Question about Kenmore 24032\24036 Top Load Washer
Washer Washing machine pumps the water out while in the wash cycle.Then stops to refill to proper level and then continues to pump water out while in wash cycle.
  • robin L Mar 25, 2008
    I've replaced practically everything in the washer in the past.
    Sergeant:
  • 351 Answers
Sounds like the water isnt shutting off once it starts washing,check the valve assy or may have a timer fault,try turning off the taps once it starts washing and see what happens if it starts pumping then timer?
Posted on Mar 26, 2008
How to stop the water?
Not knowing what brand / model you have makes it difficult however, the basic symptoms of a water problem are; If the water keeps coming into the machine with the power off and the tap on, it will be a valve fault. If the water keeps coming in with power on and on a wash cycle, its likely to be a fault with the pressure switch, pressure tube (Split or hanging off) or an electronic failure of the control board.Lastly, check the drain hose. If the end of the hose is lower than the water level of the machine, it is possible for the machine to start syphoning itself. Espe3cially just after the first pump out (Start of Rinse cycle) Make sure the machine is actually pumping water out. If it cant pump out, the machine may try to refill but it is already still full from last wash , causing the error code to flash. Check for pump jamming up with foreign objects, or hoses blocked with a sock, lint etc.. Sorry but cant help much more than this.
Sep 02, 2014 | Washing Machines
Washer does not spin. Tried to start cycle over
If you are getting this code it is because your washing machine has tried for at least ten minutes to drain the water out of the machine. The most likely cause of this problem is that you have a plugged pump filter or you have something stuck in the pump filter.Make sure that you unplug your washing machine.To clean out the pump filter you must empty the washing machine water. The best way to do this is to manually drain the water into a low bucket or basin. Then lay a towel down to catch to remaining small amount of water. Remove the pump filter, clean out any debris, and wash out the filter. Then plug your washer back in and restart the washing machine.Check that your machine is properly leveled. A washer that is too far out of level may not drain properly. Make sure that you are level front to back as well as side to side.This solution will solve your problem
Thank You !!
Jul 26, 2010 | LG Washing Machines
Washer sticks on wash cycle; runs continuosly on spin cycle
That sounds like you have one of them fancy water saving outfits with a diverter valve that dumps the pump water continuosly over the clothes. Weirdest washer I ever saw. Could be the solenoid that opens the drain pump has failed. Don't know too much about em but I do have the service manual. Post your model number for a more precise answer. Whirlpool Catalyst washer manual
Apr 24, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series will agitate but not spin or let water out.
Hi, I know washer had a party, he just need a dancing partner, joking, that's a common problem, when machine is not properly level, you should used spirit level, to level machine, after leveling machine, place both hands on machine, and try to rock it from left to right, forward and backward, and it should not have any play, if there's play adjust legs to compensate, water has to be pumped out first before machine spins, rhere's something wrong with water pump, maybe some fabric stuck in pump impeller, or maybe wires disconnected from water pump, remove back of machine and check connection to water pump, check for kink hoses, visual check, if wire were remove, connect to water pump, you're smart. good luck.
Aug 08, 2009 | Kenmore 24032\24036 Top Load Washer
WILL NOT STOP FILLING
Hello Friend, You either have a bad water level/pressure switch or your water inlet valve is bad. If you unplug the washer from the wall and the water stops filling the washer then it's not the water inlet valve. If it only continues to fill when wash cycle is started then you will need to replace the water level/pressure switch behind control panel. This should solve your problem. Happy to help, Tim.
Jun 30, 2009 | GE WHRE5260E Top Load Washer
LG WM1832CW Front Load Washer
FE means water is overflowing. Check pump filter. Check water level switch and hose. Also check that drain hose isn't too low causing it to refill itself continuously. In any case the drain pump should run for 4 minutes to try and eliminate the extra fill
Dec 28, 2007 | LG WM-2277HW Front Load Washer
Water level drops during wash/rinse cycle
Check the exit hose behind, it should be at least 3 feet from ground level, and not too deep into the wall stand-pipe. You will find a level mark behind the machine......check this out.
Your pump pumps this water OVER this height.
Dec 03, 2007 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
50 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
