Question about Samsung Washing Machines
Samsung washing machine J1045 error code SE or 5E won't lock off or drain..... help please ?
SOURCE: I have j1045 front load
The display should say 5E, this means that it's not draining. unlucky for you as this means you have to replace the drain pump, wich aperently cost about $137NZ. this seemes to be a common fault. i'm not a teck, but I just had the same thing happen, lucky for me i had a warranty.
Other simptoms are the loud racking noise coming fromn the washing machine. home this helps.
Posted on Mar 15, 2009
SOURCE: washing machine stops and flashes 4E
1. WATER SUPPLY ERROR – Display shows 4E.
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
Posted on Feb 23, 2010
  • 43 Answers
SOURCE: fault code 5E
possible pump problem
try cleaning out the filter
Posted on Nov 10, 2008
  • 88 Answers
SOURCE: Error code SE or 5E
'SE' is a temporary sensor error. Switch off power at wall plug, wait a few seconds, switch it back on and it may clear the fault.
Posted on Mar 28, 2010
SOURCE: Samsung J845 error SE or 5E
Just did the above directions on my washer also.And to make things easier you can pull out the whole drainagehoses by removing 3 little phillips head screws and a couple of hose clamps.Then pull all hoses off individually and clean out all hoses and assembly a lot easier.
Posted on Jul 29, 2010
My top loader washing machine shows SE. Please assist.
Hi!
I has the same 5E mistake with my Samsung washing mashine.
5E looks like SE on the screen, but it is 5E.
This is what the manual says:
5E - Your washer is not draining. It can
also mean that the unit senses a
small clog while draining
Do the following:
1) Turn off the unit and turn it on again.
2) Select only the Spin Cycle.
3) Press the Start/Pause to drain the water.
If it still does not drain, call for service.
Apr 26, 2017 | Washing Machines
My machine is showing se
SE also comes up as 5e
The '5E' Error is displayed when the water is not draining properly from the Washing Machine. If the water does not drain in 15 minutes, a buzzer will sound , and the remaining time indicator will show '5E' Error.
You can perform following steps to resolve the issue :
? Clean the debris filter.
? Make sure the drain hose is not clogged.To make it unclogged, Detach the drain hose from washing machine. Attach the spray nozzle to the end of the hose. Aim the sprayer into the clogged washer hose and spray water kinetically down the hose. Continue spraying until the hose is no longer clogged.
? Make sure the drain hose is not frozen.
? Make sure the drain hose is installed correctly.
Dec 16, 2016 | Washing Machines
Samsung Dishwasher model DW80F800UWS with Error code 5E or "SE" error code.
The 5E error code on this Samsung dishwasher means a drain error. Most often this is caused by a clogged drain hose, or some foreign object getting caught in the drain pump impeller. But it can also mean you have a bad ECS sensor. If this is Greek to you, then you should probably call a professional dishwasher repairman.
Jan 10, 2015 | Samsung Dishwashers
Samsung SW60ASP washing machine won't spin or drain
5E is a Drain Error Code.
This can be caused by a clogged filter in the washing machine or a blocked drain line in your house. There can be a few other reasons, but these are the most likely.
If you would like to try to repair it yourself, then follow these instructions:
UNPLUG the washing machine. Repeat, UNPLUG the washing machine!!!
Check the filter in the back of the washing machine on the bottom right-hand corner. Place a shallow dish under the filter. Loosen the filter to drain out the water. Remove the filter and clean it out. Look at where you removed the filter and you will see the water pump impeller. Make sure it can move and isn't locked up. Remove any debris from the impeller.
Replace the filter, and plug in the machine. Try a short wash cycle.
Check for leaks around the filter.
Mar 11, 2013 | Washing Machines
I have a Samsung front loader. It has been stopping with the error code 5E (filter problem ) for a few months now. Turning the machine off then on again after 20min gets it going again. The fault always...
The 5E error mean:
Pump won’t empty - not draining
As usual with these error codes for not draining the first thing to do is check the pump filter but, on Samsung washing machines, the drain pump itself is often faulty. You can find how to fix this problem on youtube, just text it "Samsung washing machine 5E error".
May 16, 2017 | Samsung WF520ABP - 5.0 cu. ft. Steam...
7kg 1045 front loader, says SE or 5E wont drain, will open fill and wash but not draining
Hello & Welcome to FixYa
5E is a water drain error and occurs when the water level frequency does not show changes. First clean the debris filter located at the bottom of the washer and then turn the unit back on after 15 minutes. Please get back to me if you have any other questions.
Kevin
Apr 17, 2011 | Samsung Washing Machines
Error code se on samsung front loader 7kg
could the code be 5e if it is a 5e then the problem would be
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON. Another tech has also done a previous post to this subject so click here to see her repair as well http://www.fixya.com/support/t5093804-se_mean note that if this repair does not work please message me back and there will be other tests for you if this repair she lists does not work if you have any further questions also message me back with them and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks Rick
Mar 16, 2011 | Samsung WF337AA Front Load Washer
I have a samsung washing machine wf7600naw washing machine that won't spin and is displaying the error code SE. How can I fix the problem?
WATER DRAIN ERROR - Display shows 5E.
Dec 11, 2010 | Samsung Washing Machines
I have j1045 front load samsung 7 kg washing machine it shows 5E message and its not draining properly.we cleaned the filter, and drainage hose is not jamed.what should i do
Jun 21, 2008 | Washing Machines
Washing Machines Logo
1,103 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
