Question about Mitsubishi MS24WN Air Conditioner
No operation - neither remote nor emergency button
Since the last use - our unit stopped working. First suspected remote, but that works well in other room. I tried emergency buttons nothing happened. Fuse ok.
Model Nr. is actually MSH24NV
SOURCE: tv wont turn on
That same thing just happened to my t.v. The repair person will be here on 10/10/06. I will let you know what they say.
Posted on Sep 27, 2006
  • 192 Answers
SOURCE: blue screen and shut off by self
You will need to reset the Netcommand and tuner settings in the set. The little indented button in the front of the set needs to be pushed in (when the set is off). The front light will blink for about a minute or minute and a half. Then, reprogram the Netcommand settings. This should solve your problem. If you need more information, then, reply to this post and I will respond.
Posted on Sep 23, 2007
bestdarngood
  • 3037 Answers
SOURCE: telivision dont want to power up.
You are experiencing the Mitsubishi Green Blinking Light of Death which is fixable.
All you need to do is replace the four 1000uF/16 volt power supply capacitors in the "DM module" (one of the two onboard microprocessors) which are inadequate for this tv. These capacitors are apparently undersized, in that they will eventually fail (usually after about 3 years) if and inevitably when there are voltage fluctuations in the circuit above 16 volts. It is then recommended to install either 1000uF/25 volt or 1000uF/35 volt capacitors as replacements, so that they will be more than ample to handle any voltage spikes that will occur.
If you are good with soldering and know how to work with electronics then this will be an easy fix otherwise I suggest getting someone to replace the capacitors that knows how to deal with them without getting an electrical shock. You can get the capacitors at any electronics store such as Radio Shack.
Good luck and please let me know if you have any further questions.
thanks
Posted on May 01, 2008
SOURCE: Mr Slim Issue
Need to know the year of the system, I would reccomend going to www.mrslim.com and looking up your unit. You will be able to get the full service manual for it
Posted on Aug 26, 2008
  • 121 Answers
SOURCE: I have a mitsubishi electric
Hi Lisa,
First change the batteries in the remote. Is this a central system or separate units. It sounds like central which would have sequencers and fan relay that would keep it from coming on. mitsubishi uses pc boards for everything and they fail often. Unless you about elec. circuits then you will need an a/c contractor to troubleshoot the system. But first try the batteries if you haven't already.
Posted on Sep 27, 2008
BDV E2100 LOCKED IN TV MODE
Once again a simple GOOGLE search, and the first thing on the list is the manual for this unit!
I suspect this is what you need.
Deactivating the Buttons on the Unit
(Child Lock)
You can deactivate the buttons on the unit
(except for on/off) for preventing misoperation, such as child mischief.
Hold down
(stop/square black button)
on the unit for more than 5 seconds."LOCKED" appears in the front panel display.
The child lock function is activated and the buttons on the unit are locked. (You can operate the system by using the remote control.)
To cancel, hold down
for more than 5 seconds until "UNLOCK" appears in the front panel display.
If that's not the problem, here's the link for the manual.
http://pdf.crse.com/manuals/4446734151.pdf
Jul 20, 2016 | Sony Televison & Video
Panasonic air con - when you turn the air con on it runs for about 3 mins and then the timer light flashes. Air con will not work.
• Once abnormality has occurred during operation, the unit
will stop its operation, and Timer LEDs blink.
• Although Timer LED goes off when power supply is turned
off, if the unit is operated under a breakdown condition, the
LED will light up again.
• In operation after breakdown repair, the Timer LED will no
more blink. The last error code (abnormality) will be stored in
IC memory.
• To make a diagnosis:
1. Timer LED start to blink and the unit automatically
stops the operation.
2. Press the CHECK button on the remote controller
continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote
controller. The code "H00" (no abnormality) will be
displayed and signal will be transmitted to the main
unit.
5. Every press of the button (up or down) will increase
abnormality numbers and transmit abnormality code
signal to the main unit.
6. When the latest abnormality code on the main unit
and code transmitted from the remote controller are
matched, power LED will light up for 30 seconds and
a beep sound (continuously for 4 seconds) will be
heard. If no codes are matched, power LED will light
up for 0.5 seconds and no sound will be heard.
