Question about HP Computers & Internet
Cleaned fans&insides of tower will not come on now is power wiresinside tower to be plugged in or just loose inside
    Problem Solver:
  • 10 Answers
I suspect that you used compressed air, and that you cleaned the fans by spinning them with the force of the air stream.
For some reason this is bad for the fans, and they can stop working when you do it.
If nothing is happening when you turn on the computer, then you have a problem with a short or a loose wire/plug but if it's only the fans that wont come on, then you'll need to go to a place like Best Buy or some place that sells computer parts and get replacement fans.
Don't use your computer without fans! If you have another computer, you could also look online and find plenty of relatively inexpensive fans.
Take out your old ones, and match them up for size if you buy locally from the store. Otherwise you'll need to measure them in millimeters to know which one to buy.
A lot of the time they don't say what their size is on the fan, but you might have some that do.
It's not a big deal. I've replaced fans that were working fine simply because I wanted bigger fans to remove more heat after upgrading my computer.
Lyle
Posted on May 03, 2010
How do I clean my clean living tower fan?
Usually there would be a few screws in the base that need to be taken out and the outer case pulls out. This will expose the fan and filters inside. Hopefully that will allow you to clean the inside. Would not spray any cleaning agents. Just a light vacuum and wipe with clean moist cloth.
Aug 27, 2014 | Tower Dryers
I want to clean the dust from my tower and blow canned air, but does the blue plug on cord pull straight out ?
Dear bonnie,
Years ago, on a computer tech help site, I read a posting warning against this unless a last resort? It said that if all was well - leave it be! as moving dust from where it has settled could possibly cause a 'short-circuit' & burn out components. Also do not know which cable is "blue plug on cord"? Make sure power is off at wall. The power plug pulls straight out from computer. Other plugs have obvious screws/screw-posts. If you are going to fiddle around inside your box, best practice is to wear an anti-static wrist band attached to metal screw/frame with power OFF at wall but leads still plugged in - (this will ensure that the computer is earthed & your body static - up to 50,000volts! - will not fry any components). I hope that this helps - kind regards - 'b'ye - Bruce.
Jan 01, 2014 | E-Machines eMachines Desktop PC
Grinding noise in tower
Grinding noise in tower If everything on your computer is working fine then it is probaly a fan put your ear in the back of your tower near the power cord and see if you can hear the grinding noise better if you can then your power supply's fan is going out if not its probally one of the inside fans in your tower open up your tower and see if you can find which fan it is if you dont want to do this you should probaly get a tech to look at it it's a pretty cheap fix and it can save your computer from heat dammage
Nov 07, 2009 | Computers & Internet
My lasko tower fan gets power n wont blow air
The bearings on the motor are dry and need oil. It's really not made to be oiled, but you may be able to take it apart and get some oil to the bearings if you want to mess with it.
Jul 22, 2009 | Lasko 48" Xtra Air Tower Fan with Air...
Computer wont turn on or off
power unit PSU dead is there a fan motion ? beware of PSU that sleep in the night ... mine did it and destroyed the syste, also the auto safety may have dumped out and it will not resume unless the system is repaired, could be power or maybe an internal chip Memory short, processor dead, fan stopped inside ... never run without it there may be a loose connection stopped fan . Mike
Jun 13, 2009 | HP Compaq Presario SR1250NX (PJ534AA) PC...
Dust inside the fan
you can remove the topcover and can be cleaned using the brush and or vaccum cleaner/ even blower
Jun 01, 2009 | Seville Classics MSC10166 Tower Fan
Pc wont power up
Is there an on off switch on the back out the computer next to the main power socket? If so move it to the on position.
Check the mains lead and make sure it is firmly inserted in the socket.
When you press the front panel on button and it doosn't boot up and there is no light indicating power, then you have a faulty switch mode power supply.
Remove the switch mode power supply and replace it with a new one with the same wattage or greater wattage.
May 07, 2009 | eMachines D3415 PC Desktop
Cleaning inside the fan
Unplug the unit from the wall for safety. Remove the two screws in the upper hand grip recess (upper back of the unit). The two screws must be completely removed (not just loose and setting in the holes). Once the two screws are out, the back half of the fan cover can be slid downward (some amount of force is needed to unsnap the two halves from each other but be careful since the parts are all plastic and can possibly snap). Once the back is unsnapped from the front, you can lift the back half away from the front half and the inside parts are now accessible. I have found on my fan that it is the top fan shaft / bushing that is causing the squeaking noise that so many have complained about. I have found that periodically lubricating the top shaft/bushing will make the fan sound like new again - for a while. Every 2 - 3 weeks I need to clean (wipe off old lube) and re-apply fresh lube).
Jul 19, 2008 | Bionaire BT45RC Tower Fan
Lasko tower fan with ionizer
Try a can of compressed air. It's impossible to get inside.
Apr 21, 2008 | Lasko 48" Xtra Air Tower Fan with Air...
How to open seville classic fan for cleaning
you can find the manual here. It shows assembly, etc,
https://www.sevilleclassics.com/products.php?pid=339
Mar 31, 2008 | Dryers
Computers & Internet Logo
62 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
