Question about Belkin (F5D8231-4) Wireless Router (F5D82314)
Recommended wireless channel
Im from d philippines, wat is the recommended channel for the belkin wireless. pls help. thanks
2 Suggested Answers
Joed911
  • 4338 Answers
SOURCE: I cant change my belkin wirelees channel
Belkin Router:
Go to 192.168.2.1
when the setup page comes up,
Click on Channel and SSID on the left column.
It may ask you for a password, if you have not previously set a password, just click submit.
On the next page change the channel and make sure you click apply. then click on logout on the top right corner.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Jan 11, 2009
How do I set up a security password
Here's a video on how I did it on my F9K1003V1.
Aug 09, 2011 | Belkin Basic Wireless Router
Problem with my Belkin Wireless G Router with model no. F5D7230-4, been using it for 2 years and it just stopped working, no lights no power, want to know how can i avail of the lifetime warranty?who do i...
Hey Donne; checking out the router you list; you should be covered by their support "Comes with a Belkin Lifetime Warranty and free, 24-hour technical support" per their warranty info. You have a few options to get in touch with them: http://en-us-support.belkin.com/app/answers/contact_support/a_id/463/ use that link to find one that's to your linking. But in-case you just want to call the number for Philippines is 1800 144 10282. Best of luck.
Feb 28, 2011 | Belkin (F5D7230-4) Router (587009)
I dont have the easy install disc
You dont need disc to configure...To access Belkin's web based setup page type 192.168.2.1 on the address bar of the browser.
By default there is no password set for the router and you just simply click submit button to log on to router setup page
Click on Internet WAN and select the connection type you want.
Wireless name (SSID) is the name of your wireless network. The most recommended wireless channel is 6. You can use wireless channel 1 and 11 to and scan for the network
Jun 04, 2010 | Belkin (F5D7230-4) Router (VVLZ253558)
I have just installed a BT N mode Hub, and my Belkin Wireless G Universal Range Extender is now not working. Help please!
make sure wireless channel number should be the same on BT hub and on belkin. BT hub is normally on Auto channel change it to a channel number usually 1 and 11 are the best for coverage and then chose the same channel number in belkin.
Mar 19, 2010 | Belkin Wireless G Universal Range...
Can not change the wireless channel
A very good question!
I'd love to answer this. Belkin utility at times has some bugs. As you said you have downloaded the latest version of drivers and utility. Latest drivers are good but utility will not be of much use, I, as a technician would highly recommend that you use Wireless Zero Configuration in case of Win XP or WLAN Auto-config in case in case of Win Vista or Win 7. But if you have older versions of Windows, older than Win XP, only then utility has to be used. Enable WZC and WLAN A-C in Microsoft Services(Local) page.
Start > Run > services.msc > Ok > Services (Local) > Start the service.
At worst instances, if you are forced to use the utility, remove all SSID (wireless network names) from My Connections. Note: Remove all of them completely.
Also, i would recommend that you configure your wireless mode to be "802.11g only" on the router as F5D7001 is a 802.11g standard PCI card, and also turn ON the wireless PROTECTED MODE on the router. This will enhance the performance of your wireless devices in cases of heavy wireless traffic.
This is sure to work! Again, thanks for such a question.
Feb 02, 2010 | Belkin (F5D7001) 802.11g/b Wireless...
My belking keeps losing connection during games?
If your wireless you probably need to change broadcast channels on the router ( to the last channel) if its hard wired, you probably need to port forward the ip address for the Xbox
Oct 05, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Vista wireless connection to belkin-n
It sounds like your linksys is your main connection so therefor it will not always let belkin connect because your pc has registerd your linksys to be your connection.
Sep 20, 2009 | Belkin (F5D5231-4) Router
I have buzzing on my phone when my Belkin n modem router is on . i have just brought new Uniden 5.8GHz phones i have 2 adsl line filters but stil the buzzing persists can you help
The frequencies of the phones and the modem are causing harmonics. You should have the ability to change channels on the phones, just turn the phone on and when you hear the buzzing start changing channels on the phone till it stops. You should have at least twenty five channels on the phones. Hope this helps.
May 17, 2009 | Belkin N1 Vision Wireless Router
Its the only sparkplug i have managed to find here in philippines that fits my engine, just wat to know if is suited for my car before i have to look abroad
get on the net to find out more,NGK, Nippondenso,or Bosch will be fine usually higher price better longer lasting plug,i dont think theres any major advantage
Apr 21, 2009 | Subaru Impreza WRX STi Cars & Trucks
I have wireless router but lost the disk wat can i do
Follow the link below. The page has a download for your router.
http://www.belkin.com/uk/support/product/?lid=enu&pid=F5D7230uk4
If this helps I would appreciate feedback. Thanks
Jan 26, 2009 | Belkin (F5D7230-4) Router (587009)
Belkin (F5D8231-4) Wireless Router (F5D82314) Logo
141 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
