How to mod Crysis, Steam version? how exactly do i install mods to the steam version of crysis? cant find out how to do this anywhere
  • 4 more comments
  • Christopher Frost
    Christopher Frost May 03, 2010
    where exactly do i get the "MWLL-OpenBeta1.rar" file?
  • Christopher Frost
    Christopher Frost May 04, 2010
    how do i build my own exe files so i can install a custom mod?
  • Christopher Frost
    last reply from previous expert was unrelated to the question i was asking, which was, how do i build my own exe files for the crysis steam version so i can install a custom mod
  • Christopher Frost
    Christopher Frost May 05, 2010
    ok thanks, for your info i have tried all compatability modes
  • Christopher Frost
    i have Windows 7 Ultimate
  • Christopher Frost
    32 bit, srry i keep clicking submit instead of typing further details
  • 493 Answers
You should change the compatibility according to your operating system.
What is your operating system (of PC)?
Try to check if steam is set to run in Vista compatibility mode. If it is, uncheck the compatibility mode.
Ifyour Operating System is Windows XP, change the compatibility to Windows XP.
Hope this helps.
Posted on May 04, 2010
  • 1 more comment
  • Ibrahim OKTAY
    Ibrahim OKTAY May 04, 2010
    Hi again,
    You may install the Demo version from here.
    And a iveo link from YouTube, I don't know whether it works or not. For info only.
    Hope this helps.
  • Ibrahim OKTAY
    Hi again,
    Sorry for my comments, but the links in my last comment are not used by me. It is your own risk to use the unknown downloads as you know. I only wanted to give info.
    Good luck.
  • Ibrahim OKTAY
    Ibrahim OKTAY May 05, 2010
    As I understand you had the rar file of the Game Steam.
    - Open a folder name as \Steam in your computer.
    - Copy that "MWLL-OpenBeta1.rar" file in that folder.
    - Double click on that file to extract it. (To extrac it you maust have an unzip software,)
    - While extracting select all files and extract them in the same folde (\Steam)
    - Run the Setup file to install the game. (Find it in that folder. That setup file's name It may be something Steam maybe)
    - It will create and place the files automatically to their folders.
    - After installation you will have a custom exe file and game. (If the copy of your game is not a network setup game),
    Hope this works.
    Genius:
  • 1,354 Answers
To install, first make sure that your "vanilla" Crysis is patched to 1.20, then patched with the hotfix to 1.21.
- UAC for vista and Win7
I find that Vista and Win7 have problems with UAC, so at your own risk, you can disable UAC by navigating to your control panel
find the user accounts section, and disbale your UAC (or as low as possible in Win7)
Then,
Unrar the File named "MWLL-OpenBeta1.rar" with either 7Zip (www.7zip.com) or Winrar (http://www.rarlab.com/)
To do this, open the file in one of the programs mentioned above, then click "Extract to"
Make sure to extract to “C:\Program Files\Electronic Arts\Crytek\Crysis\”
Or If your using Steam, extract to "C:\Program Files\Steam\SteamApps\common\crysis\"
And if your using Win7, extraction path is the same unless your using 64 bit, in this case your path would be:
C:\Program Files (x86)\Electronic Arts\Crytek\Crysis
or for steam C:\Program Files (x86)\Steam\SteamApps\common\crysis
Once You've extracted, navigate to C:\Program Files\Electronic Arts\Crytek\Crysis\Mods\mwll\
or for steam C:\Program Files\Steam\SteamApps\common\crysis\mods\mwll
In this folder you will find the MWLL Launcher.exe, right click this and click "send to > desktop (Create Shortcut)"
Alternatively you can add a " –mod mwll" in the target line of a shortcut to the crysis executables.
The target line will look like this “"C:\Program Files\Electronic Arts\Crytek\Crysis\Bin64\Crysis.exe" -mod mwll” or “"C:\Program Files\Electronic Arts\Crytek\Crysis\Bin32\Crysis.exe" -mod mwll” Respectively to whether you have 32 bit or 64 bit windows installed.
**** Actionmaps ****
Next you need to install your actionmaps.xml to your profile in Crysis
To do this copy the file “example_actionmaps_for_joystick.xml” from your "C:\Program Files\Electronic Arts\Crytek\Crysis\Mods\mwll\" folder
Then paste the file into your "My Documents\My Games\Crysis\Profiles\Default(and YOURPROFILE if you've made one)
Then rename your original actionmaps.xml to something different if you plan to play crysis again in the future, and rename "example_actionmaps_for_joystick.xml" to "actionmaps.xml"
Posted on May 03, 2010
  • 1 more comment
  • you will get this file from folowing links
    http://www.ausgamers.com/files/details/h...
