I have an old thinkpad laptop that for some reason only connects at 11mbps instead of 54mbps when an usb wifi adapter is connected. (I have same model, another one which does not have this problem.) I want to surf/connect at 54mbps. The old pcmcia to usb 2.0 adapter does not seem to fit in the slots either (bent pins?) What are my options here? Can I connect a parallel jack on that back of laptop to a usb connector,then go from here somehow to somehow swich the usb port to 2.0 speed. Or perhaps serial port to usb 2.0 (a cable/adapter) anything is worth trying as long as not too expensive. Please do not suggest to resolder joints on board. I have a parallel cord here that I can strip one end of the cable and hook a usb cable to it if you explain which wire goes where if you think this may work.
  • 2 more comments
  • JOE May 03, 2010
    please read comments in entirety before responding
  • JOE May 03, 2010
    please read all my notes , previous 'solutions'?
    This is the deal, am using a 1000mw usb wifi adapter similar to specs to alfa 1000mw; only with this Particular Laptop does it connect at 11Mbps, not 54mbps as all my other thinkpads, all the exact same model do not have this problem.
    Also am using long extensions of reg usb extension cord. Using the entire long extension cord(usb) with This particular Laptop does not even allow the laptop to see any networks at all (won't work, power loss too much?) If I shorten the cord 6 ft, it connects at 11mbps, unlike all the other thinkpads (the same model w the same specs+ ram) which I am able to use the full usb extension cord with no problem and surf at 54Mbps all the time this showing in system tray.
    However if I use a very short usb cord to connect the laptop to the 1000mw usb wifi adapter, it still Connects At 11 Mbps.
    Using the parallel port to a usb adapter or serial port to usb adapter: is it possible that this may solve the problem?
    By the way, on the first expert's note about using a pcmcia card to usb 2.0 adapter, I Have Used this with a different brand (dell) laptop that had only 1.0 usb ports, and yes it worked perfectly.
    I have mentioned that the pcmcia jacks on this particular laptop seem to be bent, cannot fit the pcmcia card in either top or bottom.
  • JOE May 03, 2010
    Hi Thanks for your advice. How does this device connect to the t40 thinkpad; it there a cable I need to buy as well in order to use this? Are you 80% sure at least this will do the trick?
    Please explain how this works, where it draws power from and why you are sure the usb's will function as 2.0 (54Mbps)?
    Thank you.
  • JOE May 03, 2010
    I don't see any legacy option/advances settings in bios,; I went through every option. If I use serial port to usb adapter, will the speed of usb be 2.0 (or you are not sure)?
    What do you think of the fixya tech who suggested I get a thinkpad port replicator 2 for the t40, this item is vey inexpensive. Do you think that is the best option (have tried removing all usb devices in dev mgr, etc, this has to be a board issue): if I take the hdrive out of the laptop w the 11Mbps, place it in another of same exact type t40, it connects at 54Mbps, so this is not a software issue, follow? Please get back to me.
  • 3,866 Answers
I know and use a product by hfield systems www.hfield.com if you not getting 54 its probably most likely you usb port not at 2.0 or your having a hard time with signal ether rate this product should and will help give it a try,
thanks and please do click the accept button for my efforts.
Posted on May 04, 2010
  • 4,281 Answers
You can use those cable converter but it is not effective because in old wifi version there is limit on speed .
In wireless 11 mbps is limit in old usb adapter and wireless module.
If you have same model gives this 54 mbps speed then you can get this speed on that usb adapter too.
For that uninstall all usb drivers.
Go to device manager then uninstall.
If you need serial adapter then try with that too.
Then check .
Also reinstall your wireless usb drivers after uninstalling it.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on May 03, 2010
  • Enable usb legacy 2.0 option in bios.
    For that when you power up the computer press F1 or F2 or del or ALT+F2 then you can see bios then go to advanced and enable usb 2.0 then save settings and exit.
    Buy new adapter for serial to usb converter then install driver then it will works.
  • 2,069 Answers
To manually increase ur internet speed go to network places click on view network connection ,and then the connection with which you are using, right click on that connection click on properties, there u'll find modem tab click on that.then after selecting the usb modem click on configure.select the modem speed to maximum and click on ok.
  • 2 more comments
  • Muzahura Frank May 03, 2010
    ok, I get your situation properly now. The only viable solution for you is to use the ThinkPad Port Replicator II here
    you will have more than just the USB 2 ports.
