Question about Nintendo Wii Console
I plug a 120 to 220 outlet?...then the adaptor explode... is it fixable?
  • Don
    Don May 11, 2010
    Chances are that it's completely destroyed, in which case i'd have to say no. Get a used one and power it up the way it was meant.
Flashing AC Adaptor
Is the battery any good? A bad battery will cause erratic operation of adapter/charger.
Jun 10, 2017 | Samsung Kitchen Ranges
I am getting a lot of distortion feedback when I connect my computer to the mixer but the feedback only starts when the computer is connected to an electrical outlet. I have plugged the computer to a...
Sounds like a ground problem. Try to hook a ground strap or wire from the case of the computers power supply to the ground of the mixer. If it still has noise, try to touch the ground to the bracket of the computers sound card. Most likely, the computer uses a three prong adaptor and the mixer does not. Outlet grounds have voltages which bleed off from motors and other devices, which could cause the 60hz noise. If your mixer has a three prong plug do not plug your computer and mixer in separate outlets with separate grounds or you could fry your system. If you still have problems use a three to two prong adaptor and attach an isolated ground wire on the adaptor for the computer.
Jun 25, 2010 | Gem Sound CDM-150 Mixer
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
Uploading pictures
Cameras can't upload if low on power. Charge batteries or plug in the ac adaptor to an outlet and try again.
Sep 12, 2009 | Panasonic SDR-H40 HDD Camcorder
Gateway MT3422 won't charge battery
shutdown the notebook - unplug the a/c adaptor - remove the battery - re-insert the battery - plug-in the a/c adaptor
it can also be a systemboard failure
Mar 21, 2009 | Gateway MT3422 RTL Notebook
My son plugged in your AC adaptor Model AD 126 when we got Verizon DSL and he put the modem in my room. Cords from that modem go to my computer and to 2 other computers elsewhere in the house. The adaptor...
Too much things is connected thru that wall. The outlet is being use to pull more current that its normal use or that it can handle hence running different ports hot which will cause problems in the near. Somthing will get too much current & blow up !
Recommend that you chose a outlet for the adapter.
Get bac @ me!
KJ
Apr 22, 2008 | Computers & Internet
2wire 1800hg wireless gateway/router not functioning...
Your power adaptor might be faulty.  Yes, you can measure to have 6 volts.  But due to faulty electronic component in the power adaptor, the 6 volts will be dropped to a very low level due to "loading effect"  when you connect to the router.
I had the same problem but could not find the original power adaptor.  I replaced it with a 3rd party power adaptor.  You must ensure that the 3rd party power adaptor can provide 6V output with minimum 2000mA (2 amperes) and correct connector size.
Apr 07, 2008 | 2wire 1800HG Router (RG1800HG00)
Power supply Adaptor
Just to be sure, is it the power supply that is faulty, or the harddrive 'case'?
If you have a separate power supply, you can find a new one for something like 15-20$
/michael
why pay for software?
Dec 18, 2007 | Seagate (ST3100203U2-RK) (ST3100203U2RK)...
Nintendo Wii Console Logo
47 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
