Question about Kenmore Elite HE5t Washer
I plug it in and it won`t turn on - Kenmore Elite HE5t Washer
  • a_lauaki May 03, 2010
    my kenmore elite smart washer he5t won`t start up. i unplugged it then plugged it back in and no lights come on
  • Kenmore Master
  • 12,061 Answers
Http://tutorials-search-engine.com/kenmore-elite-he5t-owners-manual.html
http://washing-machine.110mb.com/free-kenmore-washer-repair-manual.html
coding.derkeiler.com/pdf/Archive/Tcl/comp.lang.../msg00324.pdf
Washing machine repairs
ApplianceRepair.Net
Washing Machine Repair Manual FREE online - DO-IT-YOURSELF
Ok, the top link is your service manual,
If it is new, have you removed the shipping bolts. Check, Fuse/Circuit breaker, check on another power point if can... use these sites and manual to sort your problem
Posted on May 03, 2010
  • 11,896 Answers
A faulty door switch can cause this, You can test it with an ohmmeter. A faulty control panel can also cause this. Also a faulty fuse or power supply which can be tested with a voltmeter to make sure it is getting power.
  • Nate Stansfield
    Nate Stansfield May 03, 2010
    If you have no lights even, then I would start with fuse, then check power supply with a voltmeter. See what the reading is. There should be a label on the machine that says the DC Voltage Output. Make sure the numbers match or are extremely close. Also play with the door switch to see if it makes a difference. You can disconnect the switch and then put an ohmmeter on it. Should be no reading with the door/lid open and get a full resistance reading with door/lid closed.
    You can go to partselect website to view parts and diagrams for free
Engine turns over about 3/4 of turn,won"t start,been running good,new batt,new plugs,new air filter
check and see if you have gas in the oil if you do rebuild carb if not replace starter is bad
Jul 12, 2014 | Garden
Notebook won't turn on
my nb500 netbook wont turn on i slamed it shut now wont turn on
Apr 23, 2012 | Toshiba NB500-12X
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
Truck wont crank. we have put new distributor cap, rotor button, coil pack, plugs, wires, and fuel pump. we also checked our firing order.
you said you repl dist cap that means you don't have a crank sensor you have electronic ing module. remove your elec ing module have it tested most auto parts stores could test your module, or check your coil at the neg terminal. should have power. if not you lost your primary volt from your batt.your secondary power is coming from your electronic ing module from the module to the pos terminal on the coil, when the eng cranks,from the coil to the dist cap , from the dist cap center to the rotor then out to the plugs,this all happen pervided the timing belt or timing chain is ok. the cumbustion chainber needs 3 things , thats fuel, air, and spark.
Apr 17, 2011 | 1996 Chevrolet K1500
Kenmore Elite HE5t Washer Logo
573 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
