Question about Dell OptiPlex GX260 PC Desktop
My dell gx260 powers up but gives no output on monitor and the LED indicator light at rear labelled D shows orange instead of green like the other LED. How do I fix this?
    Problem Solver:
  • 6 Answers
Chk to see if u have the right chipset or driver installed for ur video
Posted on May 03, 2010
My Dell Optiplex gx260 Pentium 4 Flat CPU doesn't Display anything, and Power light is Orange.. Please help me out
You say the power light is orange--I'm assuming that you mean the monitor.
This indicates the monitor is not receiving a signal from the computer.
Assuming that the computer actually powers up (fan runs, you can hear the hard drive being accessed, etc) then your problem lies in the video card.
If, on startup, you do see the BIOS info and maybe even the Windows splash screen before your monitor goes dark, then the problem lies in the video card drivers. In this case, starting in safe mode will work and allow you to download and install new drivers.
Aug 27, 2011 | Dell OptiPlex GX260 PC Desktop
My dell gx260 ligth come green if i turn it on but for a few mins time it turn orange why
Do you mean the monitor's power light starts green and then turns orange when you turn it on? Most monitors will go to a power saving mode when they do not get a signal from the computer.
The Dell GX260 has a green power light when on. When the computer is off, the light is off. If it is green and blinking, then the computer is in a power saving mode.
Diagnosis: start with the obvious: is the monitor cable plugged into both the computer and the monitor (if not permanently connected to the monitor)? Are you connected to the active port? (You can add a video graphics card in most desktops. The motherboard video port usually needs to be disabled to use the card ports. If you plug in the monitor cable to the disabled port, it won't work.) Is the monitor set to the correct input? (This applies if the monitor has several ports. In that case, there will be a Source or Input button on the monitor.) Is the computer on? The GX260 has the power button on the front. (Other computers have the power button on the top.) There is also the power supply switch on the back which needs to be on.
Next try a different data cable between the monitor and the computer (if you can). Try a different monitor. If a second monitor works, than the monitor has a damaged main board. If the second monitor doesn't work, then the video graphics adapter has probably failed. Replace the add-on card, if in use, then boot in the safe mode to remove the old graphics driver. Then install the correct driver for the graphics adapter.
Note: the computer and the monitor should both be off when you connect the cables. Then turn on the monitor first and set it to the correct source before turning on the computer.)
I hope this helps.
Aug 21, 2011 | Dell OptiPlex GX260 PC Desktop
Start button flashing
It depends on the color, if it's green or amber. This may indicate the computer is in sleep mode. Press the power button to see if you can turn on the pc. If it doesn't press and hold power button for five seconds. You may give more details. I hope this helps
Mar 10, 2011 | Dell OptiPlex GX260 PC Desktop
The power LED light is orange instead of green and it won't turn on
Hi! for most dell machines if the power led is orange its an indication of a issue with the ram, try to reseat the ram first.if that doesnt work normally for dimension 4600, there are diagnostic lights that are located at the back panel of the machine, they are four bicolor lights(amber and green) You can determine the exact problem by checking these lights and you can interpret them by going to this website: http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/adtshoot.htm#1112886 hope this helps...
Jun 12, 2010 | Dell Dimension 4600 PC Desktop
My dell monitor turns on for 2 seconds then goes black and the green light blinks orange
I assume that you already try this monitor on another PC to verify that the problem is in the monitor, in this case you need to open it up and inspect the fuse, transitors, solder connections on the power/inverter board, see failed Dell monitors here for guide: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 23, 2010 | Dell E173FP 17" LCD Monitor
Dell PC Desktop Optiplex GX260 Doesn't boot
Open up the case and remove any add in cards and memory modules. Try to start up by adding these back one at a time until the unit stops booting normally. The light combination is not one recognised in the user manual so I am guessing you have a non-descript fault with one of your components. Be careful when you open the case as to not disturb the ribbon to the motherboard which controls the power, I have had a very long experience trying to get one of these reconnected!
Dec 15, 2008 | Dell OptiPlex GX260 PC Desktop
Dell optiplex gx260
Reference the Power LED States
Dell OptiPlex and Dimension computers and Dell Precision workstations have incorporated the use of the multi-state power button LED as a hardware status indicator. The power button LED illuminates in two different colors and can also blink, which allows for indication of five different system operation states. (Table 1)
LED State
System State
Steady Yellow The power supply is functioning, but the system is not processing data. This may indicate an issue with the system board or CPU. Blinking Yellow The power supply is receiving power from the source but is unable to properly distribute it to the components. This may indicate a power supply problem. Steady Green This generally indicates that the system is functioning normally. However, if problems are detected with installed components, the system may initiate a beep code. Blinking Green The system is in a Standby ACPI state. Off The system power is off.
Feb 24, 2008 | Dell OptiPlex GX260 PC Desktop
Optiplex GX260 won't boot
I had the same issue and accidentally discovered a temporary solution. Unplug the power from the back of the machine, open the case and unplug the ATX power connection from the motherboard. With the ATX cable unplugged, plug the power cord back in. When you try to turn the computer back on the power light should turn orange and fans should be spinning, with it powered on plug the ATX connector back in. That should turn the computer off. Turn it back on and it should boot fine. You can even shutdown and restart, but when the power is unplugged you will have to go thru the same process to get it back up. This sounds crazy but it worked on mine. Good Luck!
Nov 01, 2007 | Dell OptiPlex GX260 PC Desktop
Neovo x17a monitor
Are the settings on the video output correct? Is there a green or orange light illuminated. There is a difference between the Power LED and the Signal LED which is green. If you have no signal the LED will remain orange or yellow but not green. If the LED is green, then a signal is getting from the PC but not necessarily good. Check the signal with another monitor or TV if you can. Check the cable.
Aug 15, 2007 | Neovo AG 17" LCD Monitor
Dell OptiPlex GX260 PC Desktop Logo
176 people viewed this question
Alun Cox
