Question about Technics SL-1200MK2 Turntable
The platter on my Technics SL 1200MK2 stopped spinning. The power works fine... the platter doesn't want to turn. It feels like it just wants to be stuck?! Never had this problem with any of Technics 1200's... any help is much appreciated!
  • 476 Answers
If you remove the rubber pad from the top of the platter then you should be able to lift the platter off the servo drives' center shaft,
from memory the unit is not attached just held on by gravity,if the servo magnet is gone the take it in for a service and pay the man for his time,
My first problem on my 1200s was a pitch control issue and easy to fix,with a little cash,never use second hand parts unless you know what you are doing because when they fail on you while playing to a packed dance floor then youll get more of a supprise than you barginned for,
Misterdj
Posted on May 03, 2010
When i turn my 1210s on both 33/45 switces come on and platter spins too fast
Couple of options , but first cleanen the pithfader and variable resistor pitch vr3 i thought, it's an open one , he needs allways to be replaced, even technics says so and first clean the board, inside and on youtube and this side there enough movies and text how to do it, and check the pitchfader cables very good.
Apr 12, 2014 | Technics SL-1200MK2 Turntable
Platter stops when back-cueing
? so you take whole the platter with you when back cueing ..... i would buy some good suzuki slipmats and don't stop and spin the platter backwards , that's allways bad and why pushing that hard....
Dec 06, 2013 | Technics SL-1200MK2 Turntable
Is it bad for the motor to test a technics sl 1200 off load with the platter removed?
No. Motors simply turn. It's when you make them work harder by putting loads on when the problems start.
Aug 07, 2013 | Technics SL-1200MK2 Turntable
Motor problem?
If its still working then GREAT! The direct drive system uses magnetic frequency to drive the table platter. If you havnt already....Remove the platter and clean the coke off the magnet under it. Not sure at this point but hope that helps!
Apr 04, 2010 | Technics SL-1200MK2 Turntable
My platter spins fast out of control
At a guess from the minimal informaton given, i would say the drive motor has gone. I would suggest taking it to your nearest dealer or service center for a full overhaul, appart from that, visit e-bay.
Oct 24, 2009 | Technics SL-1200MK2 Turntable
Technics SL-1600MK2
Tonearm lift is probably a deteriorated belt. Google it, it's pretty common. The platter spinning might be due to a bad control board. You'll probably have to go to a repair shop to diagnose it.
Oct 13, 2008 | Technics SL-1200MK2 Turntable
Technics dj deck 1200mk2
So the unit powers up still? First and foremost check to make sure there is nothing forcing the platter to not rotate. If the platter is fine, and there is nothing holding it back, then you have a drive issue. More than likely one of the IC's (Integrated Circuits) failed, or it could be one or some of the other resistors which control the drive/platter on this unit.
Unfortunately, this is not an easy fix. You will need to take it to a qualified service center for repair. Make sure you ask the service center if they are familiar with the drive of the Technics SL1200MK2, many service centers are not.
- Optic.
DJ PRO LAB
Apr 12, 2008 | Technics SL-1200MK2 Turntable
Technics 1210 pop up light?
Maybe you should try putting a smaller (in Watts) lamp in the pop light...
Nov 09, 2007 | Technics SL-1200MK2 Turntable
1200 platter drag
the platter should have two holes on it,my 1210 does. put your thumb on the spindle and a finger in each hole and prize the platter off. theres no screws holding the platter on just a tapered spindle shaft. it is quite heavy so a good pull will do it. as for the scraping it might be as simple as packaging placed under the platter to secure it for shipping, technics are built really well so i cant imagine it could be anything major. i hope this helps you out, if you need any more help let us know. please also let us know how you get on. darren
Oct 05, 2007 | Technics SL-1200MK2 Turntable
Technics SL-1200MK2 Turntable Logo
643 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
