Question about HP LaserJet 3380 All-In-One Printer
Scanner error My printer is saying scanner error - turn power off/on which I have done over and over. I am unable to print, copy or fax.
  • peonybl Apr 04, 2008
    My printer has similar problem. Also the copy or scan does not work when document is loaded in the flatbed scanner. Only if I put the document on ADF, copy or scan works. What is the problem? Thank you.
  • Anonymous May 21, 2008
    Dear sir;
    As I mentioned in the above subject, my printer laser jet 3380 is no problem in printing from windows. But when I need to copy and fax I got a problem with message of "Scanner Error Power on Power off ".
    So I need your assistance through the following email address.
Usually this means that the scanner electronics has failed. If you can print from the control panel try printing out a configuration page and let us know what the error codes are.
Posted on May 28, 2008
  • countlaserje Aug 04, 2011
    i have the similar problem
    here's the error report
    ASIC fault
    view:phx.rom6.8
    Built:0209_10:10:24:14
    fault addr:0x8019f00c
    Current Task : PCLXL
    0x41e03004
    0x00084bac
    0x0016d39c
    0x00169038
    0x0058307a
    0x005763d6
    0x005376a6
    0x00
    ASSERT FAILED
    View:phx.rom6.8
    Built:0209_10:24:14
    File: fax_nvram_config.c Line:52
    Current Task: NVRAM_MGR
    0x002f2f16
    0x002ea28c
    0x00006726
    anyone can help with tutorial fix it.
"Ink system has failed. Unable to print. Refer to printer documentation. Error: 0xc18a0101 Turn power off, then on again."
The first problem is you have an ink jet consumer printer. Go to their support site and search that error code. That may help, but don't count on it. HP is notorious for selling defective products and have lost more than one class action suites. you can try these steps http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00489814&cc=us&lc=en&dlc=en&product=3204785&tmp_track_link=ot_search
But it could also be the error for when the ink resovors are full in the bottom of the machine. It will stop working by design then. If it were to over flow you would see where all that ink went you been buying, so they stop the machine before that happens. Best advice is take it to the nearest dumpster and deposit it inside it, and buy a laser printer. It was the best thing I ever did.
Jun 17, 2014 | HP Photosmart C6180 All-in-One Printer,...
Getting error message
turn off printer while holding #9 button press power wait till display "full nv reset" problem solve
Oct 05, 2012 | Epson WorkForce 845 Wireless All-in-One...
My HP Photosmart C5240 will print from computer but will not scan or make copies.
Is there any error message displayed on the control panel of the printer just like one of the following:
Scanner failure, power off and on
Scanner System Failure
Scanner failed, cannot make copies or fax
Scanner failure. Unable to scan, copy, or send a fax
Scanner failure, cycle power
You may want to try following these steps:
1. Check if the scanner light does turn on when you initiated the scanning process, if not you need to reset the product.
2. Try using your other electrical outlet because your AVR or Surge Extension may not be providing enough voltage for the printer.
3. Try using dirty cycle, meaning you need to directly cut the power of your printer by pulling of the power cord from the rear side of your printer and wait for about 30 seconds before inserting again and turn it on.
If all these steps do not improve your printer functionality, you may want to call the HP online help and ask for replacement.
Job Espinosa
Feb 15, 2011 | HP Photosmart C5280 Printer
MY HP PHOTOSMART 3110 ALL-IN-ONE PRINTER FAX SCANNER COPIER IS HAVING AN INK SYSTEM FAILER AND IS UNABLE TO COPY,RECEIVE,FAXES, OR PRINT.
Solution
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx
Jul 09, 2009 | Office Equipment & Supplies
Printer won't print
Try this Issue When trying to copy, print, or receive a fax, the following error message appears on the product control panel display. Ink System Failure. Ink system has failed. Unable to copy, receive faxes, or print. Refer to printer documentation. Error: 0xc19aYYYY NOTE: The Y in the error message represents any digit, 0 - 9, or any character, A - F. Solution To resolve the issue, use the following steps. Step one: Remove the cartridges Make sure that the product is turned on and then disconnect the USB cable from the back of the product. Open the product cover and remove the cartridges. Close the cover and wait for a message to insert the cartridges to appear on the control panel display. Disconnect the power cord from the back of the product. Disconnect the power cord from the wall outlet and wait for one minute. Step two: Reinstall the cartridges Reconnect the power cord to the wall, reconnect the other end of the power cord to the product, and then turn on the product if it is not already on. Open the product cover and reinstall the cartridges. Close the cover and print a calibration page, if prompted. Print a self test report to make sure that the product can print. Reconnect the USB cable between the product and the computer. Try to print a document from an application on the computer.
Jun 08, 2009 | HP Photosmart C6180 All-In-One InkJet...
Won't copy or fax, scanner failure
Uneconomical to replace the scanner assy. sorry
Feb 17, 2009 | HP Officejet 4315 All-in-One Printer
Ink system failure
hp photosmart c7288 all-in-one
ink system has failed unable to copy receive faxes or print refer to printer documentation error oxc19a0002
Nov 25, 2008 | Office Equipment & Supplies
Dell Photo 926 - unable to scan
1. try to make a copy.
if it copy fine, then its an issue with software.
2. Try to scan with MS Paint,
Click on Start > All Programs > Accessories > Paint
Click on file > from scanners and camera > scan
It should scan if its not the windows issue...
3. Try different computer if it does not scan with Paint\
4. If it works with Paint, try to open Dell AIO center and try to fax from that too...
5. Turn the printer off, take the power brick out from back of the printer where power cable goes in , wait for 15 seconds to connect it back and turn on and try again to print, it should work fine
Oct 28, 2008 | Dell 924 All-in-One InkJet Printer
HP LaserJet 3380 All-In-One Printer Logo
280 people viewed this question
Seeker5211
Seeker5211
