What is a faulty door switch - Washing Machines
  • a_lauaki May 03, 2010
    yes that was really helpful. its basically a sensor that tells the brain to go ahead and start or don`t start. door needs to be completly close to start
  • 12,061 Answers
Ok, inside the Door, there is a switch, mechanism, that "Tells" the "Brain" if it is open or closed. Depending on the "State" of the door, the machine, will or will not do certain actions. If need to be replaced it is an easy job. To undertake this task, you need to get a Service Manual, your your exact make and model. When the Door Switch goes faulty, the "Brain" can "Sense" this and will then give an "Error Code" Sometimes it is NOT the switch, but the "Brain" itself, is faulty, the Only way to tell, is to swap out the old switch for a new one, if still "Faulty" then it will be the "Brain" that's faulty instead.
Posted on May 03, 2010
VOLVO 2000 S80 BOTH REAR DOOR LOCKS DON'T WORK WHEN I TRY TO USE THE KEY FROM THE OUTSIDE OR THE BUTTON ON THE DRIVER'S DOOR.
flat battery in the fob
broken power wire between the door hinges
faulty door lock actuators
faulty master control switches
or faulty door switches at the doors
Oct 11, 2016 | Volvo S80 Cars & Trucks
Interior door light stays on
Door switch stuck open or broken. Spray switch with wd40 to free it if it's stuck, replace if broken
Oct 23, 2014 | 2004 Volkswagen New Beetle Convertible
What does e 62 error code refer to?
E62: Overheating during washing this is real ans now iam giving u more tips abt error -
E11: Difficulty in filling during wash phase
E13: Water leakage.
E21: Difficulties in draining .
E23: Malfunction of drain pump triac.
E24: «sensing» circuit of the component (triac) that controls the drain pump faulty
E33: Incongruence between closure of anti-boiling and 1st level contacts of pressure switch
E35: Water level too high
E36: «sensing» circuit of anti-boiling pressure switch faulty
E37: «sensing» circuit of 1st level pressure switch faulty
E39: "HV" «sensing» circuit of anti-overflow pressure switch faulty
E40: Door open, Interlock, wiring or main PCB
E41: Door open
E41: Problems with aperture of door
E42: Problems with aperture of the door
E43: Problems with the triac which actions the door interlock
E44: Door closure «sensing» circuit faulty
E45: Problems with the «sensing» circuit of the triac that actions the door interlock
E51: Motor power triac short-circuited
E52: No signal from the motor tachymetric genetaror
E52: No signal from the tachymetric generator
Procedure for checking commutator motors
E53: Problems with the «sensing» circuit of the triac which powers the motor
E54: Motor relay contacts sticking
E61: Insufficient heating during washing
E66: The contacts of the heating element power relay are always closed
E71: NTC washing sensor faulty.
E82: Error in reading the RESET/OFF position of the programme selector.
E83: Error in reading the programme selector code
E93: Incorrect machine configuration.
E94: Incorrect configuration of washing cycle
E95: Communications error between microprocessor and the EEPROM
E96: Incongruence between control panel version and configuration data
E97: Incongruence between selector version and configuration data
EA1: Drum positioning system (DSP) faulty (top-loaders only)
EB1: Incorrect mains frequency
EB2: Mains voltage too high
EB3: Mains voltage too low
E32 INCORRECT CALIBRATION OF ANALOGIC (ELECTRONIC) PRESSURE SWITCH. IF THE MACHINE IS DRAINING OK, THEN IT IS THE SWITCH
E32 relates to the electronic pressure switch, normal pressure switch,inlet valves,poor water mains pressure and finally the main control board
E90 means theres a fault on the main control module so A;will need a new control module or B; get an engineer to try re-configureing the module
May 16, 2011 | Hoover Washing Machines
FL keeps coming up on machine
The "FL" is indicating that the door has failed to lock or it locked but the control does not sense the door has locked.
It could be caused by:
  • faulty door lock solenoid
  • loose wire connection
  • faulty door lock switch
  • faulty door lock sense switch
  • bad control board
Apr 17, 2011 | Maytag Neptune MAH5500B Front Load Washer
Doorlocks dont work except from passenger side. mirrors dont work. windows dont work from anywhere
First, check all fuses to make sure that none are blown.