7. The breakdown diagnosis mode will be canceled by
pressing the CHECK button continuously for 5 sec-
onds or without any operation the remote control for
30 seconds.
8. The LED will be off if the unit is turned off or the
RESET button on the main unit is pressed.
When you have the error code, we can work out what to do next.
Mar 27, 2015 | Panasonic Heating & Cooling
Garage door opener won't work
Motor has overheated; the motor unit does not operate or trolleyis stuck on stop bolt = Motor unit hums briefly; RPM Sensor =Short travel 6-8" (15-20 cm).• Unplug unit to reset. Try to operate motor unit, check diagnostic code.• If it is still flashing 5 times and motor unit moves 6-8" (15-20 cm), replace RPMsensor.• If motor unit doesn't operate, motor unit is overheated. Wait 30 minutes andretry. If motor unit still will not operate replace logic board.
Aug 30, 2012 | Craftsman 3/4 Hp Garage Door Opener System...
I have changed the batteries but the remote does not work. We can turn the unit on mamually at the unit but can't change temperature or any other function
Manual button in a/c unit is just for emergency. You should operate only by remote. Get new remote and operate. Helpful?
Jan 20, 2011 | Heating & Cooling
I have a Sears Craftsman HBW0777 Garage Door Opener (Date: 07/94) whose remotes both stopped working - I suspect this is a problem with the main control unit, but everything else with the unit is fine (I...
I had the same issue yesterday with my remotes which are model 850CB. I fixed it by following these steps on Chamberlain's help site:
1. Press & release the "learn" button on the motor unit. 2. Within 30 seconds, press and hold the button on the remote. 3. Release the remote button when the light bulb on the motor blinks. It has learned the code.
http://help.chamberlain.com/help/en-us/programmingInstructions/ and enter your remote model number for re-programming instructions.
That worked for me. Not sure why it "lost" the code in the first place. By the way, I only had to do this for one remote, the other started working after the first was re-learned.
Oct 31, 2010 | Home Security
The emergency brake warning will not go away even when the emergency brake is on...do I need the remote in order to operate the dvd player?
The warning is there because the signal that the brake has been engaged doesn't reach the player - either the unit was badly installed or there's a fault in the wiring. To find which you will have to remove the unit and test the wiring.
BTW you don't need the remote, almost all functions can be easily accessed from the buttons on the unit. The remote is there so that the passengers from the rear seats don't have to lean towards the central console to operate the unit.
Jul 01, 2010 | Dual Electronics XDVD710 Car DVD Player
RS Focus registered yesterday 19th March Keyless entry but remote fobs do not lock or unlock car. The car was driven back yesterday hav ing now covered 114 miles alarm was going off last night but thats...
should not be using fob buttons for entry or locking for emergency only .if keyless entry walk up to car with fob do not press any buttons see if door opens then walk away from car with fob about 20m then go back to car without fob and see if door locked if so all working fine .indicators will not flash if the above dont work take back to main dealer for diagnostics keys may need to be reprogrammed
Mar 20, 2010 | 2009 Ford Focus
No Display on controller
Try replacing the battery but if it wont work you need to replace the remote control itself, but for the main time you can operate the unit by pressing the emergency switch button to operate the unit manually.
Jan 09, 2008 | LG LS-L1210CL Mini Split Air Conditioner
AIR CONDITIONER REMOTE
- Check if the battery is ok.
- Some remote control have reset button, you can find it at the front or back at the compartment of the battery push the rst button with pin or ballpen to reset it and try.
- Some remote control have selector switch in both remote control and at the board inside the unit. Try to transfer the switch button from A to B and also at the board inside the unit and reset the remote control and try.Or need to reconfigure the remote control to select the frequency.
- Try your remote control to other unit with same brand as yours to confirm if your remote control is really need a replacement. If it works then your receiver board in the unit is need a replacement. Or if wont work then you have to buy a new remote control. But if you have no budget then try to switch on the unit using emergency button to operate the unit.
Dec 26, 2007 | Heating & Cooling
Volume and mute buttons suddenly stopped working
Try changing the batteries. Most times the "tivo" buttons will work but the "tv" buttons will stop working when the batteries are low.
If you have done that, go back into settings and program the remote again for your tv, then give it a shot.
Nov 05, 2007 | Tivo DirectTV Remote Remote Control
Heating & Cooling Logo
44 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
