Question about Cell Phones
Forgot pass word to unlock samsung cell phone
  • 311 Answers
Samsung Secret Codes
Software version: *#9999#
IMEI number: *#06#
Serial number: *#0001#
Battery status- Memory capacity : *#9998*246#
Debug screen: *#9998*324# - *#8999*324#
LCD kontrast: *#9998*523#
Vibration test: *#9998*842# - *#8999*842#
Alarm beeper - Ringtone test : *#9998*289# - *#8999*289#
Smiley: *#9125#
Software version: *#0837#
Display contrast: *#0523# - *#8999*523#
Battery info: *#0228# or *#8999*228#
Display storage capacity: *#8999*636#
Display SIM card information: *#8999*778#
Show date and alarm clock: *#8999*782#
The display during warning: *#8999*786#
Samsung hardware version: *#8999*837#
Show network information: *#8999*638#
Display received channel number and received intensity: *#8999*9266#
*#1111# S/W Version
*#1234# Firmware Version
*#2222# H/W Version
*#8999*8376263# All Versions Together
*#8999*8378# Test Menu
*#4777*8665# GPSR Tool
*#8999*523# LCD Brightness
*#8999*377# Error LOG Menu
*#8999*327# EEP Menu
*#8999*667# Debug Mode
*#92782# PhoneModel (Wap)
#*5737425# JAVA Mode
*#2255# Call List
*#232337# Bluetooth MAC Adress
*#5282837# Java Version
Type in *#0000# on a Samsung A300 to reset the language
Master reset(unlock) #*7337# (for the new samsungs E700 x600 but not E710)
Samsung E700 type *#2255# to show secret call log (not tested)
Samsung A300, A800 phone unlock enter this *2767*637#
Samsung V200, S100, S300 phone unlock : *2767*782257378#
Samsung Secret Codes Part 2
#*4773# Incremental Redundancy
#*7785# Reset wakeup & RTK timer cariables/variables
#*7200# Tone Generator Mute
#*3888# BLUETOOTH Test mode
#*7828# Task screen
#*#8377466# S/W Version & H/W Version
#*2562# Restarts Phone
#*2565# No Blocking? General Defense.
#*3353# General Defense, Code Erased.
#*3837# Phone Hangs on White screen.
#*3849# Restarts Phone
#*7337# Restarts Phone (Resets Wap Settings)
#*2886# AutoAnswer ON/OFF
#*7288# GPRS Detached/Attached
#*7287# GPRS Attached
#*7666# White Screen
#*7693# Sleep Deactivate/Activate
#*2286# Databattery
#*2527# GPRS switching set to (Class 4, 8, 9, 10)
#*2679# Copycat feature Activa/Deactivate
#*3940# External looptest 9600 bps
#*4263# Handsfree mode Activate/Deactivate
#*2558# Time ON
#*3941# External looptest 115200 bps
#*5176# L1 Sleep
#*7462# SIM Phase
#*7983# Voltage/Freq
#*7986# Voltage
#*8466# Old Time
#*2255# Call Failed
#*5376# DELETE ALL SMS!!!!
#*6837# Official Software Version: (0003000016000702)
#*2337# Permanent Registration Beep
#*2474# Charging Duration
#*2834# Audio Path (Handsfree)
#*3270# DCS Support Activate/Deactivate
#*3282# Data Activate/Deactivate
#*3476# EGSM Activate/Deactivate
#*3676# FORMAT FLASH VOLUME!!!
#*4760# GSM Activate/Deactivate
#*4864# White Screen
#*7326# Accessory
#*7683# Sleep variable
#*3797# Blinks 3D030300 in RED
#*7372# Resetting the time to DPB variables
#*3273# EGPRS multislot (Class 4, 8, 9, 10)
#*7722# RLC bitmap compression Activate/Deactivate
#*2351# Blinks 1347E201 in RED
#*2775# Switch to 2 inner speaker
#*7878# FirstStartup (0=NO, 1=YES)
#*3838# Blinks 3D030300 in RED
#*2077# GPRS Switch
#*2027# GPRS Switch
#*0227# GPRS Switch
#*0277# GPRS Switch
#*22671# AMR REC START
#*22672# Stop AMR REC (File name: /a/multimedia/sounds/voice list/ENGMODE.amr)
#*22673# Pause REC
#*22674# Resume REC
#*22675# AMR Playback
#*22676# AMR Stop Play
#*22677# Pause Play
#*22678# Resume Play
#*77261# PCM Rec Req
#*77262# Stop PCM Rec
#*77263# PCM Playback
#*77264# PCM Stop Play
#*22679# AMR Get Time
*#8999*364# Watchdog ON/OFF
*#8999*427# WATCHDOG signal route setup
*2767*3855# = Full Reset (Caution every stored data will be deleted.)
