Question about Kenmore Elite 45986 Front Load Washer
Slow muddy drip right behind the motor/
I have a slow muddy drip right behind the motor when the tub is full and washing.
  • 269 Answers
Is the machine noisy when it spins,because it sounds like the bearings are starting to wear and there is water leaking from the rear bearig seal.
Posted on May 03, 2010
WSM2480 Clothes Still Wet After Slow Spin Cycle
It's possible that the tub didn't drain properly in the allotted time and the remaining water is slowing your drum from coming to maximum extraction speed.
Jan 10, 2014 | GE WSM2420D Unitized Spacemaker Washer /...
Water leaking into tub
A solenoid is bad on the water inlet valve and needs to be replaced. Here is a link to the part to order.
Nov 05, 2012 | Frigidaire GLWS1749A Top Load Washer
Water is continually leaking into the tub from the inlets as a slow drip. This happens while the washer is off and continues forever unless the water supply is turned off. This is a stackable washer/dryer.
A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Jan 06, 2011 | Washing Machines
My clothes are still dripping wet after a complete cycle.
If the washing machine is not spinning to its regular speed then it can be the cause of wet clothes.If there is any cloth got stuck in between the inner and outer tub then this will slow the speed and this can cause the problem.Also if the washing machine spin motor,if its faulty then it can be the reason for clothes coming wet.Also check the motor coupler,if its cracked or broken this can be the reason of motor not spinning to its full speed. --------- But if all this ----- the motor,the motor coupler and the inner tub and outer tub blockages checked ok.And there is no problem seen then the other possibility is faulty water inlet valve.The valve lets the water to enter the machine.But if this valve is got weak/faulty then it will not stop the water from entering.So the clothes come out wet,because some amount of water will always enter the washer due to faulty water inlet valve. --------- This are the possibilities that has to be checked and confirmed for the problem to be solved.To get required parts ,you can get it from www.repairclinic.com . Keep updated if any more queries.Thanks.
Oct 14, 2010 | Kenmore Washing Machines
I have a Model GSL9365EQ2. It has a slow drip
Take the drain hose out of the regular drain and lower it to gravity drain into a bucket, pan, or floor drain if available. Turning the water off should not have prevented the machine from starting. The drip is likely coming from a leaking solenoid water valve at the rear of the machine where the hoses connect. Replace the valve assembly after removing the cabinet top and maybe the cabinet back panel. Make sure to remove the power if you are going to do the work. Hope this helps!
Mar 26, 2010 | Washing Machines
Slow spinning wet clothes
The reason to this problem is your worn belt.It might have
gone bad.You may need to replace it.
Sep 02, 2009 | Admiral AW22 Top Load Washer
My tub motor seems to be going slow and may need replacing. Do I have to remove the tub top do it?
yes you are very correct.the tub needs to be removed to replace the motor. you can get new motor at  www.repairclinic.com
May 06, 2009 | Kenmore Elite 21082
Water leaking into tub from inlet
you need to replace the water valve. Look on line for parts for your model
May 07, 2008 | Washing Machines
Whirlpool dishwasher Model DU9450XY-1
it may have a cracked tub does it drip out of the tub brace (a strip of metal that runs side to side on the bottom of the tub behind the wash motor) Have replaced several for this issue. Have fixed them with good epoxy also. PLEASE rate my help as solved if i answered your question!! Thankx
Oct 03, 2007 | Dishwashers
Kenmore Elite 45986 Front Load Washer Logo
47 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
