"No Disc" Even with a disc in the machine it says it is loading and then says there is no disc. Why isn't it registering that there is a dvd in there to be played?
  • blondieinvt Mar 30, 2008
    I had already tried several boughten dvd's.
    Master:
  • 518 Answers
"No Disc" also means "I can't read the Disc". The laser must be able to read the disc or you'll get that. There are several reasons:
Bad or noncompatible Disc: Some units won't play certain types of recorded discs. Try a rental or bought DVD.
Dirty laser lens: Either try a cleaning disc, or GENTLY clean the lens with a moistened Q-Tip.
Defective components like laser, spin motor, tracking motor, etc. Usually requires professional servicing.
Hope that helps...
Geno
Posted on Mar 26, 2008
SOURCE:
My Road view in the vehicle was working fine...2 day's ago..it's saying 'bad disc' the disc's are all clean and new..I unplug it.. and still saying the same thing.
see this causes and fix it. God bless you
If your mini DVD player reads "No Disc" after you've loaded the disc, it means the machine isn't reading the DVD. Take the DVD out again and clean it. It's quite possible that the disc is simply dirty and cleaning it will solve the problem immediately.
However if the problem persist test the following:
  1. Bad connections to one or more buttons or sets of buttons.
  2. Microcontroller failed to reset properly.
  3. Missing/bad voltages from power supply.
  4. Defective microcontroller or other logic.
go to the repair shop FOR fix it.
Oct 15, 2012 | Roadview Rd615 DVD Player
Sony bluray player flashes wait
If you try several different discs and clean them and you still receive a reading saying "No Disc," then the problem is in the laser and this will need to be fixed by a professional.
Clean a DVD disc:
  1. Hold the disc by its central hub and outside edge.
  2. Blow dust from the bottom surface with a can of compressed air.
  3. Clean dirt and fingerprints from the bottom surface with a lint-free cloth dampened with CD/DVD-cleaning fluid or denatured alcohol, wiping from the center outward.
  4. Clean the objective lens:
  5. Remove the housing and lift the hold-down clamp to expose the lens.
  6. Remove dust with canned air or soft brush. If needed, use a foam swab or a camera-lens tissue dampened with lens fluid
Sep 30, 2012 | Sony BDP-S300 Blu-Ray Disc Player
I have a 19" LCD
Here's what I would do in your shoes:
1)Try several DVDs, to make sure it isn't an isolated case.
2)Check the firmware version of the TV against the newest one available from Polaroid's website.
3)If you are in warranty, call Polaroid, this is obviously an issue with their TV and will have to offer you options to repair or replace this unit.
I'm sorry you are having trouble with your DVD player.
Jul 18, 2011 | Polaroid Televison & Video
DMR-EX98 CANNOT USE DVD RECORD FUNCTION MACHINE THINKS A DISC IS LOADED EVEN WITH NO DISC INSERTED.HDD/VCR OK
This problem has just happened on my dmr-ex98 although perhaps more extreme in that the dvd drive will not read any disc let alone record - makes an attempt to read disc plus phantom disc but gives up. hdd.vcr also ok. Any guidance?
Feb 15, 2010 | Panasonic Televison & Video
Discs won't play.
please change laser unite then solve your problem
Jul 16, 2009 | Sony DVP-NS575P DVD Player
Player won't play any disc now
Time to look inside the dvd player. try readjusting the variable trimmer under the laser lens of the dvd player assembly. It is usually located under the lens assembly. try to adjust the lens at every 1 degree angle up to +/-5deg. sometimes it can be done. if not. time to change for new lens. damage lens is caused by using pirated DVDs or bad disc as the lens is trying to read the data on the cd.
guest.
Mar 13, 2009 | JVC DR-MV7 DVD Recorder/VCR
No Disc
Get a new machine. Not "seeing" the disc could be bad laser, transport, electronics, on and on. Given the repair cost, a NEW one is your only practical alternative.
Mar 26, 2008 | Televison & Video
Televison & Video Logo
165 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
