Question about LG CRD 8480C (CRD-8480C) Internal 48x CD-ROM Drive
Currently running a windows 98 program and tried to install windows xp but it failed because it said the file cdrom.sys could not be found...
  • 476 Answers
Does your cd rom work?is it installed??
To fix this install the drivers for the cd rom and
try again
Posted on May 03, 2010
I had Windows 98 OS on my desktop and I wiped it out and installed Windows XP. My system performed better before I did this, how do I get rid of XP and reinstall Windows 98? I don't have the Windows 98 CD...
If you don't have the Windows 98 CDROM, or an image backup of your Windows 98 installation (if you don't know what an image is then you don't have one) then you're in a tough spot.<br><br>
You can't just "go back" to your Windows98 machine, you will have to reinstall Windows 98 from a CDROM. So you will have to find a disc from someone/somewhere and hope it's the same version of 98 that your product key was for (if you have the product key). Or you can purchase a new copy of Windows 98SE. They cost around $55 from several websites (viosoftware.com for one).<br><br>
On another note, if you computer is running slower with XP it's most likely due to the amount of RAM being low. Try to get at least 1GB of RAM in your current PC and you'll probably see XP run better. You could also try installing Ubuntu, it's a free operating system.
Jan 31, 2010 | Microsoft Windows XP Home Edition
IBM ThinkPad 600E trying to put os on it
that is correct.. IF you are using windows 2000 the files are NOT the same as the files under XP.. Your best bet is to EITHER install the complete XP or find the win2k installation disk,, even an upgrasde disk for win 200 can be found probably around 100.00. IF the system isn't booting from your XP disk IS Your disk an ORIGINAL or a copy of the original?.. If for example your CD rom is drive E then see if you can find a win XP emergency boot disk and access the CDROM goto e:\windows\i386 then run the setup program, many cases this will overwrite your existing OS.. but do so at your OWN RISK I will not be accountable if you lose any of your important files.. some win98 emergency boot disks can access the cdrom but you may have to make certain additions to the autoexec.bat and/or config.sys files. be careful when using DOS because you can completely delete EVERYTHING on the HDD if you use the right command(s). As A DOS BABY I have performed many lazarus miracles but I have been using dos since the early 70's
May 22, 2009 | Computers & Internet
Lite on DVD Combo disk read failure
You could take the drive out of the encloser and hook it up. There could be a flaw in the enclouser ive had that happen before to me. I just took it out and put it in standard if this dosent work then there is a flaw in the dvd burner
May 20, 2009 | AMD Duron 1.3 GHz (cpu-amd-1.3g-o)...
Error code 2352
http://service1.symantec.com/SUPPORT/nav.nsf/pfdocs/2003020714354306?Open&docid=2003020714354306&nsf=nav.nsf&view=pfdocs
To run the Microsoft Windows Installer if Norton AntiVirus was installed from the CD
  1. Insert the Norton AntiVirus CD into the CD-ROM drive.
  2. Do one of the following:
    • If the installation program appears, then click Browse the CD
    • If the installation program does not appear, then double-click the My Computer icon on the Windows desktop, and then double-click the CD-ROM drive icon.
  3. Double-click the MSI folder.
  4. Do one of the following:
    • In Windows 98/Me, double-click the WIN9x folder.
    • In Windows 2000/XP, double-click the WINNT folder.
  5. Do one of the following:
    • In Windows 98/Me, double-click the Instmsi.exe file.
    • In Windows 2000/XP, double-click Instmsiw.exe if you have Windows 2000/XP.
  6. In the next dialog box, click Yes.
  7. After the rollback has finished, then reinstall Norton AntiVirus.
    Follow the instruction in Reinstalling your Symantec program after a failed installation or after you see error messages to start the computer without any programs running on startup and then reinstall your Norton program.
If these steps do not fix the problem, then go on to the next section.
