Question about Mitsubishi WD-57731 57" Projection HDTV
Power supply Tv code is bad power supply,have removed unit from tv.Need help to find problem. thank you
  • 1 more comment
  • zx10r Mar 27, 2008
    status light flashed code 12.bad power supply
    No picture or sound
    I found out that the tv will reset to code 12.Someone had told me that a code 12 was a power supply fault.I will put unit back together and start over.Thank you.
    Genius:
  • 1,153 Answers
Where did you come up with code and how you know it's the ps
Posted on Mar 26, 2008
  • Lashawn Robinson Mar 27, 2008
    You might want to double check on error code, my books have 12 as no error.Ok just what is your set doing or not doing?
    If you plug set in and press power does the status light keeps blinking?
TV power is switching on and off. I have unplugged the set and plugged it back in and the problem persists.
Sir the problem of your unit is the power supply, if you remove the back cover of your unit try to observe the power supply if there is a bulge up or leaky capacitor. This bad capacitor is producing unfiltered and low dc supply to your unit that cause your unit to malfunction, if you see this bad capacitor replace it but observe the polarity. Note be sure to unplug the unit when removing the back cover. Good day sir and best regards.
Sep 08, 2011 | Samsung 50 in. Plasma TV
Hit by lightening need to replace fuse/vizio tv 47 ?
The fuse is located at the power supply.Please open or remove the cover of the television and look the power supply at the upper right side of the TV.Then remove the cover of the power supply and you can see the fuse.Replace the same amphere of fuse.Thanks..
Aug 25, 2011 | Vizio VO47L 47 in. LCD TV
I have a Panasonic TH-46PZ85U Plasma TV with a two blinking light code, no picture. How do I fix. I Have removed the back panel and looked for damaged caps but I do not see any.
hi; the blinking light code means that you have a fault in the power supply unit, unplug the tv from the power source, check all transistors you will find some of there shorted, just replace them; if you need a help about repairing i'll help you
Nov 06, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
Mitsubishi model Wt-46807 Power shuts down after turning on. Tried the solution of pressing the menu & input buttons at same time for at least 5 seconds. Power light error code was 2 blinks/pause 2...
hi,
Error code 2-2 indicates "Short Protect Circuit" problem in tv.
Need to check pico fuses in power supply as one or two got blown due to bad convergence chips.
Below is an exploded view of tv chassis, power supply and convergence area has been marked to give you better idea to look for pico fuses.
Unplug tv from wall socket before to repair/check any thing inside tv.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Oct 16, 2010 | Mitsubishi WT-46807 46" Rear Projection...
Samsung model HP-T5054 Plasma TV .. Push power button it lights up and Tv clicks like it is comeing on but then dont..
When you remove the back of the set. You will fined a couple of caps on the power supply board that are bulged and they need to be replaced, or you can buy a new power supply at www.partstore.com. If you want to just purchase the caps, you can get them at www.mcmelectronics.com
Oct 16, 2010 | Samsung HPT5054 50 in. HD-Ready Plasma...
Lost power completely
If you are comfortable with working in tv circuit boards then unplug tv from AC wall socket, take off back of tv and follow AC cord going inside tv that will take you to power supply board, check fuse on power supply board, replace it with same rating written on it if it found blown.
Replug tv back in wall socket and check if it turns On.
If still problem not solved then power supply board is defective and need to be replaced.
Local tv repair shop will help you if you think its not safe for you to work inside tv.
Thanks.
Jul 10, 2010 | Protron PLTV-4250 42 in. LCD Television
Pioneer pro 940hd tv screen goes blank after 3-4
The is due to ether a bad backlight or bad inverter that powers the back light on this TV.
Ether would need repair you can get the parts @ www.partstore.com
Hope this information helps please do click the accept button for my efforts.!
Jan 02, 2010 | Pioneer Elite PRO-940HD Television
My tv does not turn on
This problem is likely a failed power supply. This is a known issue with this model TV. It will normally occur soon after the warrenty expires. It can also be caused by a voltage surge produced by a power failure. You might wish to unplug the TV for an hour or more. If this power reset does not allow the TV to turn on component failure is indicated. These sets are assembled using the wave soldering process they are known for having cold solder connections. The safety circuitry shuts the TV set down or will keep it from turning on when it detects a problem. This model of TV has over 2,000 parts, which includes millions of transistors inside the integrated circuits. The capacitors will change value, leak and become defective. Resistors will change value and burn. Diodes and IC can go bad. This may have a domino effect and cause other parts to fail. Replacing one defective part may make the TV operate for a short time but the part will fail again if the parts that caused the failure to begin with are not replaced. The only way to know for sure which parts that are no longer within factory specs and for a proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment specifically designed for TV service and the skills to use the test equipment. I wish I could tell you there was a quick fix or button to push that would fix the TV but that is not the case or the solution needed to get the TV operating correctly.
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 08, 2009 | Akai LCT2721AD 27 in. LCD Television
Tv has sound ,no picture,power light comes on
Tihs would be the power supply unit gone bad.
1. Check power supply fuse if the fuse is blow so are the caps do not try to replace the fuse you will smoke this thing.
2. upon inspection you can remove the power supply unit and buy a new one. There about $150 bucks aftermarket for this unit. So I would be looking for other RCA's with this same series and pull some psu's to save money.
I hope this helps you find a solution for your TV these are nice to have and worth the repair.
May 21, 2009 | RCA R56WH76 Projection Television
Tv problem
Hi
Tell me the model no and brand name so that we can help u ya.
Turn off the tv for five minutes and then turn on.
thank you
Oct 09, 2008 | Toshiba TZ50V51 50" Rear Projection...
Mitsubishi WD-57731 57" Projection HDTV Logo
107 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