    Regards
    you can get it as low as $5 from many resellers e.g here.
  • Muzahura Frank May 10, 2010
    Sorry I couldn'yt get back to you intime, but what I gave above is the only perfect solution and since the replicator has USB2 ports, it will connect at higher speeds. Normally, it plugs in the slots you see under the laptop, it is easy to install and cheap on line. i gave you a link above.
    Regards
  • JOE May 16, 2010
    Well guess what I bought it and it did not solve the problem at all.
    Thanks!
  • 12,061 Answers
Ok, your USB port, and your WiFi card cannot "DO" 54mbps. unfortunately. There is just NO way to do this, even if you could use another USB 2, WiFi card, and you could plug it in, the BIOS, wouldn't allow it to work, as it doesn't "Know" 54mbps. The "Band width" of your system simply is NOT enough to process the data at any rate, IF you had onboard USB 2, then it would, BUT there is NO WAY again to effect this, even adding a USB 2 PCMCIA, PORT, or WiFi Modem, most likely will not work, but really is your ONLY shot, it may work, possibly, although I suspect it too, will default to 11mbps. You can do anything you like, it is simply NOT possible with you USB level, and inbuilt, WiFi & BIOS. So as related unfortunately, unless PFCMCIA works, then, there is simply NO WAY. IF you want a higher speed on the WiFi, then possibly, connecting to a Router via, the Ethernet, 100mbps, may help, but there too, you are limited by your Ethernet port, which, has a limited maximum, speed, 10mbps, too. I fear you are stuck, with what you have...
My toshiba laptop with a realtek rtl8187b wireless 802.11b/g usb 2.0 network adapter, is connected to a wifi network with internet, but periodically the connection is lost (connected and automatically...
This is not a problem. Wireless connections sometimes tend to be inconsistent. Try closing the distance between your laptop and the wireless network adapter.
Mar 17, 2011 | Toshiba Realtek RTL8187B Wireless...
Will it work with a wireless g router ?
The Play Adapter offers both 2.4GHz and 5GHz band operation, and it is backward compatible with 802.11a/g devices at 54Mbps as well as 802.11b products at 11Mbps.
Feb 04, 2011 | Belkin Play Wireless USB Adapter (F7D4101)
Is IBM Thinkpad T22 equipped with WIFI & what's the USB port vers
IBM Thinkpad T22 doesn't have Wi-Fi adapter installed. you need a USB Wi-Fi adpater in other to have Wireless connection.
You can go for D-Link, 3COM,belkin USB Wi-Fi adapter. Make sure the USB Wi-Fi adapter support the Operating System you installed.
Good Luck.
Jan 08, 2010 | IBM ThinkPad T22 2647 Notebook
Cannot seem to get wireless connection . ethernet connection works fine . do i need usb adapter to bring my 3 year old laptop up to N standard ? Ray
If your laptop does not have a wireless card built into the computer then yes I would go and buy a usb wifi adapter because you cant get wifi if you dont get one.
Sep 29, 2009 | NetGear DGN2000-100NAS Router
Wireless network on and off all time
Plz check ur signal strength first. Second u can check with configure ur wirless adapter properties with static speed (802.11b or 11Mbps).
u can check ur wireless adapter on ur bro's laptop, disable his WiFi button & connect his laptop through this wireless adapter to samsung modem.
If the problem remain same on ur bro's laptop then ur wireless adapter having some problem.
PLZ GIVE RATING BY YES or NO.
Mar 20, 2009 | SMC EZ Connect g SMCWUSB-G (SMCWUSBG)...
Good Signal,Good Mbps, Slow Internet Connection?
1. Try to use a different wireless adapter on all available USB ports, if the problem remains then
2. turn off your PC unplug the power cord from the power socket, short the two legs of the power cable then leave it for 5min, then plug it into the power socket again and turn on the PC.
if this didnt work then you have a hardware problem with the USB ports.
let me know how it works out.
Nov 30, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
Good Signal, Good Speed, Slow Internet?
