Question about Canon BubbleJet i560 InkJet Printer
The black is not printing but the cartridge is full
    Problem Solver:
  • 10 Answers
Are you sure that you removed the protective film cover from the terminals of the cartridge before plugging it in?
Also make sure it is seated firmly in it's carriage.
If you have an ink level indicator with your printer's software, and it shows the cartridge to be full, then there might be a problem with your drivers. I would re-install them.
If the indicator shows empty, then the protective film just might be on there.
Lyle
Posted on May 03, 2010
Can I print with just using the black ink cartridge?
Printers are set up that way to make you purchase cartridges
Feb 05, 2017 | The Office Equipment & Supplies
Printer has all full cartridges, not printing clearly
Does this machine have drum units, image units and toner units? what combination? Replacing the toner cartridge will not fix the issue with the drum or image unit.
Nov 20, 2015 | Office Equipment & Supplies
Only one black cartridge on my canon mp560 is empty, but all the colored ones and smaller black one are full, but my printer will not print
Once a cartridge is empty the printer will not print untill a new cartridge is put in, just replace the empty black cartridge
Jul 21, 2014 | Canon MP560 All-In-One InkJet Printer
I have a Lexmark Pinnacle Pro 901 printer and its set up to print using black ink only, but it keeps telling to replace color cartridges and it won't let me print at all, how do I print using blac
The printer would need all cartridges to have sufficient ink levels to continue printing - that's to prevent damaging the printhead. Every time a cartridge is replaced, all colors are primed simultaneously thus the need for all cartridges to have ink.
To save on your ink investment, try printing in draft mode and by making sure that your printing preferences is set to print using black ink only.
Oct 25, 2012 | Lexmark Pinnacle Pro901 All-in-one Inkjet...
I changed the black cartridge and the printer won't start copying when I try. The color cartridge is empty. Is that why?
Yes that is probably the reason that it will not print.
Both cartridges have to be installed with a good amount of ink supply in both of them in order to be able to print.
Your color cartridge has to be full in order to print anything - even when your only trying to print black text and your black cartridge is full.
Both cartridges have to remain installed too. You can't remove one and try printing. The sensor will know it.
Hope this helps?
Nov 06, 2010 | HP Officejet 5610 All-In-One InkJet...
Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink cartridge and I have a drawer full of small 8BK cartridges. How can I get it to use the small black...
Canon PIXMA MX850 Multi Function Printer Printer Canon MX850 will not print from... Answer Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink... (More) Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink cartridge and I have a drawer full of small 8BK cartridges. How can I get it to use the small black cartridge and not the large black cartridge? Thanks
Sep 30, 2009 | Canon PIXMA MX850 Multifunction Printer
Printer wont print black.already replaced with new ink but still wont print black
did you take the tape off the new cartridge and is the print head burned out for the black? if you installed the diagnostic's on it then run it and see what it says, otherwise expect the print head to be cooked, however it is possible to get a bad ink cartridge try tapping it on your finger and see if ink comes out if it does not then the ink cartridge is dried out or no good, about %15 of print cartridges are bad on just about any brand printer some more than others.
May 31, 2009 | Brother DCP 165C Compact Color Inkjet...
Want to print with black ink cartridge only
It is a little known fact that ink cartridges do have an expiry date, and it is sometimes possible that even if a printer reads full, that it has dried out and will not print. When you recieve a warning that your ink is too low you will simply be unable to print black ink after a certain point. Generaly if you want to print in only black you will have to do that when you print a document. For instance in IE when you go to file and then print you can select prefrences and select print in greyscale or black. hope this helps!
Jan 24, 2009 | Dell 922 All-In-One InkJet Printer
Won't print with only 1 cartridge empty
sorry you can print unless all your cartridge are having some ink
Dec 17, 2008 | Epson Stylus Color 740 InkJet Printer
When I print, only the color cartridge is used. I'm printing documents that are all black and white. How do I print with the black cartridge? I have a full black cartridge, but my printer won't let me...
if your document only black and white , the machine only use black ink, no going withdraw the color ink. but you have had to leaved the full color ink in the machine.
Dec 09, 2008 | Lexmark X2600 InkJet Printer
Canon BubbleJet i560 InkJet Printer Logo
79 people viewed this question
old marine
old marine
