Question about HP LaserJet 2840 Printer
I am trying to initialize a new drum. An error message is displaying :Supply Error 10.1004 - what does this mean??
  • HP Master
  • 6,993 Answers
The error code means: E-label can’t be read or print cartridge is not properly installed.
Reinstall print cartridge and try again.
If problem still persists, open the cartridge door and make sure that the correct print-cartridge slot is in the access position.
I believe the error came as a result of the new printer drum you are trying to install.
So check again, and make sure you fix the right part at the right position. Also make sure you are installing the right printer drum.
Good luck.
Posted on May 03, 2010
Printer Supply Error 10.1004
This kind of error are cause for a toner cartridge, install a new HP toner, a your problem go.
Jan 12, 2014 | HP LaserJet 2840 Printer
System error code 070010
07-00-10 error code refers to a drop out voltage warning,
basically this means something in the machine is shorting the power supply out,
the chance's are that the fault lies with the trailing cable where the laquer and white coating eventually wears down to reveal bare trailing cable connections which short to ground causing the power supply to temporarily shut down causing the formatter to display the error.
this is a very old model now and the chances of you being abble to order 'new' have allready gone. I would recommend upgrading to a newer model.
Nov 07, 2013 | HP DesignJet 750c plus InkJet Printer
Problem with the Samsung Washing Machines The machine keeps coming up with the message HEI 10x
Here is a list of errors for your machine.
I hope they help you.
SAMSUNG WASHING MACHINES, ERROR FUNCTIONS
When an error occurs, the alarm noise will sound and the error code displayed in the program window. Listed below is a series of error codes you may or may not see for your model of Samsng Washing Machine. The errors are shown as blinking in O.5 second intervals until the error status has cleared. In this case, all the driving devices are turned off until the error is cleared.
1. WATER SUPPLY ERROR - Display shows 4E.
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
2. WATER DRAIN ERROR - Display shows 5E.
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
3. OVER-FLOW ERROR - Display shows oE.
Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER switch OFF. Water is drained prior to POWER switch OFF. The tub is drained for 2 minutes if a frequency of more than 25 KHz is detected.
4. UNBALANCE ERROR - Display shows UE.
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
5. WATER HEATER ERROR - Display shows HE, HE1.
HE, HE1 is displayed if the water temperature rises by 7 C or more in 1 Min or by 2 C or less 20 Min after heating process has started. The error can be cleared by turning POWER switch OFF.
6. WATER PRESSURE SWITCH ERROR - Display shows 1 E.
* Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz
High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
7. ABNORMAL WATER TEMPERATURE ERROR- Display shows cE.
e.g. If the water temperature is 50 C or more, during a Delicate or Wool cycle.
At the time of initial water supply, if the water temperature is not appropriate, the display will show cE. This error can be cleared by POWER SWITCH OFF.
8. WATER LEAKAGE ERROR - Display shows 11 E.
Water Leakage error occurs when the water drains naturally, (by leakage) after the washing program starts.
9. THERMISTOR ERROR - Display shows tE
Nov 21, 2010 | Washing Machines
LaserJet 2840 Printer: I am trying to initialize a new drum. An error mes...
This means that the printer cannot read the E-Label on the cartridge, or it is not properly installed.
  1. Reinstalle the cartridge
  2. Power cycle the device
  3. If the problem is not solved, replace the cartridge. (Is the cartridge a remanufactured one? this can be a problem)
  4. Check if correct cartridge type.
May 10, 2010 | HP LaserJet 2840 Printer
Drum error. dont have user guide. how do i troubleshoot? tried replacing drum but still says drum error.
If the drum is used up you open the front door and press menu or options and tell it it's a new drum, otherwise you clean the metal contacts on the sides of the drum and inside the printer, and run the blue tab back and forth about 20 times. If still drum error you may have a bad power supply.
Jan 30, 2010 | Brother MFC 7840W Printer
Brother DCP 7020 display reads "Drum Error" and instructs me to clean corona wire which I did. I then bought a new drum and still get the same message.
You need to reset after a new drum, open the front door and press menu or options and it will ask if it's a new drum. after that if you still have the error, you may need a new power supply PCB.
Dec 29, 2009 | Brother DCP-7020 All-In-One Laser Printer
BROTHER DCP 8040 MULTIFUNCTION HAS AN ERROR MESSAGE: 7A. How do I fix it?
This error means that the Main motor is not synchronising with the reference clock.
This can be caused by several things...
  1. Could be a faulty motor.
  2. A faulty Engine Circuit Boaard.
  3. Fault on the Main PCB.
  4. A siezed Drum unit.
  5. Something seized up in the drive train.
Try to get it to start up with the Drum unit removed, if it does the initial rotations OK with no Drum unit installed, then try a new Drum unit.
Failing that, you will need to dismantle and inspect all the drive train and motor assemblies.
Good luck.
Dec 27, 2009 | Brother DCP-8040 Copier
Newly set-up Brother color laser printer displays drum error.
The slides you are moving are for the drum units, you could try using canned air to blow in the same area that the sliders slide across, if that doesn't help you may need a new drum unit..
Aug 21, 2009 | Brother DCP-9040CN Laser Printer
Error message E078 on Canon MF 8100 series after replacing drum
try to check your connection form your printer and if possible try reinstall the printer driver then try to run again the printer.
Jun 16, 2009 | Laser Canon imageCLASS 8180C Multifunction...
Error E078 Canon MF8180c
I have a Canon Color Image Class MF 8180C with a system error code E078 - Trying to understand what it means and how to clear. Any ideas?
Jun 05, 2009 | Laser Canon imageCLASS 8180C Multifunction...
HP LaserJet 2840 Printer Logo
Seeker5211
Seeker5211
