Zenith pv5263bt 53
I own a 53" Zenith rear projection t.v. Recently I've been having trouble with the picture going very dark then bright Then dark again and so on. I have no idea what could cause this. please help
  • 59 Answers
If this is a projection TV, first you should check you lamp. Is it good (clear) or bad (foggy). If foggy, you should replace it. If it is good (clear) reseat it back onto the ballast (it just might be loose). If you are still having this problem, you probably need to replace the ballast
Posted on Mar 25, 2008
6ya staff
SOURCE:
1. picture is getting darker 2. there is a green outline when the brightness is turned up
Hello ksolovy, i understood your Problem with the Sony KP-53V90 53 in. Rear Projection Television,In fact i encountered already that kind of problem you have it now. Check first the color wheel im sure that the blue section of your color wheel was burned and the blue color turn to dark; That's why you have seen dark picture, Re-place color wheel.
Dec 21, 2010 | Sony KP-53V90 53" Rear Projection...
BRIGHTNESS ON A Pioneer Pro-520HD REAR PROJECTION TV
Have you attempted to adjust the brightness setting?
Thanks,
Lee
Jul 26, 2008 | Pioneer PRO-520HD 53" Rear Projection...
I have a 1994 zenith big screen the picture is showing really dar
It could be that the picture tubes have gone down on emission, there is a prcedure that can be tried to bring up the overall brightness but it is just possible that you will loose some picture quality. If it's a 1994 projo tv i am thinking of the three crt system, a gray scale alignment would probably correct the dark condition in your picture, again depending on how far gone is the emission in your picture tubes, if your projo tv is the dlp system, the bad news is that you could be needing some light engine repair. The color adjustment is possible with the availability of a service manual or in the case of the dlp system, light engine repairs or replacement are available from some on line stores.
Jan 12, 2010 | Zenith E44W46LCD 44" Rear Projection...
Projection television picture trouble
picture tubes are fine. just need to change out coolant
Oct 26, 2009 | Philips Magnavox 51MP392H Rear Projection...
07 sony 32"hdtv trouble...
sounds like you have a bad lamp maybe a bad color weel to so be careful
May 16, 2009 | Zenith D52WLCD 52" Rear Projection...
My picture is dark and have changed the brightness
Hello!
Well it seems that your lamp is about to go out, replacing the lamp might jus do it ! Also make sure you get a Philips lamps, they work like a charm.
And regarding the long plastic cover just be a little bity patient and you'll make it come off, just make sure you do remove all the screws.
Apr 18, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Hatachi 53FDX01B
The screen drive or filament voltage is low
increase the the screen drive first.
mounted on the flyback transformer.
guy9
Nov 13, 2007 | Hitachi 53FDX01B 53" Rear Projection...
Toshiba 53" Dull Screen. No brightness and Contrast.
I would guess the tubes are going...I would still have serviceman check it out
Oct 20, 2007 | Toshiba 53H71 53 in. Rear Projection...
Darkening tv picture
The Picture tubes(not bulbs) do and probably are weak. There replace should only be done by a trained service person. One reason would be the hI Voltage issues related to the crt's, as these tubes store alot of HI voltage even after its unplugged for a while, and another reason would be that these tube can very easy implode then explode and that wouldnt be a pretty sight. Third would be the alighnment involved after all three tubes are replace. There ba cross hatch generator and alot of time involved with the alighnment. Please seek a pro to assit you when your ready to spend at least 900 TO 1000 bucks. Good Luck
Jun 30, 2006 | Hitachi 53FDX20B 53" Rear Projection...
Televison & Video Logo
100 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