*2767*2878# = Custom Reset
*2767*927# = Wap Reset
*2767*226372# = Camera Reset (deletes photos)
*2767*688# Reset Mobile TV
#7263867# = RAM Dump (On or Off)
Samsung Secret Codes Part 3
*2767*49927# = Germany WAP Settings
*2767*44927# = UK WAP Settings
*2767*31927# = Netherlands WAP Settings
*2767*420927# = Czech WAP Settings
*2767*43927# = Austria WAP Settings
*2767*39927# = Italy WAP Settings
*2767*33927# = France WAP Settings
*2767*351927# = Portugal WAP Settings
*2767*34927# = Spain WAP Settings
*2767*46927# = Sweden WAP Settings
*2767*380927# = Ukraine WAP Settings
*2767*7927# = Russia WAP Settings
*2767*30927# = GREECE WAP Settings
*2767*73738927# = WAP Settings Reset
*2767*49667# = Germany MMS Settings
*2767*44667# = UK MMS Settings
*2767*31667# = Netherlands MMS Settings
*2767*420667# = Czech MMS Settings
*2767*43667# = Austria MMS Settings
*2767*39667# = Italy MMS Settings
*2767*33667# = France MMS Settings
*2767*351667# = Portugal MMS Settings
*2767*34667# = Spain MMS Settings
*2767*46667# = Sweden MMS Settings
*2767*380667# = Ukraine MMS Settings
*2767*7667#. = Russia MMS Settings
*2767*30667# = GREECE MMS Settings
*#7465625# = Check the phone lock status
*7465625*638*Code# = Enables Network lock
#7465625*638*Code# = Disables Network lock
*7465625*782*Code# = Enables Subset lock
#7465625*782*Code# = Disables Subset lock
*7465625*77*Code# = Enables SP lock
#7465625*77*Code# = Disables SP lock
*7465625*27*Code# = Enables CP lock
#7465625*27*Code# = Disables CP lock
*7465625*746*Code# = Enables SIM lock
#7465625*746*Code# = Disables SIM lock
*7465625*228# = Activa lock ON
#7465625*228# = Activa lock OFF
*7465625*28638# = Auto Network lock ON
#7465625*28638# = Auto Network lock OFF
*7465625*28782# = Auto subset lock ON
#7465625*28782# = Auto subset lock OFF
*7465625*2877# = Auto SP lock ON
#7465625*2877# = Auto SP lock OFF
*7465625*2827# = Auto CP lock ON
#7465625*2827# = Auto CP lock OFF
*7465625*28746# = Auto SIM lock ON
#7465625*28746# = Auto SIM lock OFF
Type *#9998*627837793# Go to the 'my parameters' and there you will find new menu where you can unlock phone.(not tested-for samsung C100)
To unlock a Samsung turn the phone off take the sim card and type the following code *#pw+15853649247w# .
Java status code: #*53696# (Samsung X600)
If you want to unlock your phone put a sim from another company then type *#9998*3323# it will reset your phone. Push exit and then push 7, it will reset again. Put your other sim in and it will say sim lock, type in 00000000 then it should be unlocked. Type in *0141# then the green call batton and it's unlocked to all networks. This code may not work on the older phones and some of the newer phones. If it doesn't work you will have to reset your phone without a sim in it by typing *#2767*2878# or *#9998*3855#
Posted on May 03, 2010
  • virendar rawat May 03, 2010
    try this if it doesnt work then contct me through email ravi_rawat0912@yahoo.co.in
    Problem Solver:
  • 5 Answers
Software version
Posted on May 14, 2010
4 Suggested Answers
  • 8404 Answers
SOURCE: My keypad is lock on my Samsung A877 and i forgot
Did I just respond to this question??? Someone here just posted a very similar question on a Samsung device.
