Question about Tefal Avante Deluxe 2 Slice Toaster
Clean out bottom
I have a moth infestation and really need to clean the inside of this toaster. I don't see how I can get at the crumbs in the bottom. Help!
  • sasharris May 04, 2010
    Yes, I know the access is on the bottom -- And there is a tiny little flap but it doesn't allow access to the big layer of stuck crumbs. thanks though.
    Guru:
  • 351 Answers
Hi .. turn the toaster upside down. There should be an access door there to allow you to clean out the bottom of the toaster.
Posted on May 04, 2010
Waring pro toaster oven: the toaster part spring would not stay down. How to repair?
Most of the time this problem is caused by a build-up of toast crumbs in the latch mechanism. Unplug the toaster oven and follow the instruction manual directions for cleaning the toaster section. Try cycling the toaster lever up and down a few times, then clean out the crumb tray again. If that doesn't solve the problem, you'll have to look for an access to the latch mechanism to clean it out and perhaps gently straighten the latch hook if needed. Note: these are generic directions for all such toasters. I can't be more specific without knowing which model in the Waring Pro line you have.
Jul 02, 2017 | Waring Toaster Ovens
Model TQ-800H gets toohot and shuts off.
i've found this to be a common problem.... typically, people will clean out the crumb tray at the bottom of the toaster, whilst other crumb bits remain elsewhere inside the toaster, especially close to the heating elements, and alot of newer models today have a safety sensor. try giving it a good thorough cleaning and visual inspection to rule out a little excess building getting in your way...literally. lol. hope this helps
May 09, 2016 | Hatco Kitchen Appliances - Others
How to clean the inside of a toaster
Slide the bottom door under the toaster and it will open, I would suggest doing it over a waste can or sink. You can take a small thin brush and get the crumbs out. Then your toaster will be back in working order. Crumbs that are stuck in the bottom of the tray is what causes it to burn the toast.
Nov 21, 2013 | Dualit CTS4E 4-Slice Toaster
Just purchased toaster oven model CE23551 and it did not have a crumb tray as advertised on the box and owner manual. Why is there no crumb tray ?
This model does NOT come with a crumb tray. In order to remove the crumbs from the bottom it must be shaken (like a toaster). I understand that this may be a little inconvenient; however, this machine is made relatively light weight for that purpose.
Mar 30, 2013 | Toaster Ovens
Russell Hobbs 18140 Toaster The bread carrier will not stay down during toasting. Insert two slices of bread into bread carrier and push down to lock. The right hand side carrier does not stay down. The...
Constant use can lead to crumbs clogging the path of the lever. Try opening up the bottom panel, by pulling on the metal tab to release the plate (and crumbs!) over a trash can. Also try flipping the toaster upside down and, very gently, shaking the crumbs out. if that doesn't work, you can try checking the toaster's browning dial. This might be too low to activate the heating coil. Try dialing it up, and pushing the lever down again. I hope this helps. You can check our post on Best ways to use a Toaster oven. Best ways to use toaster oven 2017 ultimate guide Kitchenutilitypro
Sep 28, 2017 | Kitchen Appliances - Others
Where can I purchase a new bread crumb tray (goes in the bottom) for Euro Pro toaster oven model TO251? What is the coast? Don
From my research from several sources, you can't. Best bet is to buy a baking sheet of 12" x 12" size and use it as the crumb tray. These inexpensive ovens are throw away items, hence, no part supplies.
Mar 10, 2011 | Euro-Pro EuroPro 6Slice Toaster Oven with...
Crumbs stuck on the sides and bottom of toaster
You can follow the instructions on how to replace the heating elemnts of the dualit toaster in the link
http://www.fixya.com/support/r4472039-procedure_replacing_heating_elements
With this way you remove yours clean the toaster completely and put the elemnt back.
Good luck
Jul 24, 2010 | Dualit CTS4E 4-Slice Toaster
How do I remove the upper housing assembly to clean out the toaster? I have a KitchenAid model KTT340OB
In the event that you DO need to take it apart, my KTT570 had two of the six screws hidden by rubber feet on the bottom of the toaster. Remove the feet by carefully prying them out with a very small straight-slot screw driver. They are essentially just rubber plugs about 3/4 of an inch in length. They are located on the end from which the crumb-tray is extracted. There are ONLY six screws so don't remove the rubber feet on the opposite end. You will need to remove the darkness knob and the handle from the end of the toast-lowering mechanism prior to removing the cover.
Dec 27, 2009 | KitchenAid KTT570 4-Slice Toaster
Dualit 20247 2-slice toaster
Very often it's simply crumbs in the wrong place.
Unplug it and take it outside. Remove any little drawers you have completely, and brush them out with a stiff brush.
Turn toaster upsidedown, and bang the sides with your flat palm to empty crumbs. Because of the design, this doesn't get everything out, and you may need to do it upright, and upsidedown again.
While upsidedown, press the levers fully down, and agitate them on the bottom stop.
This should remove the crumbs from the electromagnet armature.
This is operates when a flat plate rests on the elecromagnet. If there are crumbs in the way - it wont hold.
If there is still a problem after this, please contact again, or rate so that other may follow the advice given. Thank you.
Jun 25, 2008 | Dualit 20247 2-Slice Toaster
Tefal Avante Deluxe 2 Slice Toaster Logo
244 people viewed this question
Top Tefal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paul
paul
Oscar Netto
Oscar Netto
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
