Question about Ericsson SCREEN PROTECTOR MEXXPROTECT Crystal-Clear for Sony W595i, W-595i, 100% fits, Display Prote... Cell Phone
How can i clear puk code - Ericsson SCREEN PROTECTOR MEXXPROTECT Crystal-Clear for Sony W595i, W-595i, 100% fits, Display Prote... Cell Phone
Apa kode PUK untuk nomer telkomsel ***********1 dengan nomer di belakang kartu 0020000004132471
I PUK codes are a sim lock issue and must be cleared by the carrier. Or through your account online. Have you checked with them? Some are non clearable if you entered your pin wrong too many times.
Sep 22, 2015 | Cell Phones
What is the PUK code
its Personal Unlock KEY..........for phone security......actually before PUK u enter sim pin........if wrong pin is entered 5/10 times your sim is locked permanently and sim can only be used after u enter puk code. Please note that pin code is entered by user.....but PUK code is provided by your network service provider company. PUK is generally mentioned on the sim rapper(cover).........in case u have not kept the rapper and u do not know the PUK code and ur phone is asking for it...then please do not try to enter it as too many attempts to enter wrong PUK will lock ur sim for ever and u will have to get a new sim.....so instead of trying a wrong PUK code its better to contact your network service provider (you can call their service number) and he will give u the PUK code for your sim free of cost.
I Hope this clears all your doubts about PUK.
May 21, 2014 | LG Optimus T P509 Android Smartphone, No...
How do you unlock clear sounds telephone
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Aug 11, 2012 | CLEAR SOUNDS Lands Phones
Can you give me a puk code for an LG500g
Hello, welcome to Fixya!
I am not in the position to give you a PUK code. Below is what you need to know and how to retrieve the PUK code required:
When a PIN code is entered wrongly three times, the phone line will be blocked. Irrespective of the owner, it is assumed that you are not the owner of the phone line when you enter your pin wrongly.
The blocked line at this point can still be unblocked and this is where the PUK code comes in. Once you enter the PUK code, your PIN code will be reset. You can then create a new PIN code.
To get your PUK code, if your phone is using a SIM Card, Check the SIM card Pack and you will see your PUK code there. But if you don't have a SIM card pack, you can get the PUK code from your service provider.
Call the customer care line of your service provider using another phone, request for your PUK code and it will be given to you. Note that your service provider will ask you some few questions about your line in order to be sure you are the real owner.
Note that your service provider alone is the only one that can give you your PUK code because it's only your service provider that has it.
I hope the above is clear now. If not clear, please let me know so that I can assist further.
Regards
Nov 03, 2011 | Cell Phones
My phone nokia e63 is saying that the pin code blocked.enter puk code.what do i do
hi.
check the Pack of your SIM Card.
you should find some codes there.
there are Three Static Codes (Pin, PUK,PUK2 codes)
enter pin code for entering to phone or use PUK in order to clear the PIN Code
Jan 30, 2011 | Nokia E63 Cell Phone
How can i get PUK code for my w595??
Puk code means Personal unlocking key and depends on the sim card. When you insert 3 times a wrong ping, the sim card will lock with PUK code. If puk code is entered 10 times wrong your sim card will be unusable until your service provider will replace it with a new one. Only your service provider can provide you the PUK code to unlock your sim.
Nov 14, 2010 | Ericsson SCREEN PROTECTOR MEXXPROTECT...
Puk code?
Puk code retrieval
Well, the first thing you need to realise when you read this, is that your puk code is a personalized code.
This code is unique to your phone, thus, there is no standard code you can type in.
The only way that you can retrieve your code is to have a look on the package which your sim card came in.
Your Puk and default pin should be stated clearly on the card.
Otherwise, you need to call your service provider from a sim which is from the same provider.
This is a toll free number, thus, you will not be charged. Explain to the assistant that you need to retrieve your puk code.
They will ask you your phone number and give you your puk.
Once you have your puk code, you will be able to reset your pin code.
Kind regards
Andrea
Jun 20, 2010 | Siemens A55
My phone is asking for a PUK code. i'm on orange pay monthly
No need to worry at all, this code is Service dependent (SIM card).
As you described your service provider is Orange, so all you have to so is to call on 07973 100 450 (or 450 from some other Orange phone)
Ask them for your code, they will first authenticate few things and will give you the PUK Code in return.
I Hope you have a clear picture now,
Regards, Waqar.
Oct 25, 2009 | Cell Phones
DEFAULT PUK CODE AND PIN CODE FOR N73 ME
No the Default PUK and PIN codes are not set by you, these codes are Service Provider Dependent (SIM)
All you have to so is to call your Service Providers Customer Support (Like of T-Mobile, AT&T...).
And ask them about the PUK and PIN code, they will first Authenticate few things about the Ownership of the SIM card, and will give you the codes, in return.
I Guess, the picture is clear in front of you, Now.
Regards, Waqar.
Sep 20, 2009 | Nokia N73 Cellular Phone
Ericsson SCREEN PROTECTOR MEXXPROTECT Crystal-Clear for Sony  W595i, W-595i, 100% fits, Display Prote... Cell Phone Logo
49 people viewed this question
Top Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you an Ericsson Cell Phone Expert? Answer questions, earn points and help others