  • -Giving yourself a name in game-
    When you first play online you'll notice your name is Nomad. To change this you need to go to the main menu, go to profiles, then hit New Profile, the name you give your profile is the name you use in Multiplayer. ( Remember that when you do this, you have to reinstall the action maps for your new profile like in the example above)
    -Crashes-
    I myself have had quite a few crashes and found that by following the instructions below, you can reduce some of those crashes.
    If you experiencing crashes try the following:
    Navigate to your "My Documents\My Games\Crysis" folder, and delete your shaders folder, by doing this, the cry engine will re-download the shaders for the mod. I find this helped to stop most of my crashes in game.
    If your experiencing crashes before even getting in game try deleting your "My Documents\My Games\Crysis" folder all together. Don't worry this will be replaced upon the first start up of Crysis.
    And remember to replace your Actionmaps.xml after doing this to not mess up your in game controls.
    -Crashing In The Menu System- Anti Virus Troubleshooting
    Try to disable your Anti Virus, as it seems that any file change in the Crysis Directory is triggering your Anti Virus.
    AVG - Real Time protection, set to off or shutdown helps as well - Thanks lessergod
    AVG - Adding a path to your Crysis folder "Tools > Advanced Settings > Resident Shield > Directory Excludes > Add Path" add Crysis folder -Thanks Scarfox
    AVG - Adding the Crysis Executable "Tools > Advanced Settings > Resident Shield > Excluded files" Then add the Crysis.exe - Thanks Jsnack
    If you have questions or you want something added to this threa
  • read all the details of folowing link
    http://cs.elderscrolls.com/constwiki/ind...
My crysis 2 code won't be accepted
You would need to contact EA, if code came with game purchase.
Oct 09, 2012 | Electronic Arts Crysis 2 PC Game EA
Where can you get crysis 2 full version?
http://thepiratebay.org/search/crysis%202/0/99/0
You may try a few of these ones....Im not sure which one will work ..but the download is free and you may find the one you want ..For downloading you have to install a torrent client like this one ..in case you do not have a bittorrent or lime ....http://www.utorrent.com/
Good luck !
Jul 05, 2011 | Video Game Consoles & Games
Registration code for crysis warhead
hi.
i put the key for you.
if it didn't work only ask for another:
KEY: D4W6-U6GQ-FA2E-XYQP-Q4ZQ
Jan 29, 2011 | Electronic Arts Crysis Warhead v1.1 Hotfix...
I need a registration code for crysis warhead.................. Plz help me
Well Go on the limewire and download the new version of it and the patch
Sep 23, 2010 | Electronic Arts Crysis Warhead v1.1 Hotfix...
how can i get the registration code for crysis warhead........?
Plz help me.............
Sep 02, 2010 | Electronic Arts Crysis Warhead v1.1 Hotfix...
My polti 750w mod PRO VT doesn't produce steam
i woundnt see why not alls that needs to be done is replace the power cord to the unit your local electrician store should be able to fix that
Apr 21, 2010 | Irons
I cant seem to find out how to be able to put cheats on my game called crysis.
Hi just1bri,
I'm a fan of Crysis myself, and cheats always have a way of making things a lil bit more fun every so often. Follow this link.
Note that to use the cheats, you need to either play the game in DevMode, or type in con_restricted = 0 into the console which you can access by pressing the ` key (tilda).
Have fun!
Nov 28, 2009 | HIP Crysis for Windows
Windows vista home basic cant play games like crysis..on ge force 6150 is there any driver or software to accelerate games
sorry, your graphics is slow, crysis wouldn't run on that, but you can try this software: http://www.iobit.com/gamebooster.html to make your games smoother
Jul 10, 2009 | Compaq Computers & Internet
Crysis not working, may be because i have Vista
You need to install the editor in the same directory as the game. The default is "C:\Program Files\Electronic Arts\Crytek\Crysis\Bin32
In regards to crysis not loading, attempt a reinstall of the game and see if that works. Most problems like this are solved with a fresh install of the game due to the game becoming corrupted in some way.
May 04, 2009 | HIP Crysis for Windows
Computers & Internet Logo
216 people viewed this question
David Payne
David Payne
