Question about Acer Aspire 5050-3242 Notebook
Could anyone tell me how to fix mouse pad of aspire 5310, mouse only work with left click, can not do right click???
  • bay ba May 04, 2010
    Still not working, may be I have to replace mouse pad or cable???, I have checked left or right click properly...... or do I need to install motherboard driver update?? because I just change new mainboard!!
  • bay ba May 18, 2010
    THANK YOU VERY MUCH , I HAVE TRIED AS YOU SHOW BUT DOESN'T WORK, SO I HAVE TO BUY NEW MOUSE PAD, VERY HARD TO FIND??!!
  • 2,069 Answers
Are you sure its not stuck, inside there? check properly. also, try to disable and re-enable the mouse by clicking Ctrl F7.
Posted on May 03, 2010
    President:
  • 1,561 Answers
Take a close look at the Acer laptop mouse buttons. Make sure the exterior of the buttons are clean and that there is no grime around the edges and crevasses of the Acer buttons. Dirt on top of the mouse pad can result in slower performance or an unresponsive experience, while grime around the sides of the mouse buttons can cause problems with the pressing and depressing of the mouse.
Is there any way your mouse pad has been turned off? Check into this possibility. On an Acer laptop, hitting the "Function" (Fn) key and "F7" on the key board will result in the mouse pad being switched off. Hence, you may have hit this function and your mouse pad may not actually be broken or require any repair. Hitting the "Fn" button and the "F8" key on the Acer keyboard will result in the mouse pad being turned back on again.
The above steps may not have worked, so downloading new drivers for your mouse may be necessary. Launch your web browser and go to the official Acer website.
Select your country of origin, then click on "Support." You will be asked to click on your country again. After you do so, click on the link that says "Drivers and Downloads" on the left sidebar.
Select your product line ("Notebooks") as well as your specific Acer computer model, and then hit "Search." Click on the link that says "Touchpad drivers." Your Acer computer may only require new drivers for your mousepad. Download the .exe file and run it to install the contents to your Acer computer.
Restart your Acer computer after fully completing the download and installation process. Once the restart process has completed, the driver installation will be complete and your mouse should work again.
Take care.
Posted on May 04, 2010
  • Sulaimon Jimoh Olayemi May 04, 2010
    You can also install the new motherboard driver, and restart your system after the installation.
TOUCHPAD MOUSE ANS KEYBOARD NOT WORKING
Try these steps.. Click start button, type "mouse" on Search Programs and Files, click "mouse" under control panel. In mouse properties options....as you an see the touch pad driver tab? click it. Choose or click option button and you can enable the right and left click button. About the keyboard problem,,,,,go to device manager, right click the standard PS/2 keyboard..uninstall it. Windows restarting and the keyboard driver will re install automatically.. check if the keyboard works fine.
Aug 17, 2014 | Acer Aspire 3810T 4810T 5810T
Samsung laptop mouse left button
-If me I'll buy a new mouse.
Good luck
Mai
Jun 16, 2017 | Computers & Internet
Mark favorites delete internet
Left hand mouse = tap the bottom left of pad. Right hand mouse - tap bottom right of pad.
Nov 04, 2013 | Acer Aspire One PC Notebook
How do I double right click if I don't use a mouse, I use a touch pad
Notice how the touchpad is laid out. Normally there is the big square area that you slide your finger across to control the mouse pointer. Then either at the top or at the bottom of the touchpad there will be two separated squares that you can click on. They work just like a mouse. the one on the left is a left click, the one on the right is a right click.
Apr 03, 2012 | Acer Aspire 5720 6497 Laptop
How do I do the right click function of a normal mouse on the pad mouse of an acer aspire 4741g laptop which does not have a right click button. I have tried to press and hold the Ctrl key and press the...
On your laptop, directly beneath the touch pad are two oblong buttons. They act as mouse buttons. The left one selects and the right one gives extra options.
Hope that helps.
Feb 03, 2011 | Computers & Internet
My aspire 5310 mouse pad is not working
either your mouse pad is broken or someone or some program has shut off the driver for your touch pad. I would reinstall the drivers and reboot. if that doesnt fix the issue, I would then look into replacing the pad.
Sep 12, 2009 | Acer Aspire 5050-3242 Notebook
Both my keyboard mouse buttons act as right clicks
Hi
Access BIOS settings and search for mouse / peripheral settings, you may find one to activate left and right mobo clicks.
Cheers cbacer
Aug 12, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Mouse touch-pad
Click Start > Control Panel > Mouse > Device Settings (tab) > Settings (right hand side, immediately under the white box with your touch pad device listed)
Select "Tapping" on the left and make sure it is enabled.
If tapping was enabled, go to "Sensitivity" on the left and adjust the touch settings.
Thanks for using the FixYa forums!
Mar 31, 2009 | Acer Aspire One PC Notebook
I have an ACER ASPIRE 4315 laptop. For some unknown reason the right mouse pad button no longer works. Can you please advise me how this might be fixed. The left mouse pad button works fine. When I say...
you may wish to go to the acer website and look up that model... download the driver for the touchpad and buttons again. reinstall that and see if it fixes the issue
Robert
Aug 29, 2008 | Acer Computers & Internet
THE 4-way scroll button IN MY ASPIRE 5100 DOESNT WORK
Double click the icon in the toolbar. Click the device settings tab and then hit setting. select buttons in the list on the left side. Hit the plus sign(maximize) and select scroll up button action....scroll down button action...Etc. For each action select what you want it to do and just hit apply and move to the next. Once you have selected the action for scroll up, down , left, and right hit apply again just to be sure and try it. It should work. I just did it on my 5630 but Im assuming it works the same.
Aug 14, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 5050-3242 Notebook Logo
115 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
