Question about Sony BRAVIA KDL-52XBR6 LCD TV
How to fix scratches on lcd tv screens what is the best way to fix scratches on a sony kdl52xbr6 tv screen or do I contact Sony directly
  • Sony Master
  • 3,866 Answers
If there deep scratches you need to replace the outter layer and that could get expensive. Now if there small scratches a lcd repair kit would work. You can get those on line for the fraction of the replacment of the lcd screen.
thanks
please do leave feedback and ratings for your free answer today.
Posted on May 03, 2010
Testimonial: "very helpful"
  • Grand Canyon Tech
    Grand Canyon Tech May 08, 2010
    I want to make a additional comment here to correct confusion on what i mean by outter layer. Some lcd have a plastic or glass even that covers the lcd screen (not a part of the lcd itself) That can be replaced not if the scratch is deep on the lcd itself you are going to need to replace that lcd itself. Now if its a small scrtatch or smudge you can try a repair kit.
    I hope this clears up the confusion.
Scratch on screen of LCD TV
Check by wipe the screen with a soft cloth dipped in glycerin.
Dec 09, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I am having the same problem with my 3 yr old 52 inch Bravia HD LCD TV. The right side of screen starts out darker than the left side and then in about 5 minutes it brightens on the right and has...
To be honest, it won't be a cheap repair. You could be looking at an aging backlight inverter or possibly the CCFL bulbs that light your tv are aging as well. The backlight inverter would be nearly $60-$90 and the CCFL bulbs are close to $20 each @ 12-14 of them.
Please rate if this helped :)
Mar 09, 2011 | Sony BRAVIA KDL-52W3000 52 in. LCD...
I have a Sony KDL-52XBR6. It has horizonal lines across the top of the screen. They appear to pulsate. The horizonal lines appear in groups, so that if, let's say, the screen was divided into columns, you...
Based on the information you've provided, I suggest that you update the TV with the latest System Software and check the operation. I've provided a link with the information to download System Software Update:
http://esupport.sony.com/US/perl/news-item.pl?news_id=273&mdl=KDL52XBR6
If the issue is unresolved, please follow the additional steps given below to troubleshoot the issue:
1. Make sure that you have connected the source to the Television properly and securely.
2. Unplug the power cord of the unit from the wall outlet for few minutes, then connect it to a different wall outlet and check the operation.
3. Connect the video source to a different input on the Television and check the operation.
4. Connect a different video source to the Television and check the operation.
5. Replace the connecting cable and check the operation.
6. Reset the TV to factory settings. To reset your TV to factory settings, turn the TV ON. Then, while pressing the UP ARROW or RESET button on the remote control, press the POWER button on the TV. The TV will turn itself OFF then back ON.
Dec 31, 2010 | Sony BRAVIA KDL-52XBR6 LCD TV
My son scratched my screen very bad how do i fix it
Sorry u have to live with it.The very bad scratched on tv screen panel can't be repair.The only way is to replaced the whole tv screen panel and the new screen panel,will cost the same as a new tv.So it not be practical.Because the tv screen panel are limited production by the tv corporations.
Nov 16, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
While i was cleaning my Sony Bravia 40 Inch 1080p Flat panel LCD Screen, it had alot of dust so i used some cloth while i was cleaning it with cloth it made some kind of lines... scratches the scratches...
only use microfiber cloth to clean LCD panels, and no windex. Use 50/50 distilled water and denatured alcohol, or a dedicated LCD cleaner. Small scratches are not worth buffing out as screen itself is relatively soft plastic.
Oct 19, 2010 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
White corners SONY KDL52XBR6
This is called a dark shading error. All the LCD consumer sets have some visible degree of this effect. Some will be a little less or more than others even from the same batch in the assembly run. This has to do with the optical design quality of how the back-plane lamps illuminate the screen. The design and assembly tollerance of this area is very critical.
Normally, LCD screens don't show their best picture in a darkened room. The very black regions of the picture content may look a little washed out. LCD screens are best watched in a room that is lit, but not very bright. You have to consider that there is a powerful set of lights behind the polarized panel of the LCD display, and there will always be some breakthrough of light.
If you want a TV that is more like a CRT in its characteristics a Plasma would have been a good choice. The trade-off with the Plasma is that it does not have the picture sharpness of the LCD. A Plasma set is best watched in a darkened room.
If you have an LCD computer monitor, take a look at it in a dark room with a black screen. You will most likely see the dark shading errors. Only the very expensive production studio type LCD monitors have less of this error than the consumer sets, and they are not absolutely perfect.
Jerry G.
Nov 19, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Scratched Sony LCD screen
The cost of replacing the screen (it is the entire LCD panel) is more than the TV is worth
Sep 28, 2008 | Sony BRAVIA KDL-40V3000 Television
SCRATCHED TV SCREEN
try contacting www.tvscreenprotectors.com
They deal with damaged tv screens
Apr 11, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Broken Screen
You need new optic block. Sony will pay for repair if you contact an authorized SONY repair facility
Dec 19, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Screen for 50" sony kdf-50a10
The front screen Sony part# 2-590-451-21 Andrews Electronics $153.80
Sep 23, 2007 | Sony KDF-E50A10 50 in. LCD HDTV
Open Questions:
See all Sony BRAVIA KDL-52XBR6 LCD TV Questions
Sony BRAVIA KDL-52XBR6 LCD TV Logo
1,737 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