Try plugging the computer straight to the router.If all is well the adapter may need a firmware or driver update.Or your adapter may be experiencing some type of heat problem or failingRICHARDM69
Nov 29, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
Wifi Dongle
function PopupWindow(URL, WIDTH, HEIGHT){ var winleft=(screen.width-WIDTH)/2; var winright=(screen.height-HEIGHT)/2; day=new Date(); id=day.getTime(); eval("page"+id+" = window.open(URL,'"+id+"','toolbar=0,scrollbars=1,location=0,statusbar=1,menubar=0,resizable=1,width="+WIDTH+",height="+HEIGHT+",left="+winleft+",top="+winright+"');"); }
USB WiFi Dongle
Product reference: 11590 Here is some Technical data on your wireless adaptor. There is also a link at the bottom where you can download the driver for the operating system you are running.
" src="http://www.mobilefun.co.uk/graphics/rightarrow.gif" width="10" /> Description The USB WiFi Dongle easily connects your USB-equipped desktop or notebook computer to your wireless network for internet and file sharing. Desktop users can now join the network with the ease of a USB plug-in, without opening their PC cases, laptop users can enjoy the benefits of staying mobile-while connected to the internet.
By adhering to the 802.11g wireless standard, the USB WiFi Dongle is capable of streaming video and transferring large files across a wireless network. You will most likely need this if you have a bought a wireless ADSL or cable modem and wish to connect your PC to the internet or other PCs on the network wirelessly. The USB WiFi dongle is also compatible with all mobile phones and PDAs with WiFi connectivity.
Features:
  • Versatile use with Desktop PC or Laptop Computer
  • Portable, compact, pocket sized design
  • Compatible with IEEE 802.11b (11Mbps data rate).
  • Compatible with IEEE 802.11g (54Mps data rate).
  • Dynamic data rate scaling at 6,9,12,18,24,36,48 and 54Mbps for 802.11g.
  • Support wireless data encryption with 64/128 WEP for security.
  • Support infrastructure networks: Access point and ad-hoc network.
  • Supports WPA enhanced security.
  • Supports DFS/TPC for European operation.
  • Friendly user configuration and diagnostic utilities.
  • High speed USB 2.0 interface.
Technical data:
  • Chipset: SiS 163U.
  • Standards: IEEE 802.11b, IEEE 802.11g.
  • Frequency Band: 2.4GHz ~ 2.483GHz.
  • Data Rate: IEEE 802.11b, 1, 2, 5.5 & 11Mbps.
    IEEE 802.11g, 6, 9, 12, 18, 24, 36, 48 & 54Mbps.
  • Transmitter Power: 17 dBm.
  • Receive Sensitivity Operating at 11Mbps: -80 dBm @ 8% FER.
  • Operating Range: 100 - 400m, depending on environment.
  • Antenna: On board chip antenna.
  • Security: 64-bit or 128-bit WEP/WPA/TKIP.
  • I/O Interface: USB 2.0.
  • Size: 58 (L) x 23(W) x 9(H) mm.
  • Weight: 9g.
System Requirements:
  • Windows 98SE/ME/2000 and Windows XP.
  • Pentium 233 MHz or higher.
  • 32 Mb of RAM under 98, 98 SE, Millennium & NT 4.0 with Service Pack 5.
  • 64 Mb of RAM under Windows 2000 and Windows XP.
  • 100 Mb of disk space.
rightarrow.gifDriver Download To download the latest drivers for Windows 98 or higher click here.
Apr 14, 2008 | Computers & Internet
No wifi
The Fujitsu Lifebook S5582 does not have an integrated Wireless network card. This laptop was manufactured in 2001-2002. The integrated Wifi card was not generaly common in laptop computers until 2004.
So, you will need to buy a wireless adapter if you want to have wifi connectivity. Since this laptop is quite old, I would recommend a PCMCIA (a.k.a. PC card) adapter instead of a USB because it will be much lighter on the processor load.
You also have to be aware that using a wireless card will use more battery power and therefore shorten the expected autonomy of the laptop when running on battery.
Feb 17, 2008 | Computers & Internet
Wireless
you may struggle if youve got win 95 on it, and only if you got usb ports,go for a wireless usb adapter if you can find one, as sometimes the pcmcia driver can be a bit fiddly and cause problems with pcmcia wireless cards. Although there are win 95 expansion cards available most are only 11MBPS transfer speeds as apposed to the 54MBPS and 108MBPS cards now available for other operating systems
Sep 02, 2007 | Toshiba Satellite Pro 470CDT Notebook
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
