Question about Breville ESP8XL Espresso Machine
No heat Hi! This is my second Breville Roma machine. First one lasted over 4 years but the second one stopped heating in less than a year. I love the look of it, it's almost new and would like to fix it if possible. Light stays on and even after 10 minutes water remains cold. I've bought it from the same, very reputable store fhere in Montreal Canada but the second one on ebay. Please help... I miss my morning cappuccino. Thanks.
Same problem with mine. There was a burnt connection on the heating block.
To fix this: 1) Unplug!
2) Unscrew top, 5 screws total. 2 on the back near the top, 1 under the water reservoir lid, and 2 up inside long black tubes located on the front two corners of the overhanging section. 3) Remove top, you'll see a large chunk of metal with a lot of wires connected to it. any one of these could be bad, but in all likely hood it's one of the 2 main power wires to the heating block. These are located on the back of the heating block. 2 metal posts with a flat piece if metal welded to each and a spade terminal on over that with either a red or blue wire. (colors may very, but i imagine it's universal)
For me it was the left of these two connections that was bad, the flat piece of metal was burnt and the connection was broken. To fix this I found a small metal clamp and clamped the spade terminal to the flat piece of metal. Soldering probably won't work, because the heating block could get hot enough to melt the solder, so this was the only suitable option. Short of actually removing the heating block and welding a new piece of metal onto the post.
4) Fix broken connection, if there's no obvious broken connection, or discoloration of wires, then it could be a bad heating block. Changing the heating block would be difficult to do safely for the unexperienced, so attempting this isn't suggested.
5) Return top and screws. 6) Make a delicious latte to celebrate
Posted on May 04, 2010
Testimonial: ""Make a delicious latte to celebrate." ... and I'll drink it to your health! :) Thank you. "
  • akenjoy Jun 21, 2011
    I just did this as well (June, 2011). Worked like a charm....Thanks didge87!
  • didge87 Jun 22, 2011
    No Problem! Glad to hear this is helping people, I guess it's a common problem.
Breville Cafe Roma , worked fine, stored for 2 yrs, now it will not pump. Powers on, heats up, but when the switch is placed on water or steam setting, no pumping sound at all, perfectly silent. One...
Just a guess, water is usually like oil (a lubricant) in your pump, so standing 2 years it's "dry" or there is no water being supplied or there is a screen or filter that is plugged.
Possible no power to pump, or an inline fuse or circuit breaker to the pump and heater has blown. Or a temperature safety sensor has disabled power to pump and heater. Owner's manual might help.
Feb 10, 2018 | Breville Coffee Makers & Espresso Machines
My Breville water kettle stopped heating water. This is my second teakettle to do this. We have had this second kettle for about 2 years. We always were careful to make sure the kettle is off before
Unless you can take it apart and repair it yourself, it probably isn't worth the cost to have it repaired. There are several websites that sell parts, but you really have to be familiar with electrical circuits to diagnose it. Possibilities are:
1. It could be the thermostatic switch that turns it off as it reaches temperature. These are little devices with two wires connected and are in the base of the unit. these normally reset themselves but can stop working, especially if they have gotten wet.
2. It could be the cord to the unit with a wire broken at the base or the plug end.
3. It could be a thermal fuse; these are about 1/4 inch in diameter and may be hidden in an insulating sleeve near the element; they are sensitive to both heat and current.
3. It could be the element is burned out.
Link to a parts supplier is enclosed
Breville Kettle Parts
Feb 04, 2015 | Breville Kitchen Appliances - Others
Venezia problem. When I turn it on, the heating light does not come on. After a few seconds, it starts to pump without me having turned the dial at all. Fix?
Hi Matt,
Sorry I don't have a solution for you, but I have just had the same problem with the heating light not coming on and it starting pumping water with me turn the control to pump......
did you get your sorted? If so what was the problem?
Cheers Neil
Oct 19, 2010 | Breville Venezia BES250 Espresso Machine
My breville cafe roma wand is not steaming it is just making air bubbles
Have you tried cleaning out the machine? My steam wand started just spraying out a steady stream of water but was not heating up. I used the cleaning solution CLR (8 parts water, 1 part CLR) and let it run through the steam wand for awhile. At first it just kept streaming out then all of a sudden it stopped. I still kept it on just to see what would happen. After about 10 seconds all of a sudden the steam wand shot out whatever had clogged it and it works perfectly again! I had only used the machine about 10 times before this happened. I had not been cleaning it well after each use back then. Now I definitely do.
Sep 13, 2010 | Breville ESP8XL Espresso Machine
Breville Cafe Roma esp8xl
push down on the water reservoir. ours took a while to prime.
Aug 15, 2009 | Breville ESP8XL Espresso Machine
Espresso Machine Stopped Working
Mine stopped heating (pumped only cold water) and when I opened the top of the machine I noticed that the blue electrical cable to the thermal block assembly (probably to the thermal fuse, but I an not sure about that) corroded and was loose. I fixed the connection and since then the machine heats perfect.
May 12, 2008 | Breville ESP8XL Espresso Machine
No steam, just hot water.
The steam wand has to be removed to be cleaned properly. Unfortunately, this procedure is not outlined in the manual. Just cleaning the wand on the outside or using a clip to clean the tip is not enough.
The other end of steam wand where it connects to the pressuring cabin actually swivels around a fitting. It is this fitting that you need to thoroughly clean. Years of using the machine can cause calcification around this fitting.
If you look under this end of hte steam wand, you should see a philllip-headed screw. Before you loosen this screw, you have to remove the grey trim so that the entire wand can be remove.
Once the entire wand is removed, what I just described will be much clearer.
Nov 10, 2007 | Breville ESP8XL Espresso Machine
Breville ESP8XL Espresso Machine Logo
665 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
