I am a medical transcriptionist. I need a DA-127D model dial-in transcriber but cannot din one anywhere, used or new. Is there any other website I can look. These are expensive new, around $359.75, on up.
    Guru:
  • 731 Answers
There are no used ones available online, the new ones are expensive as you said
http://www.dictationwarehouse.com/DA127Ddetail.asp
Regards,
Riztech
Posted on May 03, 2010
How to fix buzzing in transcriber
Possibly the head has contacted dust particles, causing the buzz sound, try using a swab to clean the head.
Feb 02, 2015 | Panasonic Rr-830 Standard Cassette...
Olympus DSS Player Pro Woes!
Could it be that the files are just being regularly accessed by one of the server admin tools and the DSS Player application interprets an open file as 'being transcribed'
What happens when a copy of a .DSS file is made to an operators machine and then loaded locally for transcription?
Oct 21, 2007 | Olympus DS-40 Digital Voice Recorder
I have a brand new Sony BM-850T2 destop transcriber. Right out of the box, when you use the foot petal to reverse, pick up your foot the tape continues to reverse. The lever that you use to set the number...
This Sony model has a scan feature that reads index info on the tape. If the tape is recorded on a non Sony unit, you may have this issue. To turn this off, Hold both the Stop and Reset buttons together for about 5 seconds. The display will now only show the counter, no indexs, and your problem should be resolved. If you lose power, you will need to do this again.
Sep 16, 2011 | Sony Audio Players & Recorders
Nu gasesc driver ptr placa e baza si mi se misca in reluare totul !
Du-te aici
http://support.asus.com/download/download.aspx?SLanguage=en-us
in stinga sus pune modelul - P5VD2-VM SE - si da clic. Dupa aia da din nou clic pe model. Dupa aia selecteaza Windowsu tau. Dupa aia trage toate driverele si ardele pe un disc ca sa le ai de rezerva. Acum pune discul in pc si instaleazale.
Oct 03, 2010 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
My m key doesn't work on my mac computer. now i have to copy/paste the m when i need it. any suggestions
Ah, the dreaded "M" key. When I was a medical transcriptionist, my "M" key always stuck, and I had a doctor who dictated "dominant mass," so quite often it came out "dominant ***." Sometimes I caught it, sometimes....
With your computer turned off, try to use a can of dust remover (can of air) which will help to clean between the keys. (Swabbing with alcohol will also help to clean them.)
If none of that works, gently remove the "M" key from the keyboard, and you'll see a little spring. Stretch that a little and then put the "M" key back on. That should help.
Jul 09, 2009 | Central Music Company M-Key Keyboard
I have a Iomega 250GBExternal hard drive. The pins that connect to the hard drive via the adapter pack have broken. The serial number is 579233448 the model no is DA-30C03 and the p/N is 31426900. I wanted...
i have the same probleme . I have a Iomega 250GBExternal hard drive. The pins that connect to the hard drive via the adapter pack have broken. The serial number is 579233448 the model no is DA-30C03 and the p/N is 31426900. I wanted to know which is the correct product to buy please
Sep 08, 2008 | Iomega (33090) 250 GB Hard Drive
Panasonic RR-830 only rewinds and fast-forwards, will not play
If the foot pedal is pluged in, press the play button and then you should be able to activate it with the pedal.
Jul 30, 2008 | Panasonic RR-830 Desktop Cassette...
LANIER LX231 WITH LANIER VTI LX547
We use this equipment in remote locations and have found that the type of phone needs to be a centrex line, such as is used on a fax machine. Note: in the past, we used to have to use an "analog" phone line, which is just a normal phone line.
You probably have two different phone lines involved here.
Jun 12, 2008 | Lanier Audio Players & Recorders
Dictaphone MicWiz
Catherine, did you ever get an answer for your problem with MicWiz? I am a transcriptionist that works from home and they are having problems getting it to recognize my foot pedal (as well as another MT) with the new software. It is recognized by Express Scribe and ever other system we use, but not Merge.
Thank you, Cindy
Apr 23, 2008 | Dictaphone 2740 Desktop Cassette...
55 people viewed this question
 Grubhead
Grubhead
