Question about Electrolux Washing Machines
Ew1080 electrolux washing machine..when rinsing it beeps and i need to drain out thru the front plug.
  • 269 Answers
There is a main filter plug which can get very tight if it has not been removed for a while,be very careful if you use a pliers to remove put a cloth around the jaws of the pliers but be warned if you break the filter plug it will have to be replaced.Just next to the filter on the left is a small grey rubber hose that pulls out with a plug in the end,this is your emergency drain but over time this can become blocked.Try this and see how it goes.
Posted on May 03, 2010
Whirlpool front loader washer will not do the last drain and rinse cycle. Cleaned the drain pump but still doesn't work. When it gets to the last cycle it just beeps every couple of seconds.
check the pump motor if running when the program is in drainning time,if not!check the power going thru the motor or if theres is, or check the motor winding if its okey!
Oct 03, 2013 | Whirlpool Duet GHW9150P Front Load Washer
My Electrolux front load washer does not fill with water in the rise cycle and beeps and displays "draining, no water"
If this is a brand new product, I suggest that you MUST call for warranty assistance from their depot.
This can be related to failure or error of the controller, fault in the inlet or water level sensor which must be done free of cost.
Feb 12, 2013 | Electrolux EIFLW50LIW 4.2 Cu. Ft. Front...
Electrolux EWF 1495, Starts but dosent wash. Drum turns about twice then stops for a couple of minutes, turns then stops. It then indicates cycle ended but didnt rinse, spin or drain or spin. These can be...
OK, first remove the rear access panel. You will see a drain boot going from the tub to the pump. You will need to remove that boot and inside is a filter that you need to clean out. Reassemble and run a load and let me know what happens.
Dec 02, 2012 | Electrolux EIFLW55HIW Front Load Washer...
My new electrolux front loader is not filling with water during the wash cycle. The clothes are soaked, but there is NO extra water in the bottom of the tub. It does have extra water in there during the...
front loader washers fill accourding to how big the load size is on all front load washers.There should be no water above the center with a full load.If it is spinnig out and draining then it is working properly:)
Apr 21, 2010 | Electrolux EIFLW55HIW Front Load Washer...
E20 fault display
E20 is a fault either in the filter/pump or drain.
The water must be drained thru. the little hose by filter or get machine to back door and undo filter plug and drain onto back step its quicker.With filter out see if any blockages,shine torch up in filter hole turn to spin/drain and see if pump blade spins if not then get long screwdriver and turn blade to free if no joy pump has to come out to free,hopefully this will work and refit plug and check for leaks.Then try again.
Good luck.
Apr 19, 2010 | Zanussi ZWF1420W Front Load Washer
My washing machine door doesnt lock properly
its most likely your door lock if it is malfunctioning the washer will not work
Apr 09, 2010 | Kenmore Elite 45986 Front Load Washer
Unusual display on panel (padlock) machine can't be programmed door is not locked however
i just went through the same thing.......you need to hold the option and extra rinse buttons simultaneously for 6 seconds, this will unlock it.....so turn the machine on and press the two icons, dont worry about the beeping and flashing after 6 seconds the padlock symbol will go and you can use the machine as usual.....i wish they put that 'minor detail' in the manual...cheers!!
May 31, 2009 | Electrolux EW1000i Front Load Washer
Electrolux 1087 E90
call frigidaire for factory service or have the dealer replace it
May 08, 2008 | Frigidaire ATF6000ES Front Load Washer
Electrolux 1087 E90
When the washing machine is turned on... it beeps and displays error message E90 it wont operate.
what can i do ?
Sep 15, 2007 | Electrolux EW1000i Front Load Washer
Washing Machines Logo
77 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
