Question about Whirlpool Estate TAWS750PQ 27-Inch Washer
Belt for washer
If the belt is loose how do I tighten the belt or replace it. It looks loose when I proped it up it has play in it. So where do I go from here?
    Genius:
  • 3,587 Answers
The pulley should have a bolt in the middle of it, or an arm, that adjusts the tension..
Posted on Mar 26, 2008
SOURCE:
The agitator on my washer seems to be slipping or stripped. How do I get into it to see if it's loose or needs to be replaced?
On some washers, you may be able to tilt it to look under it. There should be a main rubber belt that drives the agitator and other components, see if there is any slack or looseness in the belt. It should be pretty tight. If it is not, you may look for documentation on how to tighten it or else you might consider a replacement belt in some cases.
Dec 13, 2011 | Whirlpool Washing Machines
Everytime I use my washing machine, I get the E3, then dc messages.. also, my belt (for the spin) seems as if it is slipping and can't turn the washer drum over... Then, after I can't take the running...
You get an error if there is something wrong with your machine, now that your washer drum doesn't turn and you are hearing a noise, the possible cause is that the belt alreadi slipped out, if you have the access of opening the back panel where you can see the inner part of the machine, try to replace yoour belt with a new one and install it, it is easy, it only take an adjustment of the bolts and screw, try not to tighten it too much.., make a little loose so that the belt can play.
Aug 25, 2010 | Samsung WF328AA Front Load Washer
Belt slipping have tried to tighten, just bought used
When the belt slips, it can be 2 different places. The trick is to look at the front roller when the belt slips. If the front roller stops with the walking belt, then the drive belt (between the motor and front roller) is loose and can't be fixed by tightening the walking belt. If the drive belt is slipping, it needs to be tightened or replaced. I need the brand and model number to help you further.
Mar 06, 2010 | Exercise & Fitness
Whirpool duet washer. Drum pulley loose
If the pulley doesn't fit the shaft anymore, it may have sheared a metal key between the shaft and pulley center. If it did, you may have to replace both the key and pulley. If the key is intact and the set-screw is only loose, just tighten the screw and you're home free. Make sure the belt has not been damaged--replace it if so. The belt should be fairly tight when things are back together.
Oct 28, 2009 | Whirlpool GHW9100L Front Load Washer
Our belt came off but we don't know how to put it back on
1. Look and find the pulley tensioner of your
washer, and loosen it up. This is a bolt holding
the motor base,and allow the base to move and
loosen the belt or tighten it.
2. When it is loose, you just put the belt back on the
big pulley track and then, on the small pulley.
3. Full the tensioner back in place to tighten the belt.
Just follow this instruction, and solve your problem.
Sep 28, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
Maytag top load performa, put clothes in , fill up and now the agitator is noisey, looked under washer belt appears to be loose 2-3 inches in play, should I replace belt,or something else to repair noise...
thats normal tension on the belt if the agitator is making noise the cams within the agitator are worn (loud clicking or popping noise during wash) the agitator will need to be replaced
Dec 15, 2008 | Maytag HAV2558 Top Load Washer
Loose Belt Drive
Remove the rear cover on the unit and see if the belt is loose. It should not stretch more than 3/4" when you pull on it. There may be an adjusting bolt on the motor to tighten the belt. Disconnect power before working on the unit!! You should have an owners manual for this unit. Check it for further information.
Ray
Dec 11, 2008 | Kenmore 22422 Top Load Washer
BELT LOOSE ON FRIGIDAIRE WASHER HOW TO TIGHTEN
you can't really tighten a belt, I suggest that you change it, although it is extremely hard to replace a a new belt yourself. Have you checked the carbon brushes in the motor do not need changing, this could also generate a burning smell and leave you clothes wet if they are worn.
Nov 15, 2008 | Frigidaire CWS3600AS Top Load Washer
Washing Machines Logo
81 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