To run the Microsoft Windows Installer if Norton AntiVirus was installed from a downloaded version
  1. On the Windows taskbar, click Start > Find (or Search) > Files or Folders.
  2. Ensure that "Look in" is set to the drive where you downloaded Norton AntiVirus, and that "Include subfolders" is checked.
  3. In the "Named" or "Search for..." box, do one of the following:
    • In Windows 98/Me, type the following:
      instmsi.exe
    • In Windows 2000/XP, type the following:
      instmsiw.exe
  4. Click Find Now or Search Now.
    You might see many files with this name. Look for the file with this name that is located in either the Symantec_Norton_AntiVirus_2003 or the your Windows temporary file location depending on your version of Norton AntiVirus.
  5. In the Search Results window, do one of the following, depending on your version of Windows:
    • In Windows 98/Me, double-click Instmsi.exe.
    • In Windows 2000/XP, double-click Instmsiw.exe.
    This will undo the changes that were made to your system during the first failed installation.
  7. After the process finishes, then reinstall Norton AntiVirus.
Apr 22, 2009 | Microsoft Windows Vista Home Premium...
Running digi 001 on windows 7
i got digi 001 running on windows 7...
i left my xp on hard disk while installing win 7. it kept xp on folder windows.old folder. in control panel i saw digi as multimedia adapter wich system couldn't recognice. hit "change settings" -> driver -> update driver
used my old windows to search for driver. it found "Dalvin.sys" driver for adapter. installed that. after that windows recogniced digi 001.
downloaded "digidesign asio 6.11" driver installer for win-xp and ran it.
and bingo - it works!
in every step windows was complaining and asking do i want to do this. just yeah'd everything. as i just had a clean install of win 7 i just thought whatta heck i can install everything again if it would not work, but it did.
so in a nut shell:
1: install Dalvin.sys in control panel for digi 001
2: run digidesign asio 6.11 driver installer for win-xp
for me it worked but i absolutely take no responsibility if you mess your system with this! at least reaper got a sound out of it. i haven't tried to record anything yet. but asio settings seemed to work as they used to do in xp.
- veikko-antero
Mar 17, 2009 | Digidesign Mbox 2 Barebone
ThinkPad A21m won't boot into Windows
Did the laptop you got come at least with a windows XP cd? If so boot the laptop off of that and try to install Windows XP and see if it goes thru. Just make sure during the installation you tell it to delete the partitions first and then let it go thru that way you know for sure the hard drive is clean at that point.
Feb 02, 2009 | IBM ThinkPad A21m 2628 Notebook
Missing or corrupted file C:\windows\himem.sys
If you are running Windows 95, Windows 98, type:
copy himem.sys c:\windows <press enter>
If when typing any of the above commands you receive a prompt that the file already exists, ensure to overwrite it.
Reboot the computer; if the issue continues to occur, verify that the config.sys is properly setup. The line himem.sys should read:
DEVICE=C:\Windows\HIMEM.SYS
or
DEVICE=C:\DOS\HIMEM.SYS
Additional information and examples of the config.sys can be found on our autoexec.bat / config.sys page.
Dec 27, 2008 | Compaq Presario Notebook
I want to boot from cd to change windows from xp to 98
enter the bios set up on start up. Go to boot sequence, change 1st option to cdrom instead of main drive. Save and exit. Let it boot up, put 98 disk in cdrom. Shut down, reboot and win 98 installation will begin asking you to over write existing ops sys. Choose yes and the install should be a breeze after this. Once xp is installed, dont forget to return to the bios and change back your boot sequence to hard drive as primary /master.
Sep 26, 2008 | Compaq Computers & Internet
Not able to install win Xp
CHECK THE CMOS SETUP OF YOUR MOTHERBOARD,CHECK THE CMOS BATTERY AND MOST IMPORTANT READ YOUR MOTHERBOARD MANUAL INSTRUCTIONS
Feb 04, 2008 | Asrock M810LMR Motherboard
LG CRD 8480C (CRD-8480C) Internal 48x CD-ROM Drive Logo
104 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
