Question about Canon PIXMA MP130 All-In-One InkJet Printer
Paper didn't feed or feeder can't feed paper - Canon PIXMA MP130 All-In-One InkJet Printer
  • Canon Master
  • 3,866 Answers
Replace Feeder sensor its a plastic piect the is a sensor that detects there is apaper in the feeder paper path, when these go bad the thing does not feed, or says your out of paper.
T will probably cost you more to have it repaired then getting a new canon or whatever all in one youe decide to buy.
thanks i hope this information finds your helpful ratings and feedback, have a good day.
Posted on May 03, 2010
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    Put new roll in printer and paper feeds through then goes back out again
    The printer should accept print paper ready for feed commands when computer sends jobs with clicks. A paper feeder tray may be clogged, attempt to open compartments to ascertain for misaligned or adjusted entrapment areas. Paper feeder adjustments that are tightened least allows feeder processing while loosened paper feeder clips allows several print papers at a time. Select the appropriate adjustment for the papers. Second, printers that run out of ink display sensitive malfunctions either as inability to feed paper when available. Ascertain that printer ink is available.
    Jan 28, 2011 | HP PhotoSmart 130 InkJet Printer
    What does load mp feeder letter mean? There is paper in the printer why is the printer not prinint
    load mp feeder means To load the Manual Paper Feeder
    You might have selected the printer settings for manual feeding. Hence you need to feed that papers in manual feeding tray.
    You can change the settings to automatic paper feeding to get rid of this error.
    Aug 27, 2010 | Lexmark Optra T610 Laser Printer
    The paper keeps jamming during feed I have changed it but it still jams, I think there is a fault with the feed section at the bottom but I cant find a manual that shows technical details for repairs so I...
    Did you replace paper feeder with new one? Most paper feeder problem are rubber at paper pick up roller (bottom side) and small spring at bottom paper pick up roller. Check for "something" slip at paper feeder and lubrication at paper feeder mechanic.
    Feb 02, 2010 | Epson Office Equipment & Supplies
    My printer won't feed paper. All of a sudden my printer quit feeding the paper - the error light comes on and states that there is no paper in the feeder - but there is paper in the feeder
    Check the paper feed switch, you have a choice to feed paper from the back or the cassette under the paper exit. Either put paper in both or select the proper source by pressing the feed switch.
    Dec 30, 2009 | Canon Pixma MP500 All-In-One InkJet...
    Printer will not feed paper. Says it out of paper
    are the feeder rollers moving? If so, the paper feeder rollers need to be cleaned.
    Aug 06, 2009 | HP Office Equipment & Supplies
    IBM 1422 not feeding 8 1/2 x 11 paper through multipurpose feeder
    Go into the paper menu and set the multipurpose feeder paper size to letter. It will work if the paper size is set correctly for the MPF.
    Apr 30, 2009 | IBM Infoprint 1422 Laser Printer
    I865 flashing 3 times
    That's a "paper jam" error that can be fixed by removing all paper and pressing the resume/cancel button. Then replace the paper in the feed chute.
    The printer can straighten out a crooked feed to a very limited degree. The photo feeder attachment can interfere with a really full 8x11 feed. The i860 is very susceptible to overfilling the 8 1/2 x11 feeder without notice until you try to print. I usually remove the photo feeder until I need to print photos, and keep the regular paper feeder no more than 3/4 full. I pull out the regular paper when printing photos.
    Feb 24, 2009 | Canon i860 InkJet Photo Printer
    Document feeder works for printing but not for scanning
    Hi, When you had the doucment feed jam were you able to clean or remove any paper that might be blocking the paper to be scanned? It sounds like there is paper still in the document feeder , I would open the DF and check very closely to make sure no paper is in the way!Good Luck!
    Dec 02, 2007 | HP OfficeJet 7310 All-In-One InkJet...
    Canon PIXMA MP130 All-In-One InkJet Printer Logo
    94 people viewed this question
    old marine
    old marine
