Question about Zanussi ZBQ965 Electric Single Oven
I have a Zanussi oven without a manual. It has a rectangular screen with 9 buttons below it. It has numerous symbols for cooking and I have no idea what some of the symbols mean. Can anyone give me a clue?
  • 269 Answers
I can tell you what the buttons are for but really you may need to get in touch with your local dealer or Electrolux to either get a hard copy or download one from their website.
Starting from the left is your main power button.
Then the oven function button.The next one is the fast heat up/defrost function.Next is the temp. control/current temp.Next the two with + and _ control time or temp.Next is the minute minder.Next is cooking time.
Finally the last one inicates end of cooking time.
Posted on May 03, 2010
How to wire up a zanussi zop37902 oven
You will need to have an electrician connect the oven to your power system in your home, unless you are expert at doing this yourself. ZOP37902XK Ovens Zanussi Products Cooking
Jun 07, 2014 | Zanussi Ovens
Will not stay on!!! the timer unit has the A symbol showing and unable to get it off, when you try and set the time by pressing the ready time and cook time buttons simultaniously the the minus button the...
You need to check that when you turn the automatic off, there is no time remaining in the cook time. You need to ensure that this is set to zero when cancelling the auto function.
If this still doesn't worh then espares will be able to source a replacement clock for you.
Mar 18, 2011 | Stoves 720EF Electric Double Oven
Zanussi double oven switches off during cooking. It can be restarted without a problem so fault can not be detected. It displayed error 3 message once.
The shutting down of the oven is due to a defective thermal switch or thermistor. Replacing the thermistor could fix the problem. It is usually located in the inside compartment of the oven and connected to the control panel board.
Dec 02, 2010 | Zanussi Ovens
Looking for a manual for Whirlpool BS0801/WH oven
I have a paper copy of the manual - if you need to know anything more than the information below post a more specific question.
The function symbols on Knob F, clockwise from the top, are as follows:
  • 0 = Off
  • Lamp symbol = Lamp Only, no fan, no heating.
  • Fan + Drip Symbol = Lamp + Fan, but no Heating - this is for defrosting.
  • Fan inside a Circle symbol = Lamp + Fan + Oven Heating - this is the normal cooking position. The temperature of the oven is set on the Temperature Knob.
  • Final position = Grill. The temperature of the Grill is set on the Grill knob.
The red indicator light only comes on when the Oven is heating (not the Grill), and goes off when the oven has reached it's set temperature.
The bulb is 25W 230V Type E-14 300 Degree C.
The oven draws a maximum of 2300W so requires a 10A supply.
Nov 29, 2010 | Ovens
Oven failer
You have reset the timer from the auto function, to the manual function.
You should see a hand symbol showing for manual operation.
It is a question of pressing the buttons in the correct sequence., or if it is a anologue timer, turning the knob until you see the hand symbol showing.
Hope this helps.
Dec 24, 2009 | Zanussi ZBF360X Electric Single Oven
I need the instructions for a diplomatic double fan oven as the second oven is set on auto timer and I can't get it to work.
i had the same prob..... manual operation, to set the programmer to manual (cancelling any auto setting),press the cook time and ready time buttons simultaneously.
To set time of day, press the cook time and ready time buttons simultaneously and keep the buttons depressed. Use the plus and miuns buttons to the the time. A(auto symbol goes out cookpot symbol comes on.
Mar 27, 2009 | Ovens
Seems to be taking a long time to cook
To preheat oven just select the temp you intend to cook at and wait until the red light goes out,it is then preheated
Then you can put your food in and carrying on cooking.
Yes you do put it on fan symbol, but make sure it is on the right one , as some ovens have fan only as well as fan and heat.
Plz rate this solution.
thanks.
Dec 14, 2008 | Ovens
Zanussi electric oven ZBM 762X How do I trun the oven to manual?
If it is an anologue timer then rotate the knob until you see a hand symbol in the window, this brings it off auto.
If it is a digital timer then you need to press two or more buttons at the same time to get it off auto and back onto manual.
Dec 08, 2008 | Ovens
Programming Belling xou181ss oven
Try Googling (belling)(xou181ss)(manual) without parens.
May 01, 2017 | Ovens
Clock
Hi this is propably too late now but we moved in to our new house six months ago and have a Zanussi ZBF 360 oven, and had no idea how to set the timer / clock. After fiddling around with the oven clock for the last 6 months i managed to set the clock. It shouldn't be much different to the one you have. Hope this helps you and others in the future.
Click the middle button until the little red things on the screen moved round to the clock symbol, then press + or - to get to the correct time, once you have done this it will flash for a few seconds then it will stop flashing and the clock is set. The same goes for the timer to set it when you want to cook something for a period of time eg: ten mins.
As for getting the oven timer to turn it's self on and off I am still messing with it and when i have mastered it I will let people know.
May 07, 2007 | Zanussi ZBF660 Electric Single Oven
Zanussi ZBQ965 Electric Single Oven Logo
251 people viewed this question
Top Zanussi Ovens Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