Normally I would expect the default value to be the last 4 digits of your telephone number. If you changed it, good luck.
Please try entering the last 4 digits.
If this doesn't work, if you changed the code, you will probably have to get help from the service provider or your manufacturer. http://www.samsung.com/us/consumer/mobile/mobile-phones/index.idx?pagetype=type
Thanks for your interest in FixYa.com
Please vote
thanks
a
Posted on Dec 05, 2009
SOURCE: unlocking my sony ericsson w580i cell phone
the w850i can only be unlocked by calling ur network provider and requesting an unlock code, for 3 they will charge the existing amount of ur contract is left, also the original owner will have to call, for vodafone if u call i think they offer it for £20 not sure though.
Posted on May 11, 2008
SpringRepair
  • 49 Answers
SOURCE: unlock password code samsung b3210
If you have forgot your password or just want to reset your phone follow these steps.
1. Remove your battery (and sim card if your phone has a sim card.)
2. Replace just your battery and power the phone back on.
3. When the phone powers on type in *2767*3855#
Your phone will power off then back on with the out of box settings,
Keep in mind that doing this will also clear any information including contacts and pictures
Posted on May 28, 2010
I forgot my 4 digit pass code to my Verizon sch a 930 samsung phone can somebody tell me how to get back in my phone.
If you have a Samsung account set up on your device, you can unlock your device remotely on the Find My Mobile web page. Unlock your Device
If you forgot your screen lock password, you can unlock your device using your computer.
  1. Go to Find My Mobile and log in using your Samsung account.
  2. Find and click Unlock my screen.
  3. Click Unlock.
  4. Once you receive a notification on your computer saying your screen is unlocked, you can unlock your screen on your device.
Nov 11, 2017 | Samsung Cell Phones
How do you get passed the pass word on a. Samsung schr680?
Judy, You will probably have to reset phone. Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Factory Restore Hard Reset or Password Wipe the Samsung Infuse Att
Hard Reset SAMSUNG R680 Repp
How do unlock my repp samsung R680 when forgot my password forgot my...
Samsung repp hard reset Programyourcelleasy
Mar 05, 2016 | Samsung Cell Phones
Samsung GT-c3262 mobile reset password
i already kept one password but i forgot that password what to do????
Mar 06, 2013 | Cell Phones
Forgot my passcode to unlock my cell phone
You can reset this code for free with solution here:
http://www.unlocksamsungonline.com/free-phone-lock-unlocking/
regards,
Mar 23, 2012 | Samsung Galaxy Prevail
Forgot my unlock code pattern for samsung galaxy s i9000
HI service562 the only way to get your phone unlock is to use your gmail to unlock the phone. If you forgot it are don't know it you will have to reset your gmail pass word. Now you do have the option of doing a hard reset on your phone. .If you can't do the hard reset go to samsung 's website and they will give you a few other ways to do a hard reset for your phone. Hope this helps
Jan 03, 2011 | Samsung Galaxy S GTI9000 Smartphone
I forgot the security pass code for my samsung solstice?
You can Unlock the Mobile from the Security Lock or Password Lock using the Master Reset Code,You can get the Master Reset Code at http://www.superunlockcodes.com/unlocking-services/rs12wp6/ and Unlock it.I unlocked My Nokia and Alcatel Mobile from the Security Lock using the Master Reset Code...
Nov 20, 2010 | Samsung SGH-A877 Impression Cell Phone
I forgot password of samsung m8800
master reset
warning, all data will be lost
start the phone with no sim
type
*2767*2878#
then
*2767*3855#
should be all reset
nick
Aug 27, 2010 | Samsung M8800 Pixon - Unlocked QuadBand...
Forgot pass word for phone lock.need to unlock phone
call up your cellular provider and ask them for PUK code...
Oct 08, 2009 | Samsung S7350 Ultra SLIDE Cell Phone
Pass word forgot
take it to a mobile service center and have them reset it for you
Aug 13, 2008 | Samsung SGH-e315
Cell Phones Logo
1,394 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
