Question about Mansfield Plumbing Products MANSFIELD 3/8" CORDLESS DUAL DRILL AS SEEN ON TV 18 volts 0-550 RPMs
MANSFIELD TOILET KEEP LEAKING
My Mansfield toilet keep leaking water and very frequently the water need to be replenished. So, I replaced reddish color value seal. (This worked on my other Mansfield toilet.) However, the water leak (internal) did not stop. Should I change the black O-rings (2)? I don't think this will be helpful because there is no inside to outside leak. Please help. Thank you.
    Problem Solver:
  • 10 Answers
I'm not exactly sure where the seals are that you are describing. I'm thinking that you might need to shut the water off, unbolt the toilet from the floor, and replace the big wax toilet gasket underneath.
That's the main seal for internal plumbing in the toilet, unless you're talking about the toilet leaking into itself and wasting water. In that case you might need to simply adjust the mechanism (float, flapper valve etc.) to get the right setup.
I'm not sure I completely understand your problem though.
I hope this has helped anyway.
Lyle
Posted on May 03, 2010
I have a mansfield toilet and after flushing it keeps running, how can I fix that?
Not sure about your brand but many toilets have a flapper valve inside the tank which needs adjusting or replacing. Try this U tube link
How To Repair Mansfield Toilet
Apr 06, 2015 | Home
Running toilet.
Bad float valve or water leaking by the flapper or whatever the handle is connected to that initiates the flush...
Mar 11, 2014 | Mansfield Summit 3 Tank Only 386-WHT -...
Replacing fill valves in mansfield 160 toilet
If this is the standard manfield 160 toilet I recommend replacing the fill valve with a Fluidmaster 400a. They are easy to install and adjust , and work very well.I have installed hundreds of these and have had zero problems. Hope this helps.
Sep 11, 2010 | Mansfield Plumbing Products Mansfield...
I have a quantum toilet that flushes normally but then syphons the water from the bowl Possible problem?
Look for your main plumbing vent that goes out your roof, is it pluged with a nest or something? When your drain system drains, it needs outside air from the vent to keep the system from vaccume lock. Same as vapor lock in the gas line on your vehicle. If the system is'nt getting air it will **** the water from the traps in your drain system like it is doing in your toilet. You may have to have a professional drain cleaner or plumber correct your pluged vent.
Feb 27, 2010 | Mansfield Plumbing Products Mansfield...
Leaky toilet
The tank will unbolt and can be removed to replace this seal.
Better yet for about $130 you can have a 1.6 LF new in box and start saving water.
Hope this tip helps.
R/
David
Jan 25, 2010 | Mansfield Plumbing Products Mansfield...
The flush valve gasket is leaking so the toilet water runs periodically
You prbably just need a new flapper valve. Buy one at Home Depot for a few bucks and it will, simply, snap into place at the base of the tank. Also, make sure that the chain is not too tight and cut off any excess chain after the flapper is installed.
Oct 26, 2009 | Mansfield Plumbing Products Mansfield...
Leaking under the rim of the toilet
Sound like what you are looking at is a corroded bolt that holds the tank onto the bowl. Remove and replace bolt and gasket with new part.
Jun 07, 2009 | Mansfield Plumbing Products Mansfield...
Mansfield Plumbing Products MANSFIELD 3/8" CORDLESS DUAL DRILL AS SEEN ON TV 18 volts 0-550 RPMs Logo
934 people viewed this question
Top Mansfield Drills Experts
Are you a Mansfield Drill Expert? Answer questions, earn points and help others
