has power
The general problem with LCD type TV's is that the power supply fails. They are very sophisticated designs that are difficult to troubleshoot and generally best to just replace the module, but sometimes there is visible damage in some of the electrolytic capacitors (visibly bulged) and high voltage rated parts can be substituted.
Hope Ya Fix It
Feb 10, 2008 | Hitachi 32LD8700 32 in. LCD Television
Will not stay on
RED light is protect circuit = do not disable !
Look for C702 near flyback transformer - might be hidden in
glue = check it = if shorted, replace 102K / 2KV with 3KV =
Sony part # 1-161-754-00 and replace E994 pico fuse.....T.
Nov 08, 2007 | Hitachi 60UX54B/55K 60" Rear Projection...
Hitachi 42PD6600 42 in. HD-Ready Plasma Television Logo
184 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
