Question about Sony Playstation 3 (PS3) Console
System is saying the hard drive is corrupted - Sony Playstation 3 (PS3) Console
    President:
  • 1,469 Answers
You can try the steps below. Its from PlayStation Forum:
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
If after trying the above options and it still does not solve the problem, then maybe the lens is weak and that's why it cannot read any disc.
But if your problem is not still solved, then maybe you should call sony for further assistance.
I wish you good luck.
Posted on May 03, 2010
Only ocationaly rebooting the system. most of the time it says operating system not found.what could be the reason.Please help.My system Fujitsu seimens amilo pro 2065
Hey, either a hard disk corruption or some missing/corrupt files - Solution: Format and reinstall your Operating system. If that doesnt work, maybe you need a hard disk replacement.
But before that, are you sure you haven't connected any USB drives or flash drives or an external hard drive when you computer boots up. That could be the reason. Solution: disconnect any such device before you start your computer.
May 21, 2011 | Fujitsu Siemens Amilo Pro V2065 Laptop...
My ps3 shut down while restoring default & now it says data is corrupt & cannot access hard drive
You are going to have to format your hard drive unfortunately, there is no solution to your problem because by shutting off the system during setting the system back to its default settings you corrupted the data on the hard drive.
Feb 15, 2011 | Sony Video Game Consoles & Games
Playstation 3 (PS3) Console: PS3 KEEP SAY DISK FILE SYSTEM IS CORRUPTED WHAT TO...
Guest
If you are gettting the corrupted drive message this means that you have corrupted data on your hard drive. The link below will help you address this. If you still have trouble then most likely you will need to replace the hard drive.
http://www.fixya.com/support/r4853494-fix_playstation_3_corrupted_hard_drive
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
May 16, 2010 | Sony Playstation 3 (PS3) Console
Hard disk file system corrupt
Bad sector or MBR on Hard drive needs replacing
Mar 21, 2010 | Sony Playstation 3 (PS3) Console
Keep getting amessage saying hard disc corrupted.
Sounds like your hard drive is so badly faulty that it cannot be restored, in all likelihood you will need a replacement drive.
Feb 07, 2010 | Sony Playstation 3 (PS3) Console
Error message that says the hard disk's file system is corrupted
tlatrice_66
If you are getting the corrupted hard drive message this means that you have corrupted data on your hard drive. The link below will help you address this.
Issken
Nov 29, 2009 | Sony Playstation 3 (PS3) Console
System saying hard drive corrupt
bully3724
If you are getting a corrupted hard drive messsage on your PS3 this means that you have some bad data on the hard drive or the drive is bad. The link below will help you address this issue. If you still have trouble then you will need to replace the hard drive.
Issken
Jan 03, 2009 | Sony Playstation 3 (PS3) Console
I start up my computer, I get a black screen that says press F1, after I do that I get a black screen with a message that reads, operating system not functioning
Have you take note the error message about the operating system? does it say a corrupted windows file?
With regard to the error message about F1 to continue, i would say that your hard drive is looking for the operating system. There is a possibility that your operating system is corrupted due a virus infected file or a system file was accidentally deleted from your computer or it could be an issue with your hard drive itself.
You may need to check also if your hard drive is detected by computer. You may call your computer manufacturer if your system still under warranty. In case the hard drive need to be replaced.
I suggesst to run a system diagnostics first to check if the hard drive still functioning before you run windows repair using the operating disc you have with your system.
Keep me posted.
Oct 12, 2008 | HP Computers & Internet
"the hard disk's file system is corrupted and will be restored"
           Ok, it appears that your hard drive in your PS3 is corrupt and needs to be reformatted. You can get an external hard drive enclosure and do it yourself. You would have to take the hard drive out of your PS3 and put it in the external hard drive enclosure and plug that into a computer with the supplied USB cable and format it. From what I'm reading out there, the external hard drive enclosure has to be for SATA 2.5" hard drive.             You could probably replace the hard drive with a larger one just as easy if you wanted to. If you don't feel comfortable with any of this, then its probably repair shop time. I hope this helps.moreover,,Use your recovery disc to reinstall your operating system. This should clean up your hard drive and restore any missing or corrupt files.
Oct 09, 2008 | Sony Playstation 3 (PS3) Console
Disk boot failure
there are multiple reasons for this
1. hard drive failure
solution: replace hard drive reinstall operateing system
2. computer is not set to start from hard drive
solution: enter bios and set computer to start up from hard drive
3. Hard drive not detected or cable loose.
solution: check are the hard drive cables connected well. try disconnecting and then reconnecting.
4. Hard drive file system corrupted and unable to find start up files
solution: you can use the windows xp to enter repair console and try to correct the corruption with chkdsk command if that doesnt work you have to reinstall operateing system
Apr 04, 2008 | Computers & Internet
Sony Playstation 3 (PS3) Console Logo
46 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
