Question about Sony Playstation 3 (PS3) Console
I turn the power on and then it turns off right
Power won't stay on even long enough to get a disc out.
2 Suggested Answers
  • 387 Answers
SOURCE: my ps3 will automatically shutdown
Yellow light of death. Here's a link to my step-by-step instructions on how to fix the problem.
http://www.fixya.com/support/t8396931-ps3_turns_ok_but_turns_itself_off_after
Posted on Sep 15, 2011
Sylvania Flat Screen will not stay on...turns on then turns right back off. Won't even stay on long enough to get the menu up. What do I do??
THIS IS CALLED SHUTDOWN---SET tries to make it on but detects an issue or problem ---anything from the power supply (first thing to check) to any board in the set that might be causing this--power supply first.
Nov 07, 2012 | JVC LT-42X579 42 in. LCD TV
2004 Ford Explore won't turn over
whilst you are trying to jump start it check if you jump leads are good and powerful enough to sent the power to your battery,check if your battery terminals are clean enough to accept the power given,or is your battery not completely dead and even you are boosting has not the power to increase the needing one to start and is just for lights only?
Sep 17, 2012 | 2004 Ford Explorer
My weslo momentum 7.0 ex elliptical machine display stopped working. It won't power on even with new batteries.
Removethe bolts or screws securing the console to the upright assembly. Lift theconsole and confirm that the cable connections are secure. Remove the coverfrom the console's battery bay and install a fresh set of batteries. Replacethe battery cover.2
Detachthe ends of the pedals from the crank axles. Remove the left and right discshields and side shields. Inspect the interior of the base unit and locate theflywheel.3
Inspectthe flywheel as it turns. Locate the magnet installed on the flywheel. Turn theflywheel until the magnet passes in front of the nearby reed switch. Loosen thescrew securing the switch in place. Rotate the switch to reduce the gap betweenit and the magnet. Tighten the screw.4
Replacethe left and right disc shields and side shields. Reattach the ends of the pedalsto the crank axles.
ernesto cuadramanagua, nicaragua
Mar 07, 2012 | Exercise & Fitness
Tv won't turn on. It turned off after a few minutes and won't turn back on. We opened it up and replaced the fuse.Didn't change anything. A friend said that it just seems to not be getting any...
does the power light flash three times slowly then stay off? If so chances are its just the CP150, cp120 and CP114 capacitors. There is the RCA repair kit by that same name available from www.tvrepairworld.com which has the capacitors and the CD with repair instructions
Oct 25, 2011 | RCA HD52W56 52" Rear Projection HDTV
Ps3 won't stay on
take the disc out before you turn the system off
Sep 13, 2009 | Sony Playstation 3 (PS3) Console
Won't stay on, every time i turn it on the red light flashes red, and orange, won"t eject disc either.
This is a common problem with the PS3, you should try to return it to where you got it, or make sure that the power connector you're using is the correct one, because even though you may be using one that is similar in size to the original, it may not support the voltage needed to power the system up.
Aug 13, 2009 | Sony Playstation 3 (PS3) Console
PS3 will not read discs
you can try to clean the laser and see if you are lucky enough to have that fix it. but usually it means your laser is shot and needs replaced. the laser is pretty pricey but it is pretty simple to replace.
Jul 29, 2009 | Video Game Consoles & Games
Green power light comes on for a split second, then red.
The power supply (AC adapter) is bad. It has enough power to light the red LED, but not enough to power the TV.http://shop.ebay.com/?_from=R40&_trksid=m38&_nkw=12+volt+5+amp+power+supply&_sacat=See-All-Categories
May 23, 2009 | Proscan 19LA25Q 19 in. LCD Television
Power button failure
  • Power Light Shuts Off
    If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
  • Power Light Flashes
    If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair
  • Sep 11, 2008 | Nintendo GameCube Console
    Sony Playstation 3 (PS3) Console Logo
    12 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    marley mcelhinney
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