If the door lock switch works on the passenger side, then the drivers side door lock switch is probably faulty. Use a multi-meter to test the Drivers Side Door Lock Switch (Black and Pink/Light Green wires unlock the vehicle, and the Black and Pink/Yellow wires lock the vehicle)
If the switch is tested and found to be operating properly, you may have a faulty Body Security Module or Drivers Side Door Lock Actuator.
If neither of your Power Mirrors are working, you probably have a faulty Exterior Rear View Mirror Switch, Power Mirror Module, or blown Central Junction Box Fuse.
If none of your Power Windows are working, you probably have a faulty Accessory Delay Relay or a blown fuse in your Central Junction Box or a faulty Master Window Adjust Switch (all of the Power Window Switches feed through this Master Window Switch). If the Power Windows didn't stop working at the same time, you may have faulty Window Adjust Switches, or faulty Power Window Motors, this is very unlikely though. It would also be a good idea to inspect the wiring for any obvious damage.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 15, 2011 | 2005 Ford F-150
The door ajar keeps going off
Hi!!
Check all the door switches, one of your doors is not shutting tight or the switch is faulty. While sombody is in the driver's seat with the motor running, push and pull the door to detect the faulty door switch. Once you find faulty door, open it up and press switch to find out if it is the switch or the door latch needs adjustment. Usually the sliding side door is the one with this type of problem.
Don't forget to rate this answer, Good Luck.
Apr 30, 2010 | 1998 Ford Windstar
Machine keeps stopping and showing fo5
ALARM CODES
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
Oct 22, 2009 | Washing Machines
Washing machine keeps stopping mid wash and coming up error (32 motor surrisc) zanussi keeps stopping and reporting E32 as a fault, how do i fix this?
Hello
ALARM CODES
E33
switch 1
--- Cycle blocked
(door open) 8.32
(door open) 8.33
Regards David Marsh
Feb 26, 2009 | Zanussi ZWF1430W Front Load Washer
Door open light stays on when door shut.
sounds like a faulty door switch not sensing that the door is shut. test the switches for continuity to determine the faulty switch
Jan 27, 2009 | KitchenAid KUDS24SE Built-in Dishwasher
Error codes
Hello ALARM CODES Alarm code Description of fault User code Effect E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2 E12 Problems with water fill in drying E10 Cycle PAUSED 8.3 E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4 E22 Problems with water drain during drying or drying condenser blocked E20 Heating phase skipped 8.5 E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked with door closed 8.6 E32 Incorrect calibration of analogic (electronic) pressure switch --- Cycle PAUSED 8.7 E33 Incongruency between level of analogic (electronic) pressure switch and level of anti-boiling pressure switch 1 --- Cycle blocked with door closed 8.8 E34 Incongruency between level of electronic pressure switch and level of anti-boiling pressure switch 2 --- Cycle blocked with door closed 8.9 E35 Water level too high --- Cycle blocked with door closed and water drain 8.10 E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked with door closed 8.11 E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked with door closed 8.11 E38 Pressure chamber blocked --- Heating phase skipped 8.12 E41 Door open E40 Cycle PAUSED 8.13-14 E42 Problems with door closure E40 Cycle PAUSED 8.15-16 E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18 E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19 E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked with door closed 8.19 E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door closed (after 5 attempts) 8.20 E52 No signal from tachometric generator --- Cycle blocked with door closed (after 5 attempts) 8.21-22 E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked with door closed 8.23 E54 Relays (motor) contacts faulty --- Cycle blocked with door closed (after 5 attempts) 8.23 E61 Insufficient heating during washing --- Heating phase skipped 8.24 E62 Overheating during washing --- Drain, end of cycle 8.25 E63 Insufficient heating during drying Heating phase skipped 8.26 E64 Overheating during drying --- Heating phase skipped 8.27 E66 Power relay to heating element faulty --- Drain, end of cycle 8.28 E71 NTC wash sensor faulty --- Heating phase skipped 8.29 E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30 E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31 E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle (door open) 8.32 E85 Circulation pump faulty --- Drain, end of cycle (door open) 8.33 E91 Communications error between main PCB and user interface --- --- 8.34 E93 Configuration error E90 Cycle blocked 8.34 E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34 EF1 Drain filter blocked LED-EF0 --- 8.35 EF2 Excessive detergent LED-EF0 --- 8.35 Regards David Marsh
May 06, 2007 | Zanussi ZWD1470W Front Load Washer / Dryer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
